Inverse laplace transform of this simple function?
In summary, the inverse Laplace transform of (2s)(1/(s-2)) can be calculated using the identity ∫f(T)g(t-T)dT=F(s)G(s), but be careful with the definition of the Laplace transform.
iScience
466
what is the inverse laplace transform of (2s)(1/(s-2))?
could i use the identity ∫f(T)g(t-T)dT=F(s)G(s)?
i was hesitant so i figured i'd just ask before i continue..
write
$$\frac{s}{s-2}=\frac{s-2+2}{s-2}=1+\frac{2}{s-2}$$
or go ahead and use convolution
You could use the property
[tex] \cal{L}(f^\prime)(s) = s\, \cal{L}(f)(s) - f(0+)[/tex]
Be careful, though: that is for a LT defined as
[tex] \cal{L}(f)(s) = \int_{0+}^{\infty} e^{-st} f(t) \, dt. [/tex]
If, instead, you prefer to define your LT as
[tex] \cal{L}(f)(s) = \int_{0-}^{\infty} e^{-st} f(t) \, dt, [/tex]
then you will need
[tex]\cal{L}(f^\prime)(s) = s\, \cal{L}(f)(s) - f(0-)[/tex]
1. What is the inverse Laplace transform of a simple function?
The inverse Laplace transform of a simple function is the original function that produces a given Laplace transform. It is used to solve differential equations in the time domain.
2. How do you find the inverse Laplace transform of a simple function?
To find the inverse Laplace transform of a simple function, you can use a table of Laplace transforms or use algebraic manipulations and theorems to transform the function back to its original form.
3. Can all functions be transformed using the inverse Laplace transform?
No, not all functions have a Laplace transform that can be inverted to find the original function. Some functions may not have a Laplace transform at all, while others may have a transform that is difficult to inverse.
4. What are some common properties of the inverse Laplace transform?
Some common properties of the inverse Laplace transform include linearity, time shifting, and frequency shifting. These properties allow for easier manipulation of functions and finding their inverse transforms.
5. How is the inverse Laplace transform related to the Laplace transform?
The inverse Laplace transform and the Laplace transform are inverse operations of each other. The Laplace transform converts a function from the time domain to the frequency domain, while the inverse Laplace transform converts it back to the time domain.
