Consider a Hydrogen atom in the ground state
In summary, the equations for finding the Kinetic Energy (K) and Potential Energy (U) of a Hydrogen atom in the ground state are K = 13.6 eV/n^2 and U = -27.2 eV/n^2, respectively. The total energy (E) of the atom is found by adding K and U, and to remove the electron completely from the atom, a minimum energy of 13.6 eV is required. The corresponding wavelength of a photon with this energy can be calculated using the formula E = hc/λ, where h is Planck's constant and c is the speed of light.
jcvince17
41
Find:
A- The Kinetic Energy, in eV
B - The Potential Energy, in eV
C - The Total Energy, in eV
D - minimum energy required to remove the electron completely from the atom, in eV
E - What wavelength does a photon with the energy calculated in part (D) have
Vn= (1/Eo)(e2/2nh)
Kn = 1/2 mv2 = (1/E02)(me4/8n2h2)
Un = (1/E02)(me4/4n2h2)
mass of H =1.008
I have no idea. I know i need to use the first listed equation to solve for v in order to use the second and find the Kinetic Energy. But how do i do the first equation since i do not know the E0
Please guide me
If those equations are from your textbook, then they should have a definition for E0 if not the actual value.
Also, something looks wrong. U should have a greater magnitude (and opposite sign) than K, but you have it the other way around.
I fixed my equations.
now using the first equation to find K. I used the following values:
E0 = 8.854x10-12
m = 1.66*10-27 (i think that's right for Hydrogen)
e = 1.602x10-19
h = 6.626x10-34
n = 1
Kn = (1/E02)(me4/8n2h2)
plug in the values and i get K = 1.28x1022 x 12.17
K = 1.55x1023
but that is wrong. where am i messing up? I only have one try at the answer left.
what is the correct mass of Hydrogen. I am using 1.66x10^-27. But when i do so and multiply it by e^4 i get 0. which makes everything 0 and this is incorrect.
K and U should be a lot smaller than 1 Joule; the answer should have 10 raised to a negative exponent. It may be that you divided where you should be multiplying, or vice-versa, when you put the numbers into your calculator.
I get 1.67 x 10^-27 kg, but that's a small difference and shouldn't really matter.
You could try separating the number from the exponent part, and do those calculations separately. For example:
(6 x 10^8) x (2 x 10^-19)^2 / (4 x 10^-4)
= [ 6 x 2^2 / 4 ] x 10^[8 - (19x2) + 4]
= 6 x 10^-26
That way, the extremely negative exponents won't turn your answer into 0.
Also, it's good practice to include the units in the calculations. This is one way to check that (1) the formulas are consistent and (2) you are multiplying or dividing the terms correctly.
Good luck!
i tried doing the exponents seperately:
for the me^4 part of equation
(1.67 x 10^-27) x (1.602 x 10^-19)^4
= [ 1.67 x 1.602^4 ] x 10^[-27- (19x4]
= 10.99 x 10^-103
that looks very wrong. and when i try to divide/multiply it by something i get an error in the calc's.
now what am i doing wrong?
another member of another forum suggested another equation:
Kn = 1/n2 * 13.588 eV
if i use this the n will be 1 therefore my Kn is 13.588...?
he also pointed out i am using the wrong mass. i am using mass of atom and i should be using the mass of electron.
well i am trying to work out the units only to make sure i have the equation right. but i am not ending with eV
E0 = C^2/N x m
m = kg
e = C
h = J x s (or N x m x s)
n = unitless
i get:
(1/m)(kg x C^2 / s)
i can't convert or cancell anything else out. this problem is driving me insane
Ah, yes, it should be the electron mass. Sorry I didn't catch that sooner.
If you can just use the 13.6 eV value (or 13.588 eV?) in the formula, that is certainly a lot easier.
I don't have time at the moment to check your units calculation, but note the units of εo are C^2 / (N m^2).
i found a new equation in the book.
K = 13.6 ev / n^2
U = -27.2 eV / n^2
E = K + U
i knew E = 13.6.
I finally got them all to work out without having to deal with the error's in the exponents.
now i solved part D and Part E.
thanks
What is a Hydrogen atom in the ground state?
A Hydrogen atom in the ground state refers to the lowest energy state of a Hydrogen atom, where the electron is in its lowest possible energy level around the nucleus.
How is the ground state of a Hydrogen atom determined?
The ground state of a Hydrogen atom is determined by solving the Schrödinger equation, which describes the wave function of the electron in the atom. The lowest energy level is found to be -13.6 electron volts.
What is the energy of a Hydrogen atom in the ground state?
The energy of a Hydrogen atom in the ground state is -13.6 electron volts. This is the lowest possible energy that the electron can have in the atom.
How does the ground state of a Hydrogen atom differ from its excited states?
The ground state of a Hydrogen atom has the lowest energy level, while excited states have higher energy levels. In the ground state, the electron is closest to the nucleus, while in excited states, the electron is further away.
Why is the ground state of a Hydrogen atom important in chemistry?
The ground state of a Hydrogen atom plays a crucial role in chemical reactions, as it determines the stability and reactivity of the atom. It also serves as a reference point for understanding the behavior of other atoms and molecules.
