Rutherford Scattering -scattering angle and formula
In summary, the formula for the differential cross section for Rutherford scattering at a specific angle θ is given by dσ/dΩ = (Z^2e^4)/(16πε^2E^2sin^4(θ/2)). To obtain the total number of particles scattered at angles greater than 60 degrees, you would need to integrate this formula over the solid angle from 60 to 360 degrees. However, for larger scattering angles, other factors may need to be taken into account for accurate results.
prehisto
115
Given variables and data: flux of alpha particles;Z; T-kinetic energy of the flux;
t-thickness of the target.I have to calculate the number of alpha particles which are
scattered in angle θ>60 degrees.
1) Is my formula correct ( see below) if I am including the T-kinetic energy ?
2) Do i have to integrate the solid angle element dΩ from 60 to 360 degrees?
3) What kind of value should I put in the sin^4(θ/2)- do I have to integrate this part as well ?
dN/N=n ((Ze^2)/(8 Pi ε T))^2 dΩ/(sin^4(θ/2))
Where θ-scattering angle
ε-electric constant
n-atoms per unit volume in target
e-electron charge
First of all, it is important to clarify what exactly you are trying to calculate. Are you looking for the total number of alpha particles scattered at angles greater than 60 degrees, or the number of alpha particles scattered at a specific angle greater than 60 degrees? The formula you have provided calculates the differential cross section for scattering at a specific angle, so you would need to integrate it over the solid angle to obtain the total number of particles scattered at that angle.
To answer your specific questions:
1) Your formula is not quite correct. The formula for the differential cross section for Rutherford scattering at a specific angle θ is given by:
Where E is the kinetic energy of the alpha particles. So your formula should be:
dN/N = n*dσ/dΩ*dΩ
2) Yes, you would need to integrate the solid angle element from 60 to 360 degrees in order to obtain the total number of particles scattered at angles greater than 60 degrees.
3) The sin^4(θ/2) term is already included in the formula for the differential cross section, so you do not need to integrate it separately.
Finally, it is important to note that the Rutherford scattering formula is only valid for small scattering angles. For larger scattering angles, other factors such as multiple scattering and the finite size of the target need to be taken into account. So if you are looking for the total number of particles scattered at angles greater than 60 degrees, you may need to use a more sophisticated model or experimental data to obtain an accurate result.
Related to Rutherford Scattering -scattering angle and formula
1. What is Rutherford Scattering?
Rutherford Scattering is a phenomenon in which a beam of charged particles, such as alpha particles, is directed at a thin target, and the deflection of the particles is measured as they pass through the target. This experiment was conducted by Ernest Rutherford in 1911 and helped to prove the existence of the atomic nucleus.
2. How is the scattering angle measured in Rutherford Scattering?
The scattering angle is measured by observing the deflection of the particles as they pass through the target. This is typically done using a detector, such as a photographic plate or a scintillation counter, which records the position of the particles after they have passed through the target. The angle between the incident particle beam and the final position of the scattered particles is the scattering angle.
3. What is the formula for calculating the scattering angle in Rutherford Scattering?
The formula for calculating the scattering angle in Rutherford Scattering is theta = 2 * arctan(d/2D), where theta is the scattering angle, d is the distance between the target and the detector, and D is the distance between the target and the particle source.
4. How does the scattering angle in Rutherford Scattering relate to the charge and mass of the particles?
The scattering angle in Rutherford Scattering is dependent on the charge and mass of the particles, as well as the energy of the incident particle beam. Heavier and more highly charged particles will experience less deflection and have smaller scattering angles compared to lighter and less charged particles at the same energy.
5. What other factors can affect the scattering angle in Rutherford Scattering?
In addition to the charge and mass of the particles, the scattering angle in Rutherford Scattering can also be affected by the density and composition of the target material, the energy of the incident particle beam, and the distance between the target and the detector. These factors should be taken into account when analyzing the results of a Rutherford Scattering experiment.
