Differences between the triplet and singlet states
  • Thread starter Thread starter Cheminewbie
    Singlet States
The triplet state features parallel spins with a total spin quantum number S=1, resulting in three possible states, while the singlet state has paired spins (S=0) and only one state. The singlet state is generally at a higher energy level due to electron repulsion in the same orbital. Differences between these states include reactivity, with singlet oxygen being significantly more reactive than triplet oxygen, and variations in half-lives and solvent effects. Additionally, transitions from triplet to ground state have longer half-lives compared to singlet to ground state transitions, which is crucial in fluorescence microscopy. Understanding these distinctions is essential for applications in chemical reactivity and photophysical processes.
Cheminewbie
What are the differences between the triplet and singlet states.
triplet state-- parallel spins-- S=1 , 2S+1=3
Singlet state-- Paired spins---S=0 , 2S=1= 1
singlet state has paired spins of electrons in the same orbit, thus there are repulsion force between the two electron in the same orbit.
Thus, singlet state is in higher energy than triplet state.
Apart than this, is there any differences between singlet state and triplet state? For instance, the population, half life, solvent effect and etc.
Chemistry news on Phys.org
For example, singlet O2 is a lot more reactive than normal triplet O2 and reacts with water to form hydrogen peroxide. Look it up in wikipedia http://en.wikipedia.org/wiki/Singlet_oxygen .
I'm not sure about other elements, maybe someone else knows more.
Your conclusion is not general. It's not always the case that singlet spin multiplicity is higher in energy than a triplet. The things you listed all depend on the particular case.
Half lives from triplet to ground state are longer than singlet to ground state transitions. This is of HUGE importance in fluorescence microscopy.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
