Satellite orbit question: does mass affect this problem?
In summary, we can calculate the height of a synchronous satellite above the Earth's equator by using the equation r^3 = ( G*mearth*T^2 ) / (4*pi^2), where r is the radius, G is the universal gravitational constant, mearth is the mass of the Earth, and T is the period of one day. This results in a height of 35,920 km or 35,920,000 meters above the Earth's surface. While the mass of the satellite does contribute to the period of the orbit, it is negligible in this problem due to the large mass of the Earth.
N_L_
33
I think I have an answer for the following problem, but I'm not sure if it (or the assumptions used to get it) are correct:
Consider a 540 kg synchronous satellite in a circular orbit in the same plane as our equator. Find the height H of the satellite above the Earth's equator.
What I got:
msat - mass of satellite = 540 kg
mearth - mass of Earth = 5.98 x 10^24 kg
r = radius = distance between Earth's center and the satellite = r
G = 6.67 x 10^-11 (N m^2 / kg^2)
v = velocity of the satellite
a = acceleration for uniform circular motion
radius Earth = 6380 km
F = ma
a = v^2 / r
G (msat * mearth) / r^2 = msat ( v^2 / r )
v = (2*pi*r) / T
T = 1 day = 86,400 seconds
substituting...and cancelling msat on both sides
G (mearth / r^2 ) = (2*pi*r)^2 / (r T^2 )
Re-arranging...
r^3 = 7.54 x 10^22 meters cubed.
r = 4.23 X 10^7 meters or 42,300 km
total radius - Earth radius = height above the Earth's surface
42,300 km - 6,380 km = 35,920 km or 35,920,000 meters above the Earth's surface
Mass does not affect it.
I got the same answer as you. Google also has the same answer.
Thank you.
Since you did ask whether "mass affects this problem," you should know that the equations you set up assume that mass doesn't matter by taking the Earth to be stationary. If you were to do the problem a little more carefully, the Earth and the satellite would revolve about their center of mass.
You would then find that the mass appearing in the equation you wrote for the period would contain the combined mass of the Earth and satellite (instead of just the Earth's mass) so then, yes, the mass of the satellite contributes to the period.
Of course, for the problem at hand, the mass of the satellite is so small compared with the mass of the Earth that the difference it makes in calculating the geosynchronous radius is entirely negligible.
1. How does an object's mass affect its orbit around a satellite?
The mass of an object does not affect its orbit around a satellite. The orbit of an object around a satellite is determined by the gravitational pull of the satellite, which is not influenced by the mass of the object.
2. Does the mass of a satellite affect its orbit around Earth?
Yes, the mass of a satellite does affect its orbit around Earth. A larger satellite will have a stronger gravitational pull and may have a different orbit than a smaller satellite.
3. Can the mass of a planet affect the orbit of a satellite around it?
Yes, the mass of a planet can affect the orbit of a satellite around it. The larger the planet's mass, the stronger its gravitational pull, which can alter the orbit of the satellite.
4. How does the mass of the satellite itself affect its orbit?
The mass of the satellite itself does not significantly affect its orbit. The orbit of a satellite is primarily determined by the satellite's distance from the object it is orbiting and the object's mass.
5. Is there a specific mass range for objects to orbit a satellite?
No, there is not a specific mass range for objects to orbit a satellite. Any object can orbit a satellite as long as it is within the satellite's gravitational pull and has enough velocity to maintain its orbit.
