Prove (0,1)=(0,1] - Showing f is 1-1
  • Thread starter kathrynag
In summary, the student is trying to prove that f is a 1-1 function from (0,1) into (0,1]. They need to prove that (0,1)=[0,1] and then evaluate what f(a) and f(a') is to prove that [0,1]=(0,1). They are also trying to prove that f is a function from (0,1) onto (0,1]. They need to prove that f is a bijection between (0,1) and (0,1) and then use that to prove that f(a) and f(a') are the same.
  • #36
HallsofIvy said:
That's the hard way to do it! And, as I said before, what you are doing, looking at numbers of the form 1/n, is of no use because the integers are countable and none of these sets are countable.
As I said a long time ago, to define a one-to-one, onto function from [0,1] to (0,1)define f(x)= x for x any irrational number between 0 and 1, write all rational numbers in (0,1) in a list, r1, r2, etc. then define f(0)= r1, f(1)= r2, f(rn)= rn+2.
The hard way to do it is the way I was told to do it with proving [0,1) is equivalent to (0,1].
  • #37
kathrynag already stated a bijection between (0, 1) and (0, 1] in the very first post of this thread. (It doesn't take too much effort from that to conclude there is a bijection between (0, 1) and [0, 1].) Her problem is showing that it is one-to-one and onto.
I suggest practicing showing that simpler functions are bijections, such as f : R -> R defined by f(x) = 5 - x^3, so that you understand the form of the proof.
  • #38
f(a)=5-a^3
f(b)-5-b^3
5-x^3=5-b^3
a^3=b^3
a=b
Thus 1-1
y=5-x^3
-y+5=x^3
x=(-y+5)^1/3
x includes all real numbers. Thus onto.
Then how do i work around proving [0,1) is equivalent to (0,1]?
Like I thought about using f(x)=1-x because f(0)=1 and f(1)=0 but then that would be a mpping and that's not quite right.
  • #39
Ok could I still use C=[0,1]
Then A=C-x element of C
B=C
but B=C-null set
null set is an element of C
so A=C- some elemnt of C=B?
  • #40
Ok I know [0,1) is equivalent to (0,1] by f(x)=1-x
Now I'm having trouble finding a similar function for (0,1) equivalent to [0,1]
  • #41
Ok, I found something else. 2 sets A and B are equivalent iff there is a 1-1 function from A onto B.
  • #42
After reading this topic, I am completely speechless.
  • #43
This would make a lot more sense to us if equivalent is replaced with cardinally equivalent.
kathrynag said:
f(a)=5-a^3
f(b)-5-b^3
5-x^3=5-b^3
a^3=b^3
a=b
Thus 1-1
y=5-x^3
-y+5=x^3
x=(-y+5)^1/3
That is right, so use this method to show that the function you stated in your first post is a bijection between (0, 1) and (0, 1]. The proof will be longer because that function is case-defined.
You already have f(x) = 1 - x, a bijection between [0, 1) and (0, 1], which is easier to show.
If you also have a bijection between [0, 1) and [0, 1], then that implies (0, 1) and [0, 1] are cardinally equivalent. If you want a single bijection between (0, 1) and [0, 1], think about how you can "combine" the 3 functions.
  • #44
Well, the book says nothing about cardinally equivalence, so i would assume my professor would not expect me to use that term.
Ok, so (0,1) and (0,1]
For f(x)=x, we get 0 and 1
For f(1/n)=1/(n-1), we get {1/1/2,1/1,1/4...}
Thus, (0,1]
[0, 1) and [0, 1]
For this I use {0}U(0,1) because I already know (0,1) is a bijection to (0,1]. Thus we have a bijection to [0,1].
Ok, for (0,1) equivalent to [0,1].
Let f(x)=x for all elemnt not of the form 1/n
Then we get the points (0,1)
Thne for all other points let f(x)={0}U 1/(n-1)
  • #45
Thus, (0,1]
You don't get 1 from f(x) = x.
Also, what about all other points not in {0, 1, 1/2, 1/3, 1/4, ...}?
[0, 1) and [0, 1]
Right idea, but you need to say it precisely because [tex]\{0\} \cup (0, 1) \ne (0, 1][/tex]. Do you mean given a bijection [tex]f : (0, 1) \rightarrow (0, 1][/tex], define [tex]g : [0, 1) \rightarrow [0, 1][/tex] by g(0) = 0, and g(x) = f(x) for [tex]x \in (0, 1)[/tex]?
This is not an element of [tex]\mathbb{R}[/tex].
  • #46
Yeah, but from f(x)=x I get all points not of the form 1/n.
All other points not in {0,1,1/2,1/3,1/4...} are in f(x)=x
Yeah, i guess setting g(0)=0 and g(x)=f(x) would work.
So then let f:(0,1)-->(0,1] and let g:(0,1)-->[0,1]
Let f(x)=g(x) for all x in (0,1) and let g(1)=0?
  • #47
Close. 0 is not in the range of f. I mentioned 0 only because you mentioned 0.
g(1) cannot be defined because the domain of g is (0, 1).
  • #48
Ok, 0 is not even in f.
Is this part correct? I know there needs to be some number to equal 0 right?
Let g(x)=f(x)=?
  • #49
If If f:(0,1)-->(0,1] then there is NO "x" left over to give f(x)= 0. That's the whole point.
  • #50
Ok I understand that.
  • #51
Let g(x)=f(x)=?
Is that the right idea or not?
I just am unsure of what x value to plug into g(x)=0
  • #52
Ok, I'm going to lay out what I've done thus far.
proving f is a 1-1 function from (0,1) into (0,1].
Let a=1/m b=1/n
f(a)=1/(m-1) f(b)=1/(n-1)
f(a)=f(b)
m=n
1/m=1/n
a=b
f(a)=a f(b)=b
f(a)=f(b)
a=b
proving f is a function from (0,1) onto (0,1]:
To prove f:A-->B is onto, let B be arbitrary and show there exists a in A such that f(a)=b. I need to show that I am f=B.
y=1/(n-1)
n=1/(y-1)
y-1=1/n
f inverse=1/n+1
f inverse =(1+n)/n
f inverse of b=(1+b)/b=a
f(a)=1/[(1+b)/b-1]=1/1/b=b
y=x
x=y
f inverse=x
f inverse (b)=b=a
f(a)=a=b
Finding a 1-1 function from [0,1) onto [0,1]
[0, 1) and [0, 1]
given a bijection f:(0,1)-->(0,1] , define g:[0,1)-->[0,1] by g(0) =0, and g(x) = f(x) for x in (0,1)
Proving [0,1) is equivalent to (0,1]:
Use the function f(x)=1-x
Proving (0,1) is equivalent to [0,1]:
right?
Let g(x)=f(x)=?
  • #53
Ok, do I use a composition?
Let f:(0,1)-->(0,1]
Let g:=[0,1)-->[0,1]
Let g(x)=1-x
Then h(x)=g(f(x))
  • #54
Ok then I would also need to define g(0) as 0 right because we get:
h(x)=g([0,1]).
No never mind because I should be doing
h(x)=f(g(x)
=f([0,1]
f(0)=1 and f(1)=0
Please let me know if this is right!
  • #55
Also f(x)=1-x
and g:[0,1)-->[0,1]
  • #56
Ok it's all figured out. They key was letting [0,1) was f(x)=x in (0,1) and f(0)=1. Then I just used transitivity.
