Do Fourier transforms always converge to 0 at the extreme ends?
In summary, the Fourier transform of a periodic function will not always converge to zero at the extreme ends, but will converge if it satisfies the Dirichlet conditions.
nabeel17
57
From -infinity to infinity at the extreme ends do Fourier transforms always converge to 0? I know in the case of signals, you can never have an infinite signal so it does go to 0, but speaking in general if you are taking the Fourier transform of f(x)
If you do integration by parts, you get a term (f(x)e^ikx evaluated from -infinity to infinity why does this always = 0?
Likes kq6up
No, not always. If a signal is periodic in one domain then it is discrete in the other domain. So if you have a signal which is discrete in time, then it is periodic in frequency. Since it is periodic in frequency it does not converge to 0 at infinity.
Ok then why is it that we the first term in the integration by parts goes to 0 then regardless of the function (Whether it is periodic or not)? For example when finding the Fourier transform of a derivative F[d/dx] = ∫d/dxf(x)e^ikx= f(x)e^ikx evaluated -infinity to infinity -ik∫f(x)e^ikx
the first term = 0, why is that? If it were a wave function like in QM then it makes sense because the area under the wave function must be finite and converge to 0 at the extremes for it to have a probability density, but why here?
I think that the various properties of the Fourier transform all assume that f satisfies the Dirichlet conditions.
The OP is asking about Fourier transforms, not Fourier series (of periodic functions) which is what #2 and #4 appear to be about.
A reasonable condition for Fourier transforms to behave sensibly is that ##\int_{-\infty}^{+\infty}|f(x)|dx## is finite. Note that if you use Lebesque measure to define integration, that does not imply ##f(x)## converges to 0 as x tends to infinity. ##f(x)## can take any values on a set of measure zero.
(Also note, "reasonable" does not necessarily mean either "necessary" or "sufficient"!)
The mathematical correspondence between Fourier series and Fourier transforms is not quite "obvious", since the Fourier transform of a periodic function (defined by an integral with an infinite range) involves Dirac delta functions, and indeed the Fourier transform of a periodic function is identically zero except on a set of measure zero (i.e. the points usually called the "Fourier coefficients").
On the other hand if you integrate over one period of a periodic function, it is a lot simpler to get to some practical results, even if you have to skate over why the math "really" works out that way.
Likes 1 person
1. What is the Fourier Transform Convergence?
The Fourier Transform Convergence is a mathematical concept that describes the convergence of a series of functions to a continuous function, known as the Fourier series. It is used in signal processing, image analysis, and other fields to decompose a complex function into simpler components.
2. How is the Fourier Transform Convergence used in science?
The Fourier Transform Convergence is used in many areas of science, including physics, engineering, and mathematics. It is particularly useful in analyzing periodic signals and images, and in solving differential equations. It also has applications in quantum mechanics and computer graphics.
3. What is the difference between the Fourier Transform and the Fourier Series?
The Fourier Transform and the Fourier Series are closely related, but have different applications. The Fourier Transform is used to transform a function from the time or spatial domain to the frequency domain, while the Fourier Series is used to represent a function as a sum of sine and cosine functions. The Fourier Series is a special case of the Fourier Transform, where the function is periodic.
4. What are the conditions for the convergence of the Fourier Transform?
The Fourier Transform Convergence requires that the function being transformed is absolutely integrable, meaning that its integral over the entire domain is finite. It also requires that the function is continuous and has a finite number of discontinuities, which are called singularities in mathematical terms.
5. Can the Fourier Transform Convergence fail?
Yes, the Fourier Transform Convergence can fail in certain cases. One example is when the function being transformed has an infinite number of discontinuities, such as a sawtooth wave. In these cases, the Fourier Transform may still converge, but not in the traditional sense. Additionally, the Fourier Transform may fail to converge if the function is not absolutely integrable or if it has an infinite number of oscillations.
  • Differential Equations
  • Other Physics Topics
