Triethylene glycol + Dichlorotriethylene glycol
  • Thread starter ccl4
In summary, Triethylene glycol has the chemical formula C6H14O4 and Dichlorotriethylene glycol has the chemical formula C4H4Cl2O2. They are both colorless liquids with different properties such as solubility in water and odor. Triethylene glycol is commonly used in various industries, while Dichlorotriethylene glycol is primarily used in organic synthesis. Both chemicals can cause health hazards and are not found naturally in the environment.
ccl4
what is the product of this reaction which is catalyzed by KOH?
For starters, what the hell is "Dichlorotriethylene glycol"? If it looks like http://www.dfmg.com.tw/member/chemical/cas/112-27-6.htm molecule, there are at least 6 different places you could have a chlorine. A combination of 2 chlorines at 6 possibles place would mean something like (6*5)/(2*1) = 15 different molecules with that generic name.
actually i just wanted known the product from the reation of Triethylene glycol and KOH.
It sounds like you are studying the Williamson Ether Synthesis.
1. What is the chemical formula for Triethylene glycol + Dichlorotriethylene glycol?
The chemical formula for Triethylene glycol is C6H14O4 and the chemical formula for Dichlorotriethylene glycol is C4H4Cl2O2.
2. What are the properties of Triethylene glycol + Dichlorotriethylene glycol?
Triethylene glycol is a colorless, odorless liquid with a sweet taste. It is soluble in water and is hygroscopic, meaning it can absorb moisture from the air. Dichlorotriethylene glycol is also a colorless liquid, but has a pungent odor. It is also soluble in water and is highly reactive with other substances.
3. What are the uses of Triethylene glycol + Dichlorotriethylene glycol?
Triethylene glycol is commonly used as a solvent, humectant, and plasticizer in various industries such as pharmaceuticals, cosmetics, and plastics. Dichlorotriethylene glycol is primarily used as a reagent in organic synthesis and as a solvent for dyes and resins.
4. Are there any health hazards associated with handling Triethylene glycol + Dichlorotriethylene glycol?
Both Triethylene glycol and Dichlorotriethylene glycol can cause skin and eye irritation upon direct contact. Inhalation of high concentrations of these chemicals can also lead to respiratory irritation and other health effects. It is important to handle these chemicals with proper safety precautions and to follow all recommended handling procedures and protocols.
5. Can Triethylene glycol + Dichlorotriethylene glycol be found naturally in the environment?
No, these chemicals are not found naturally in the environment. They are synthetically produced and are not commonly found in nature.
  • Materials and Chemical Engineering
  • Chemistry
