Investigating Frequency Offsets on OFDM Transceiver Performance
In summary, you have successfully simulated an OFDM transceiver using MATLAB and investigated the effect of frequency offsets on system performance. The fundamental frequency is defined as the inverse of the symbol period and you have correctly used it in your code. Adding a plot of the theoretical bit error rate curve for comparison would further enhance your analysis. Keep exploring different aspects of OFDM and continue your great work!
O.J.
199
I am simulating an OFDM transceiver using MATLAB. I am trying to investigate the effect of frequency offsets on the system performance by measuring different offsets against their respective bit error rate with a SNR of 10 dB.
All equations and variables are presented in the code. I am uncertain as to what is the fundamental frequency though but I used 1/T (where T is the symbol period without guard time of each subcarrier).
Here is my code:
%% OFDM Model (CP and GT) with AWGN at different SNR's
% NOTE! OFDM Parameters used in WiMAX are found in the ebook page 42!
%% OFDM parameters
Tu = 0.001; %symbol period for each subcarrier
N = 128; %number of carriers
R = 1/8; %guard time ratio (WiMAX standard)
G = Tu*R; %guard time
Ti = Tu + G; %OFDM symbol period
T = Ti/N; %original symbol period
fi = 1/Ti; %symbol rate of each datastream
f = fi*N;
Q = 8; %sampling frequency factor (should be chosen such that Q*R = whole number)
Fs = Q*f; %sampling frequency
z = 4*N;
t = 0:1/Fs:(z*Ti-1/Fs); %simulation period (upper limit should
%be an integer K ==> K*N*Ti -1/Fs
%% TRANSMITTER
%generate message
L = length(t)/Q;
M1 = round(rand(1,L));
tn = 0:Q/Fs:(z*Ti-1/Fs);
%using BPSK (mapping 0's to -1's)
M=2*M1-1;
stem (tn,M); %plot the original message (BPSK)
xlabel('Time (seconds)');
ylabel('Digital Message Signal (in discrete bits)');
title ('Message vs Time');
%S/P conversion
A = reshape(M,N,L/N);
%modulate each subcarrier using IFFT
B = ifft(A);
%P/S conversion
C = reshape(B,1,L);
%oversample by a factor of Q (DAC ~)
D=ones(Q,1)*C;
D=conj(D(:)');
%guard time insertion
i=1;
k=1;
for t0=1:L;
for t1=1:R*Q;
D(1,k*Q-R*Q+i)=0;
i=i+1;
end
k=k+1;
i=1;
end
%cyclic prefix insertion
j=1;
i=Q-R*Q+1;
k=1;
a=1;
for f = 1:length(C);
for g = 1:R*Q;
D(:,Q*k-R*Q+j) = D(:,a);
j=j+1;
a=a+1;
end
j=1;
a=1+k*Q;
k=k+1;
end
plot (t,D); %plot the OFDM signal
xlabel ('Time (seconds)');
ylabel ('OFDM Signal');
title ('OFDM Signal (with guard time & cyclic prefix) vs Time');
%% Add frequency offset
SNR = 10;
index=1;
f0 = 1/Tu;
S = zeros(2,10);
BER = 0;
BER1 = 0;
per = 0;
N_max = 100;
h = modem.pskdemod(2,pi);
for tr = 0:0.05:0.5
D1 = D*exp(2*pi*sqrt(-1)*per*f0);
for tk = 1:N_max
%% RECEIVER
%undersampling (ADC ~) removing Tg and CP
Dn = awgn(D1, SNR,'measured');
E = zeros(1,L);
i = 1;
j = 1;
for t0=1:L;
E(1,i) = Dn(1,j);
i=i+1;
j=j+Q;
if j>Q*L
j=j-1;
end
end
%S/P
F = reshape(E, N, L/N);
%demodulation
G = fft(F);
%P/S
Mr = reshape(G, 1, L);
Mr = real(Mr);
%BPSK Demodulation
M2 = demodulate(h,Mr);
%comparing the received and the sent message (0's & 1's)
bit_error = length(find(M1~=M2));
BER = bit_error/length(M2);
BER1 = BER1+BER;
end
S(1,index) = BER1/N_max;
S(2,index) = per;
per = per + 0.05;
index = index + 1;
BER1 = 0;
BER = 0;
end
semilogy(S(2,:),S(1,:))
xlabel ('Normalized frequency offset')
ylabel ('Bit Error Rate')
title ('BER vs Frequency Offset')
grid on
First of all, great job on simulating an OFDM transceiver using MATLAB! It's great to see your interest and effort in investigating the effect of frequency offsets on system performance.
To answer your question about the fundamental frequency, it is defined as the lowest frequency component in a waveform. In the case of OFDM, the fundamental frequency is equal to the inverse of the symbol period (1/T). This is because in OFDM, the subcarriers are spaced at intervals of 1/T, which means they have a frequency spacing of 1/T.
In your code, you have correctly used 1/T as the fundamental frequency. However, I would recommend using a variable to represent this value instead of a comment, as it will make your code more readable and easier to modify in the future.
Overall, your code looks good and your approach of varying the frequency offset and measuring its effect on the bit error rate is a good way to investigate the system performance. One suggestion I would make is to also plot the theoretical bit error rate curve for comparison, as this can help validate your simulation results.
Keep up the good work and continue exploring different aspects of OFDM!
1. How does frequency offset affect the performance of an OFDM transceiver?
Frequency offset refers to the difference between the center frequency of the transmitted signal and the center frequency of the receiver's local oscillator. This can cause inter-carrier interference and reduce the signal-to-noise ratio, ultimately leading to a decrease in the performance of an OFDM transceiver.
2. What are the main sources of frequency offset in an OFDM system?
The main sources of frequency offset in an OFDM system include Doppler shift, oscillator phase noise, and channel distortion. Doppler shift is caused by the relative motion between the transmitter and receiver, while oscillator phase noise is inherent in the transmitter and receiver's local oscillators. Channel distortion can also introduce frequency offsets due to multipath propagation.
3. How can frequency offset be mitigated in an OFDM system?
Frequency offset can be mitigated through the use of synchronization techniques such as pilot symbols and frequency correction algorithms. Pilot symbols are known symbols that are inserted into the transmitted signal and can be used to estimate and correct for frequency offset. Frequency correction algorithms use digital signal processing techniques to estimate and compensate for frequency offset in the received signal.
4. What are the consequences of not addressing frequency offset in an OFDM system?
If frequency offset is not properly addressed in an OFDM system, it can lead to a decrease in the signal-to-noise ratio and an increase in bit error rate. This can result in degraded performance and potentially cause the system to fail to meet its desired specifications.
5. How does the severity of frequency offset depend on the system parameters?
The severity of frequency offset depends on several system parameters such as carrier frequency, channel bandwidth, modulation scheme, and channel conditions. Higher carrier frequencies and wider channel bandwidths can result in larger frequency offsets, while more robust modulation schemes and better channel conditions can help mitigate the effects of frequency offset on system performance.
  • Atomic and Condensed Matter
