3 point Flexure/bending test for ductile materials question
In summary, the article discusses the stress distribution and load-deflection curves of brittle and ductile materials during bend testing. It explains that ductile materials do not show a linear relationship between load and deflection before failure, making it difficult to determine the yield point and obtain a valid stress-strain curve. Therefore, bend testing is more suitable for testing brittle materials with linear elastic behavior. Additionally, the conversation also touches on the use of stress-strain curves for different types of loading and provides a resource for further explanation.
Marchese_alex
54
I was looking up info on this topic and came up with this article (http://eng.sut.ac.th/metal/images/stories/pdf/Lab_7Bend_Eng.pdf)... what I don't get is why it says that bending test for ductile materials isn't good.
"The stress is essentially zero at the neutral axis N-N. Stresses in the y-axis in the positive direction represent tensile stresses whereas stresses in the negative direction represent compressive stresses. Within the elastic range, brittle materials show a linear relationship of load and deflection where yielding occurs on a thin layer of the specimen surface at the midspan. This in turn leads to crack initiation which finally proceeds to specimen failure. Ductile materials however provide load-deflection curves which deviate from a linear relationship before failure takes place as opposed to those of brittle materials previously mentioned. Furthermore, it is also difficult to determine the beginning of yielding in this case. The stress distribution of a ductile material after yielding is given in figure 3 b). Therefore, it can be seen that bend testing is not suitable for ductile materials due to difficulties in determining the yield point of the materials under bending and the obtained stress-strain curve in the elastic region may not be linear. The results obtained might not be validated. As a result, the bend test is therefore more appropriate for testing of brittle materials whose stress-strain curves show its linear elastic behaviour just before the materials fail."
Does the stress strain curve(http://dolbow.cee.duke.edu/TENSILE/tutorial/node4.html ) only applies when is in tension? <--------- is this correct?
can anyone explain it to me in more simple way
You can do a stress/strain or load/displacement graph for tension, compression or torsion. For a number of reasons, compression can be difficult to measure. Fig 3b is not clear or incomplete. Try this link http://www.bestinnovativesource.com/2012/12/29/plastic-bending-of-rectangular-sectioned-beams/ for an explanation of the gradual development of a plastic hinge as load increases in the yield zone. An 'ideal' elastic plastic stress strain curve might be bi-linear looking like a knee when sitting down, but in bending, because of the stress redistribution described in the above link (and poorly represented in fig 3b), the stress strain curve in bending will look like a real knee, rounded and short-cutting the sharp change from linear elastic to linear plastic.
What is a 3 point flexure/bending test for ductile materials?
A 3 point flexure/bending test is a mechanical test used to determine the strength and ductility of a material by subjecting it to bending forces. In this test, a sample of the material is placed on two supports and a load is applied at the center of the sample, causing it to bend. The resulting deflection and stress are measured to determine the material's strength and ductility.
Why is the 3 point flexure/bending test important for ductile materials?
The 3 point flexure/bending test is important for ductile materials because it can provide valuable information about the material's ability to withstand bending forces without breaking. This is particularly important for materials that are used in structures or applications where they may be subjected to bending forces, such as bridges, beams, and pipes.
How is the 3 point flexure/bending test performed?
In a 3 point flexure/bending test, the sample is placed on two supports and a load is applied at the center of the sample using a mechanical or hydraulic testing machine. The load is gradually increased until the sample reaches its breaking point or a specified amount of deflection. The resulting deflection and stress are recorded and used to calculate the material's strength and ductility.
What are the advantages of using the 3 point flexure/bending test?
One advantage of the 3 point flexure/bending test is that it is relatively simple and inexpensive to perform compared to other mechanical tests. It also provides information about both the strength and ductility of a material, making it a valuable tool for material characterization. Additionally, the test can be performed on a wide range of materials, including metals, plastics, and composites.
What factors can affect the results of a 3 point flexure/bending test?
The results of a 3 point flexure/bending test can be affected by various factors, such as the geometry and size of the sample, the speed at which the load is applied, and the temperature and humidity of the testing environment. It is important to carefully control these factors to obtain accurate and reliable results.
  • Materials and Chemical Engineering
  • Mechanical Engineering
9K
