What is Var(X) for my defined X?
  • Context: Graduate
  • Thread starter Thread starter Pzi
The discussion revolves around the calculation of the mean and variance of a random variable X defined as the sum of n randomly chosen natural numbers from a set of N balls numbered 1 to N. Participants explore the theoretical aspects of this problem, including the necessary calculations for both the mean and variance, while addressing potential errors and alternative approaches.
  • One participant defines the random variable X as the sum of n chosen numbers and proposes a method to calculate its mean, suggesting that each number contributes equally to the sum.
  • Another participant outlines the formula for variance, indicating the need to compute both the first and second moments of X, and provides specific calculations for E(kikj) and E(ki2).
  • Several participants share their results for the mean and variance, with one stating E(X) = n(N+1)/2 and Var(X) = n(N+1)(N-n)/12, while others express uncertainty about their own calculations.
  • Discrepancies arise regarding the calculation of E(kikj), with participants questioning each other's logic and arithmetic, leading to further exploration of the correct approach.
  • One participant acknowledges a mistake in their arithmetic and attempts to clarify their calculations, while another expresses confusion over differing results and seeks validation from the group.
  • Participants engage in a back-and-forth regarding the correctness of their formulas and calculations, with some suggesting that their results align while others remain skeptical.
There is no consensus on the calculations for E(kikj) and the resulting variance. Participants express differing views on the correctness of their approaches and results, indicating ongoing debate and uncertainty.
Participants note potential arithmetic errors and discrepancies in their calculations, which may affect the final results. The discussion highlights the complexity of deriving the variance and the need for careful consideration of the mathematical steps involved.
Readers interested in probability theory, combinatorial mathematics, or statistical analysis may find the exploration of this problem and the various approaches taken by participants to be informative.
Pzi
This applies to natural numbers [itex]n[/itex] and [itex]N[/itex] where [itex]n<N[/itex].
We have [itex]N[/itex] balls representing numbers [itex]1,2,...,N[/itex].
We randomly choose [itex]n[/itex] of those balls which happen to represent numbers [itex]{k_1},{k_2},...,{k_n}[/itex].
We then define a random variable [itex]X = {k_1} + {k_2} + ... + {k_n}[/itex].
What is the mean and variation of [itex]X[/itex]?
Well there are [itex]\left( {\begin{array}{*{20}{c}}N\\n\end{array}} \right)[/itex] equally likely combinations and every one of them brings [itex]n[/itex] summands. So we get [itex]\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> n<br /> \end{array}} \right) \cdot n[/itex] summands overall. Since there is no bias towards any particular number it means that every number is added [itex]\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> n<br /> \end{array}} \right) \cdot \frac{n}{N}[/itex] times hence our mean:
[itex]E\left( X \right) = \frac{{\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> n<br /> \end{array}} \right) \cdot \frac{n}{N} \cdot \left( {1 + 2 + ... + N} \right)}}{{\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> n<br /> \end{array}} \right)}} = \frac{n}{N} \cdot \frac{{N\left( {N + 1} \right)}}{2} = \frac{{n\left( {N + 1} \right)}}{2}[/itex].
Unfortunately variance seems to be an entirely different animal since I cannot just rip sums apart and add numbers in a different order. Any ideas?
It is a straightforward, but messy, calculation.
Let X = ∑ ki. mean = E(X), var = E(X2) - (E(X))2
To compute E(X) all you need is E(ki) = N/2.
To compute E(X2), some work is required.
You need (a) E(kikj) for i ≠ j, and (b) E(ki2).
For (a) I got N(N+1)/4 - (2N+1)/6, for (b) I got (N+1)(2N+1)/6.
To get the final answers you need to multiply the mean by n.
For the second moment {E(X2)}, there are n(n-1) (a) terms and n (b) terms.
Good luck!
In case you weren't able to work it out, I got the following:
E(X) = n(N+1)/2
See if you get same.
E(X) = n(N+1)/2
I appreciate your dedication very much. Sorry for not getting back to this topic in a reasonable amount of time.
So for i≠j you apparently got E(kikj) = N(N+1)/4 - (2N+1)/6.
Meanwhile I got
[tex]E({k_i}{k_j}) = \frac{1}{{\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> 2<br /> \end{array}} \right)}}\sum\limits_{i = 1}^{N - 1} {i \cdot \sum\limits_{j = i + 1}^N j } = \frac{2}{{N(N - 1)}}\sum\limits_{i = 1}^{N - 1} {i \cdot \frac{{(N + i + 1)(N - i)}}{2}} = \frac{{N(N + 1)}}{2} + \frac{{1 - 2N}}{6} + \frac{{N(1 - N)}}{4}[/tex]
Is my logic flawed here? Also I checked the literature for answers and can confirm that your conclusion about mean and variation is correct.
Meanwhile I got
You made at least one arithmetic error. The summand in the second summation should be
i(N-i+1)(N-i)/2. I'll let you finish from there.
In any case I got E(X2) = n(n-1)(N+1)(3N+2)/12 + n(N+1)(2N+1)/6,
where the first term is the contribution of all products of different numbers and the second term is the contribution of all the squares.
Why do you say so?
(i+1)+(i+2)+(i+3)...+(N-2)+(N-1)+N = (N+i+1)(N-i)/2
Well the first term is E(kikj) added n(n-1) times isn't it? Hence E(kikj)=(N+1)(3N+2)/12 (for i≠j) which is not the same as previously stated by yourself E(kikj)=N(N+1)/4-(2N+1)/6.
Sorry if I missed something.
P.S. http://www.wolframalpha.com/input/?i=2/(N*(N-1))*sum(i*sum(j,+j=i+1,N),+i=1,N-1)
it gives the same result as mine so I'm confused now, is it the wrong way to calculate E(kikj) ?
Sorry - I sometimes get sloppy in my arithmetic (Jan. 11 - my error was in dividing by N(N+1) when I should have
divided by (N-1)N), including my comment saying you had an error. However the calculation on Jan. 14 was done very carefully (where I divided by N(N-1)). This included the result I mentioned yesterday.
I can't figure out why yours comes out differently.
My calculation - E(XiXj) = {(∑i)2 - ∑i2}/N(N-1), where the sums are i = (1,N).
One quick check, for N = 2, the product of different x's ≡ 2, so the expectation is obviously 2.
In any case, your result is the same as mine.
Thanks for all the help.
To sum things up I'd just like to say that I almost got it right after your first post. Unfortunately I made a very silly mistake at the very end. Which in turn led to a whole phase of contemplation and doubts.
I attach that almost-correct handwritten solution just for fun.
Differences in notation: E(X)=M(X), Var(X)=D(X), X=W.
  • · Replies 0 ·
  • · Replies 18 ·
