Why Does 0 Velocity and Negative Acceleration = Increasing Speed?
In summary, when dealing with speed and acceleration, it is important to understand the difference between the informal, non-directional concept of acceleration/deceleration and the direction-specific concept of positive and negative acceleration. In the case of negative acceleration, the speed may still increase, as seen in the example of a ball fired upwards in a gravitational field. This is because speed is a scalar quantity and does not take into account direction, while acceleration is direction-specific.
Love_to_Learn
None
I am using Halliday and Resnick (5th Edition), and the anwer key in the back says that speed is increasing at the point when velocity is zero, and acceleration is negative.
I am assuming I am wrong and the book is right. I just can't understand it though. If the rate of change of the position function is not changing, and the acceleration is decreasing, then doesn't that mean that the particle is going in a straight line and is slowing down?
Speed is a scalar quantity so it doesn't matter whether you are going forwards or backwards. If you slow down you have negative acceleration; if you keep that negative acceleration after you stop, you then start to go backwards.
At the point you came to rest, you still had negative acceleration, zero velocity and zero speed. You then gained some negative velocity but your speed increased. (It's just a number)
You have to be careful of the terminology. A "decreasing acceleration" mean a decreasing in magnitude acceleration while a "negative acceleration" simply means an acceleration in the negative direction. As for your problem, imagine a ball fired straight upwards in a gravitational field. It is always undergoing a constant negative acceleration. At the peak, however, the velocity and thus, speed, reaches 0. Now, at this point, the velocity is going to become negative but the speed, which is simply the magnitude, is going to increase.
That's what I've been needing to begin to cement this concept! Thank you for your very precise use of language.
Hi. Love_to_Learn!
You will find out that the word "acceleration" is used in two rather different ways:
1. The acceleration/deceleration-concept couple:
This is the informal, colloquial way of saying the speed increases (acceleration), or the speed decreases (deceleration).
This is NOT "directionally specific", since "speed" is a quantity without direction
Note that the word "deceleration" is ONLY used in this context
2. Direction-specific acceleration:
Here, some direction is implied (say, for example, left vs. right, up vs down, or radially outwards vs radially inwards)
One of the anti-parallell directions is thought of as "positive", the other as "negative", giving rise to "positive acceleration" vs. "negative acceleration"
An often-met case is the couple centrifugal acceleration vs centripetal acceleration, where in "centrifugal acceleration" the positive direction is radially outwards, whereas the opposite is true for "centripetal acceleration".
1. Why does having 0 velocity result in increasing speed with negative acceleration?
When an object has 0 velocity, it means that it is not moving at all. However, if there is a negative acceleration acting on the object, it means that the object is slowing down in the direction of its motion. This results in the object gaining speed in the opposite direction, causing its velocity to increase.
2. How does negative acceleration affect an object's speed?
Negative acceleration, also known as deceleration, causes an object's speed to decrease. This is because the acceleration is acting in the opposite direction of the object's motion, slowing it down.
3. Can an object have a negative velocity and increasing speed?
Yes, an object can have a negative velocity and increasing speed if it is experiencing negative acceleration. In this case, the object's velocity is decreasing in the direction of its motion, but its speed is increasing in the opposite direction.
4. What is the relationship between velocity, acceleration, and speed?
Velocity is the rate of change of an object's position in a particular direction. Acceleration is the rate of change of an object's velocity. Speed is the rate at which an object is moving. When an object has a constant velocity, it means that its speed and direction of motion are not changing. However, if there is a non-zero acceleration, the object's velocity will change, resulting in a change in speed as well.
5. How does negative acceleration differ from positive acceleration?
Negative acceleration, or deceleration, is when an object's velocity decreases over time. This can be caused by a force acting in the opposite direction of the object's motion. Positive acceleration, on the other hand, is when an object's velocity increases over time, usually due to a force acting in the same direction as the object's motion.
