Why aren't black holes the brightest objects in the universe?
In summary, the conversation discusses the concept of time dilation near the event horizon of a black hole and how it affects the perception of objects falling into it. The redshift of light as it approaches the horizon is also discussed, as well as the possibility of a constant source of energy entering the horizon. The concept of conformal time is mentioned and its potential effects on observing black holes. The conversation also touches on the brightness of black holes and their relation to quasars.
DARKSYDE
50
I've seen many examples that an observer witnessing an object approach the event horizon will see it slow down to a point where it never seems to cross. Why then do we not see "everything" that has crossed into this horizon frozen in time?
Astronomy news on Phys.org
The light from the "frozen" object gets red shifted as time passes. Sooner or later the radiation will be in the radio wave spectrum.
Then radio telescopes would be blinded by them if that were true?
We'd be talking about wavelengths many orders of magnitude larger then the observable universe. I don't think any radio telescopes yet developed detect these.
Regardless of the wavelength, the power observed by an external observer will just go asymptotically down to zero as the time dilation increases. The wavelength shift just means that this radiation (what little amount there is after an appreciable time) leaves the detectable regime that much faster.
But wouldn't there be a constant source of energy entering this horizon? Such as photons ??
You are not seeing the big picture here.
This was way more humorous than it had any right to be, Chronos... :)
Darksyde: In order for you to SEE photons they have to enter your eye! If they're falling into the black hole, they're clearly not going to enter your eye, now are they?
Nabeshim,
That's the point, the observer never fully sees an object cross the horizon. The photons will reach your eye until that point.
Applying my limited understanding of the subject:
If a source of light falls into a black hole, it appears to have its time dilated in such a way so as to never reach the event horizon. But it also means that any two events happening on the source become infinitely stretched in time, as seen by an external observer.
If the two events are two consecutive emissions of a photon, then as it asymptotically approaches the event horizon, the time between the emissions becomes inifitely long. As a result the source appears to grow dimmer(flux goes down) across all wavelengths, even before taking into account the gravitational redshift.
You still fail to 'see' what is happening in conformal time. If you draw it out in a Penrose diagram, it will become obvious.
-Chronos
Would conformal time have any effect if we were to observe black holes in our own galaxy? Since there the expansion of the universe does not apply to this kind of observation, would the Hubble constant be somewhat diminished?
The Hubble effect is too small to measure over distances less than millions of light years.
That is what I thought as well. Why did you mention it then?
You are confusing conformal time with distance. It also applies to gravitational wells.
I just got introduced to quasars.
It would seem that under certain circumstances black holes are among the brightest objects in the universe, though not for the reason the O.P. had in mind.
1. Why do we refer to black holes as "black" if they are not actually black?
Black holes get their name because their gravitational pull is so strong that nothing, including light, can escape from them. This means that they appear "black" to an outside observer, as no light can be emitted from them.
2. If black holes are not emitting light, what makes them visible to us?
While black holes themselves do not emit light, they can be detected through their effects on surrounding matter. As matter falls into a black hole, it heats up and emits X-rays, which can be detected by telescopes.
3. How can black holes be the brightest objects in the universe if they do not emit light?
Black holes may not emit light themselves, but they can be surrounded by extremely bright objects such as accretion disks. These disks are made up of hot, glowing gas and dust that is being pulled into the black hole by its strong gravity. This makes them appear very bright to us.
4. Can black holes eventually run out of surrounding matter to make them visible?
Yes, it is possible for a black hole to run out of matter to feed on. As it consumes matter, it also emits X-rays which can push away surrounding gas and dust, making it more difficult for the black hole to accrete new material. Eventually, the black hole may become "quiet" and no longer be visible to us.
5. How do scientists measure the brightness of a black hole?
Scientists use a variety of techniques to measure the brightness of a black hole. One common method is to measure the amount of X-rays emitted from the accretion disk surrounding the black hole. Other methods include measuring the strength of the gravitational pull and observing the effects of the black hole on its surroundings.
  • Astronomy and Astrophysics
