Is it comman for people to Fail their PhD Presentation?
In summary, failing a defense in a PhD program is rare and there are several checkpoints that a student must pass before reaching the defense. This includes getting into the program, committee meetings, candidacy and comprehensive exams, and completing and publishing original research with the approval of the supervisor. In case of potential failure, there are options for a conditional pass or additional time for remedial work before re-examination.
Okki2
40
You know when you are disputing (i think is the word) infront of people and another doctor is grilling you on your research.
Defending, not disputing. No, it's not very common for people to fail this, at least in physics. Most of my profs have a story about someone it happened to, but usually only one story. Your adviser should not let you attempt to defend if they think you might not pass it. It's not their job to make you do your work, but it should be their job to decide if you're done or not. I've seen people fail masters defenses for not knowing enough background on the subject to answer questions on it, but I've never seen someone fail a PhD defense. Usually it's at least 4 professors grilling you, not just one.
While it's not absolutely unheard of, it is rare to fail a defence. There are many check points that the student has to get through to reach the defence. These can include:
- getting into a graduate program in the first place
- numerous committee meetings
- candidacy examination
- comprehensive examination
- publishing original research (which ends up as chapters in the thesis)
- supervisor approval of the thesis
After all that, a thesis committee has more options than pass/fail. For example, they can recommend a conditional pass, or perhaps an additional period of time in which the candidate will perform remedial work and then re-examine.
1. Is it common for people to fail their PhD presentation?
It is not uncommon for people to fail their PhD presentation. In fact, a small percentage of PhD students do not pass their defense on the first attempt.
2. What are the main reasons for failing a PhD presentation?
The main reasons for failing a PhD presentation can vary, but they often include lack of preparation, unclear research goals, poor presentation skills, and inadequate understanding of the subject matter.
3. How can one increase their chances of passing a PhD presentation?
To increase your chances of passing a PhD presentation, it is important to thoroughly prepare by practicing your presentation, knowing your research inside and out, and seeking feedback from your advisor and peers.
4. Can a failed PhD presentation be rescheduled?
Yes, in most cases, a failed PhD presentation can be rescheduled. However, it is best to consult with your advisor and program guidelines to determine the specific steps and requirements for rescheduling.
5. What happens if someone fails their PhD presentation?
If someone fails their PhD presentation, they will typically have to revise their research and presentation and schedule a new defense date. This can delay graduation and may require additional coursework or research.
  • STEM Academic Advising
