I think science too much, apparently.
  • Thread starter 1MileCrash
  • Tags
    Science
In summary, the question of which knife, a dull one or a sharp one, will give a worse cut is ambiguous and subjective. Factors such as type of blade, pressure applied, and duration of cutting must be considered to have a meaningful discussion. However, a sharp knife is generally more likely to make a clean cut and cause less damage to nerves, making it the preferable choice for amputation.
1MileCrash
1,342
41
My friend's girlfriend asked us a question from one of her home ec classes to stump us. I'm sure you've all heard it before.
"What will give you a worse cut, a dull knife, or a sharp knife."
My response: "a sharp knife, because obviously, its narrower edge allows it to split materials more efficiently (it can be thought of as a wedge..)"
She responds, proudly: "Nope! With a dull knife you aren't paying attention because you think that since it's dull it won't cut you, so you're more likely to mess up and cut yourself."
A friend responds: "Yeah, you just aren't thinking deep enough into it."
I explain to them: "No, I think it's more of the fact that I don't see how it make sense to make a judgment call on the person handling two materials when trying to compare two materials."
I was thinking science too much, they said. And perhaps they are right. When I hear this question asked I want an experiment set up where there are no mysterious variables like the snotty disposition of the person while using the dull knife. I want the same event repeated with the dull and sharp knives.
It's like saying "which is more malleable, gold or nickel?" Nickel, because you assume gold is more malleable so you hit it harder, which breaks it. Therefore nickel is more malleable than gold.
You're right, they're wrong.
The question is not worded well. "Worse" can mean a lot of different things. Cuts with sharp knives tend to be cleaner, but can possibly be deeper. Dull knives damage more tissue (and can complicate the matter with nasty side effects like tearing or shredding flesh) and you also have less control over them, giving them a strong argument for being "worse."
See, that's the type of reasoning I can get behind. If dull knives give "worse" cuts, the person wielding the knive's attitude toward their task isn't a valid reason behind such a claim. That is interference with the experiment.
I don't know much about knives and if someone would explain to me why I was wrong the way you did I would accept that. The reasons given just urked me.
"What will give you a worse cut, a dull knife, or a sharp knife[?]"
The question is ambiguous. In order to have a meaningful discussion about it, there would need to be an agreement on a number of variables (type of blade used, pressure applied, duration of cutting, motion used to cut, etc).
That doesn't follow. The question wasn't, "Are you more likely to cut yourself with..."
i don't accept their explanation. a dull knife requires more force to make a cut. so it's more likely you apply too much force, slip, and lose control of your tool.
Thats exactly what I thought when reading the OP.
The question is not ambiguously worded. All else being equal, a sharp knife will cut you worse. Period. They didn't answer the question asked, they answered a different one - a question such as "which is more likely to cut you?"
Your friend's girlfriend got it wrong. She has poor comprehension skills.
The saying is that you are more likley to cut yourself with a dull knife because you need to apply more pressure and the knife is more likely to slip and cut you.
His girlfriend = Fail
No, other people don't think science enough.
Pardon my ignorance, but what is a home ec class? Cooking?
Ah! Thanks!
Wow! That is actually quite interesting. I wonder if my school offers that? Thanks for the link!
"Ceteris paribus" wasn't in the question, so, to me, there is ambiguity. Also, "worse" can be subjective. I'd ask for some criteria and rules for testing (amount of blood, depth of cut, how long it takes to heal, etc.) to avoid any shenanigans.
I agree with your friend's girlfriend, but for different reasons. Sharp knife would make a clean cut where as a dull knife would tear the skin and mangle the nerves. I think this is why papercuts hurt much more than a knife cut.
If you don't believe me, have you ever drop a glass object and cut yourself? I tend not to feel glass cuts because the glass is so sharp, making a smooth incision into my skin. Also, a dull knife blade is likely to make a wider cut than a sharp knife, contacting more nerves. Basically, if you had to have a limb amputated, which would you choose: sharp knife or dull knife? Simple choice, right? The dull knife will damage your nerves, which is why surgeons use sharp knives.
As much as this can become a, pardon the pun, an issue of splitting hairs, there is a simple argument for why at least they're wrong. They didn't answer the question. They answered a different one. So as Evo said, their comprehension skills are sub-bar to say the least.
It's equivalent to saying "Which costs more, a soda in sweden or a soda in south africa" and answering "In south africa because you're more likely to be attacked by muggers who proceed to shoot you". If that sounds retarded, there is good reason.
AAarrgh, she had it wrong, read my post! This is a very well known question in cooking. She got it backwards. FAIL
Very authoritarian. Yet you aren't answering the same question.
= Likelihood of cut.
Which is what the gf messed up.
=Severity of cut.
I'd rather have a sharp knife for three reasons.
1. They are easier to control.
2. If you do cut yourself, a clean cut is generally easier to sort out. (even if you chop your finger off a clean cut will be easy to sew it back on).
3. Dull knives piss me off so much.
Right. Worse to my mind actually means less efficient, i.e. not a clean cut. I'd rather cut my cheese or vegetables with a sharp knife, not a dull one. A dull one would be "worse." Poorly worded question.
But when your GF asks you a question like that, it is more a matter of psychology and diplomacy than of science to find the proper response. It's not about too little or too much science. I have read that the difference between a nerd and a geek is that a geek is smart but doesn't lack social skills. It's ok to be geeky.
-DaveKA
That sounds good in theory, but I don't think it's true. First of all, dull isn't defined. I've never cut myself with a dull knife, it's always been a sharp knife. But the reason I say I've never cut myself with a dull knife is because if I cut myself with it, then I'm unlikely to conclude that it's dull. I may have cut myself with a dull knife, but then again, if it's dull, how did it cut me? Apparently it's not dull enough not to cut me.
Spoons are dull. I've never cut myself on one of those.
my thought's exactly.
The girl got the message wrong or was told wrong. Here is what she was probably told in class, since this is told to everyone that goes to a cooking class.
Always use a sharp knife! You are more likely to cut yourself with a dull knife than a sharp one, because a dull knife requires you to use more force to get the job done.
http://www.martins-supermarkets.com/cnt/cyberoctober08.html
My cooking knives are sharp enough to shave hair off your arm with. That's for a reason. They are safer to use, since you use a LOT less force to perform a task than you would have to exert when using a dull knife.
For very heavy tasks, I have a Chicago Cutlery butcher's knife and an antique cleaver. Those blades are kept sharp, but not at so fine an angle that the edge would roll when separating joints or breaking up turkey carcasses. The edges are more obtuse than the edges on chefs knives or paring knives, just for the sake of durability and low maintenance. Dull knives in a busy kitchen are a recipe for accidents.
Now I'm starting to wonder if there might be something wrong with me after all. Even though 1MileCrash specified home ec, my first and strongest thought about the question regards fighting knives rather than culinary ones.
My favourite, that I always carried in a "shoulder holster", was an 1896 Swedish Mauser bayonette with a 10 1/2" blade. The tip was razor-sharp for penetration, as were a couple of centimetres next to the hilt for cutting things like ropes. The rest was dull, almost ragged, for maximum tissue damage, with an awesome blood groove. I honestly think that I would rather be shot than stabbed with that thing. (Not that I really want either, though.)
I think your girlfriend might be retarded.
I suggest trying the 'zoo test' to confirm diagnosis.
I run into this problem ALLLL the time. And then when i try to explain why I answered like I did, and its really that they didn't ask the right question, i get the "Whatever" response. Its so annoying and frustrating.
Which is why I've learned who is worth having such a discussion with and who I'm better off just agreeing with and letting the matter go.
I think i still need to learn that lesson.
They should probably give college courses for math and science majors on "dealing with non math and science people." It's easy to become elitist or arrogant when you are versed on a topic that others are not. It is the bane of the tech support analysts existence to have to deal with "stupid people" (who aren't necessarily stupid, just non computer savvy) all day, and the good ones know how to do it without alienating their clients, friends, wives, girlfriends...
-DaveKA
dkotschessaa said:
they should probably give college courses for math and science majors on "dealing with non math and science people." it's easy to become elitist or arrogant when you are versed on a topic that others are not. It is the bane of the tech support analysts existence to have to deal with "stupid people" (who aren't necessarily stupid, just non computer savvy) all day, and the good ones know how to do it without alienating their clients, friends, wives, girlfriends...
-daveka
pebcak
  • #31
Evo said:
pebcak
I like PICNIC
  • #32
Perhaps by thinking more relationally this sort of conflict can be avoided for you in the future. She was probably not thinking in "I'm right and you're wrong" terms (at least initially).
  • #33
For clarification this is my friend's girlfriend, not mine.
  • #34
Obviously they are not capable to think in a logical way or think in a rigid way. They can not distinguish differences between definitions (more likely to cut you and more capable to make a deep cut). By any chance, did they get no or very few training in math/physics?
Related to I think science too much, apparently.
What does it mean to "think science too much"?
Thinking science too much refers to overanalyzing or overthinking scientific concepts or ideas. It can also refer to an excessive focus on scientific thinking at the expense of other types of thinking.
Why is it important to balance scientific thinking with other types of thinking?
Balancing scientific thinking with other types of thinking allows for a more well-rounded and holistic approach to problem-solving and decision-making. It also allows for creativity and innovation, which are crucial in the scientific field.
How can one avoid thinking science too much?
One can avoid thinking science too much by consciously making an effort to incorporate other types of thinking, such as creative or critical thinking, into their approach. It is also important to take breaks and engage in activities outside of science to prevent burnout.
Is thinking science too much a bad thing?
Thinking science too much can have both positive and negative effects. While it can lead to a deeper understanding of scientific concepts, it can also hinder creativity and limit alternative perspectives.
How can one strike a balance between thinking science and other types of thinking?
Striking a balance between thinking science and other types of thinking involves being aware of one's thinking patterns and intentionally incorporating different approaches. It is also helpful to collaborate with individuals who have different thinking styles and perspectives.
  • Materials and Chemical Engineering
  • Other Physics Topics
  • General Discussion
  • Mechanical Engineering
10K
