Show Span of Vector Sum of Lengths 2 & 4 is 2-6
In summary, the problem asks how to show that the span of a vector in set A and a vector in set B is all vectors with lengths between 2 and 6. One approach is to find the upper and lower bounds using the triangle inequality and then show that any vector within this range can be created using a vector of length 2 and a vector of length 4. This can be done by considering the angle between the vectors and showing that the distance from any point on the vector to a circle of radius 4 around the origin is between 2 and 4 units.
ehrenfest
2,020
Let A be the set of all vectors with length 2 and let B be the set of all vectors of length 4.
How do you show that the span of the sum of a vector in A and a vector in B is all vectors with lengths between 2 and 4?
EDIT: change 4 o 6
I tried drawing triangles but that got me nowhere. Do I actually need to write out the components or something?
Let me know if I did not explain the problem okay.
Suppose [itex]a \in A, b \in B[/itex]. Can you estimate the length ||a + b|| in terms of ||a|| and ||b||? Or you could find a limiting case, and show that it is a limiting case (e.g. write down two vectors for which the norm of the sum is maximal and show that it is smaller for any two others).
By the way, are you sure it's between 2 and 4? E.g. if a and b are parallel it will have length 2 + 4 = 6.
Ah. You're right. It should be
"How do you show that the span of the sum of a vector in A and a vector in B is all vectors with lengths between 2 and 6?"
You can get the upper and lower bounds with the triangle inequality.
I am just not sure how to prove that it spans the annular region between the upper and lower bounds.
All you need to show that the two vectors, one of length 2 and another of length 4, can create all vectors of length between 2 and 6.
What is span? Do you know what that is?
Another hint: choose the angle between the vectors.
Sorry. I am not sure what you mean CompuChip? There are three vectors in question.
Anyway, let [tex] \vec{v} [/tex] be an arbitrary vector with length between 2 and 6. All I need to show is that [tex] \vec{v} [/tex] is two units of distance from a circle of radius 4 around the origin. Drawing the picture this is clearly true.
The closest distance from [tex] \vec{v} [/tex] to the circle is less than 2 since v must be perpendicular to the circle somewhere and it is just intuitive (can someone explain that any better?)
There are then distances from v to the circle greater than 4 for the same reason (can someone explain why that is true succinctly?).
And since the distance of v from the circle vary continuously, we are done.
On the contrary, it doesn't even make sense! What do you mean by a vector being two units of distance from a circle of radius 4 around the origin? What do you mean by the distance from a vector to a circle?
The length of our vector minus the circle vector is the distance from our vector to a point on the circle!
1. What is the meaning of "Show Span of Vector Sum of Lengths 2 & 4 is 2-6"?
The phrase "Show Span of Vector Sum of Lengths 2 & 4 is 2-6" refers to a mathematical concept that involves finding the span of a vector sum. This calculation involves adding the two given vector lengths (2 and 4) and then finding the range of possible values for the resulting sum, which in this case is between 2 and 6.
2. How is the span of a vector sum calculated?
The span of a vector sum is calculated by adding the lengths of the given vectors and then finding the range of possible values for the resulting sum. In the case of this question, the span is between 2 and 6.
3. Why is it important to find the span of a vector sum?
Finding the span of a vector sum is important because it helps us understand the range of possible values for the resulting sum. This can be useful in many areas of science and mathematics, such as in linear algebra and physics.
4. Can the span of a vector sum be negative?
No, the span of a vector sum cannot be negative. The span represents the range of possible values for the resulting sum, and since negative numbers are not included in this range, the span cannot be negative.
5. How is the span of a vector sum related to the lengths of the individual vectors?
The span of a vector sum is directly related to the lengths of the individual vectors. In fact, it is calculated by adding the lengths of the given vectors. The resulting span represents the range of possible values that the sum of the two vectors can have.
