Under what conditions will quantum effects become important for gravity?
In summary, the question of quantum gravity effects is a complex one that involves both experimental and theoretical considerations. Some areas to explore for observable quantum gravity effects include semiclassical gravity, black holes, the cosmic microwave background, and gravitational waves. However, these effects may only become noticeable at extremely small scales or in extreme cosmic situations.
graeme87
I have to write a short essay answering this question (1st year university level). I am finding it very hard to get any decent info on the net at all. If someone could help me out with this I would be very appreciative. Thanks.
Regards
Graeme
Look up something called the Planck length (also Planck mass, Planck energy, etc.). These give limits on when quantum gravity effects almost certainly appear. They may in fact be significant under much more mundane conditions, but nobody knows.
thanks, i'l look it up. also what about black holes? the normal rules of physics are thrown out the window when it comes to black holes, would quantum gravity play a part here?
A priori yes, specialy for mini-black holes. Some theories concerning the quantum gravity are of course trying to describe black holes (Lorentz one euclidian one,...). But I think it is not a first year level.
Regards
Graeme
Gravity effects manifests itself at the Quantum level, when the Energy Density, Charge Density, no longer transfer Photons from a 4-D spacetime.
Non-Relativistic Gravity is Dimension dependant.
The singularity inside of a black hole would be affected by quantum gravity, but the vast majority of a (macroscopic) black hole's properties are described perfectly well by classical GR.
Another popular place to look is at the very early universe.
The WIMPs (weakly interacting massive particles) that have been proposed to explain dark matter might exhibit quantum effects in a gravitational potential well.
No more than anything else in the universe.
You bring up a good point, though. I've been talking about quantum effects on gravity itself. There are, however, many situations where gravity can be treated classically, but where it is still strong enough to significantly modify quantum mechanical processes.
These are two very different things. The latter one is much better understood, and less out of experimental reach (although less is a relative term!) than full blown quantum gravity. Hawking radiation from black holes would be an example of this. So would the Unruh effect.
I think that there's something conspicuously missing in this discussion so far here. Quantum effect of gravity HAS been observed!
<shock spreads through>
Note that in the Schrodinger equation, the "V" term for the potential can be ANYTHING. I could write the gravitational potential in there and no one can fault me. So how can I do that and observe "quantum effects" due to the gravitational potential? By applying it in situation with the suitable boundary conditions that can quantize the gravitational fall! This has been done.
The cold neutron drop experiment of a couple of years ago showed that there are discrete gravitational states.[1] I'd say that this qualifies at quantum effects of gravity. It may not be the exotic quantum gravity that everyone is enamoured with, but I'd buy it.
Zz.
[1] V.V Nesvizhevsky et al., Nature v.415, p.297 (2002).
Yes Zz. But I think it's pretty much always implied in these kinds of threads that what's of interest is something linking quantum mechanics and the uniquely-GR aspects of gravity.
That's probably true. But if you go by JUST the title that was given, that isn't automatic. Plus, he has to write an ESSAY. So it means there is more of a larger freedom to explore the subject. I'd say that if I were the instructor and a student wrote on the neutron drop experiment, it would be a delightful surprise since it fits the topic. Not only that, it showed that the student did some homework and didn't go for the easy and obvious approach.
Zz.
Regards
Graeme
Really, the way the question is phrased, the answer is really something like:
In experimental physics, gravitational effects become important in quantum mechanics when they are necessary in order to predict experimental results, that is, when there are experiments that can verify gravity on a quantum scale; in theoretical physics quantum gravitational effects are important whenever some researcher turns his or her mind to them.
In your paper, try to identify conditions where quantum-scale effects of gravity would be noticable.
This is a good question. The first place you want to look at is semiclassical gravity. All other QG things tend to shoot the scale lower (but not always)
Namely take the Einstein Hilbert action, and quantize it.
Quantum effects should show up as first order loop diagrams, scaled by Newtons coupling constant (G).
It turns out, its about 6 orders of magnitude above the Planck scale or so where you might start to get significant experimental departure from tree level. Where would you measure such a thing?
Well black holes would probably be a good point, but also you might expect to see signatures in the cosmic microwave background. Small anisotropies that are diluted in inflation but still in principle experimentally visible. You might also see it in a variety of other cosmic situations.. Gravitational waves in quantum like objects (neutron stars, but especially some of the exotic hybrids thereof), and possibly cosmic strings.
I could give you references, but perhaps its not quite suitable for a 1st year student.
Alledged WIMPs would exhibit gravitational effects in their quantum behavior much more than ordinary matter because they are unaffected by electromagnetism and nuclear forces. For example, if there is any condensed phase of WIMPs we can observe somewhere in the universe, its spectrum (in gravity waves) would have absorption/emission lines determined by the quantum structure of "wimpium", analogous to the photon spectrum lines for normal matter.
This is more along the lines of what Zz mentioned. Let me add that gravitationally induced (phase) changes to the wavefunction of a neutron beam have been experimentally observed over a quarter of a century ago.
The first, I believe, was the 1975 neutron interference experiment by R. Colella, A. Overhauser and S. Werner [1].
Let me add that the OP's question is terribly worded. What does it mean for something to be important for gravity ? The "gravity" of a neutron star, for instance, is a function of its mass distribution, which may not be explained satisfactorily without QM. But then, should the OP be instead talking about QG rather than the application of QM to specific aspects of a problem ?
[1]"Observation of Gravitationally Induced Quantum Interference," R. Colella, A. W. Overhauser and S.A. Werner, Phys. Rev. Lett. 34, 1472-1474 (1975).
Ok, I suppose that might be true. I'd just never heard of anyone talking about condensd WIMPs before (or observing gravitational spectra!). But I guess those things aren't any more 'out of reach' than the examples I gave.
Hey, even cold neutrons do !
At my place, people look into these experiments:
http://www.esrf.fr/cgi-bin/cgi-bin-bib/illexperte?auteur=&titre=gravity&journal=&bibinf=&date=&instrument=&formule=&subject=&sort=1&LIG=10&CRITERE=1&CKD=2
cheers,
Patrick
cheers,
Patrick
Er... isn't that the cold neutron experiment that I had already cited somewhere in this thread, vanesch?
Zz.
1. What is quantum gravity and why is it important?
Quantum gravity is a theoretical framework that aims to unify the theories of quantum mechanics and general relativity to explain the behavior of gravity at a microscopic scale. It is important because it could help us understand the fundamental nature of the universe and potentially solve some of the biggest mysteries in physics, such as the origin of the universe and the nature of black holes.
2. How are quantum effects related to gravity?
Quantum effects are related to gravity through the concept of quantum fluctuations, which are small, random fluctuations in the fabric of spacetime. These fluctuations can affect the behavior of gravity at a microscopic level, potentially leading to new phenomena and insights into the nature of gravity.
3. Under what conditions do quantum effects become important for gravity?
Quantum effects become important for gravity at extremely small scales, such as the Planck length (10^-35 meters) or the Planck time (10^-43 seconds). At these scales, the effects of quantum mechanics cannot be ignored and must be taken into account in any unified theory of quantum gravity.
4. Can we observe quantum effects in gravity?
At present, we do not have the technology or experimental methods to directly observe quantum effects in gravity. However, there are ongoing efforts to detect and measure these effects indirectly, such as through gravitational wave observations and experiments with quantum systems.
5. How close are we to understanding quantum gravity?
While progress has been made in developing various theories of quantum gravity, such as string theory and loop quantum gravity, a complete understanding of quantum gravity is still elusive. It is considered one of the biggest challenges in modern physics, and more research and experimentation is needed to unravel its mysteries.
  • Quantum Physics
13K
  • Quantum Physics
  • Quantum Physics
