Conditional expectation of a product of two independent random variables
It will depend on the specific distributions of α, β, and e. If they are all Gaussian, then the equation will hold, but if not, then it is not guaranteed.
Geert
Suppose that α and β are independently distributed random variables, with means; μ_α, μ_b
and variances; δ_α^2, δ_β^2, respectively.
Further, let c=αβ+e, where e is independently distributed from α and β
with mean 0 and variance δ_e^2.
Does it hold that
E(αβ | c) = E(α|c) E(β|c)
If not; does it hold when we assume that α, β and e are Gaussian?
If not; does it hold when μ_β = 0?
More general, does it still hold when c = f(α,β) + e, with $f(,)$ some arbitrary function.
Thanks in Advance;
Geert
.No, it does not hold in general that E(αβ | c) = E(α|c) E(β|c). This is not true in the case of non-Gaussian distributions, and not even when μ_β = 0. However, if α, β, and e are all Gaussian, then this equation holds.More generally, if c = f(α,β) + e, with $f(,)$ some arbitrary function, then the equation will not necessarily hold.
What is the definition of conditional expectation of a product of two independent random variables?
The conditional expectation of a product of two independent random variables is a mathematical concept used to calculate the expected value of the product of two variables, given the values of the two variables are independent of each other. It represents the average value of the product of the two variables over all possible outcomes.
How is conditional expectation of a product of two independent random variables calculated?
The conditional expectation of a product of two independent random variables is calculated by taking the product of the two expected values of the individual variables. This can be represented as E[XY] = E[X] * E[Y].
What is the significance of conditional expectation of a product of two independent random variables?
The conditional expectation of a product of two independent random variables is an important concept in probability and statistics. It is used to calculate the expected value of a product of variables in various real-world scenarios, such as in finance, economics, and engineering. It also plays a crucial role in understanding the relationship between two variables.
Can the conditional expectation of a product of two independent random variables be negative?
Yes, the conditional expectation of a product of two independent random variables can be negative. This can occur if one or both of the variables have a negative expected value, or if the variables have a negative correlation. It is important to consider the context and interpretation of the value in such cases.
How does the conditional expectation of a product of two independent random variables relate to the concept of covariance?
Covariance is a measure of the linear relationship between two variables, while conditional expectation of a product of two independent random variables is a measure of the expected value of the product of two variables. These two concepts are related, as covariance can be calculated from the conditional expectation of a product of two variables by subtracting the product of their individual expected values. This relationship is known as the covariance formula.
