A problem on time taken by relativistic particles
In summary, we discussed the speed of a proton with a relativistic γ factor of 10^10, the distance and time between a proton and photon as seen by an observer at one end of the galaxy, and the time taken for the proton to cross the galaxy as seen by two different observers at rest relative to each other. We used Lorenz transformation equations and approximations to find the times for the particles to pass by each observer. The time taken for the proton to cross the galaxy was approximately 10^5 years for both observers.
visharad
54
a) What is the speed of proton that has relativistic γ factor of 10^10? Write as (1-ε)c
b) A proton with γ=10^10 is chased by a photon across a galaxy. Observer A at one end of the galaxy (xA=0) sees the proton at t1=0 and the photon at t2 = 1.33 x 10^-8 s. According to A, how far apart are the two particles at t1?
c) Another observer B is at another end of the galaxy (xB=10^21 m). The two observers are at rest relative to each other. At what times will B see the particles go past?
d) How many years does it take the proton to cross the galaxy according to A and B?
L = Lo [itex]\sqrt{1 - v^2/c^2}[/itex]
Δt = Δto/[itex]\sqrt{1 - v^2/c^2}[/itex]
a) Y = 1/[itex]\sqrt{1 - v^2/c^2}[/itex]
1 - v^2/c^2 = 1/Y^2
v^2/c^2 = 1 - 1/Y^2
v^2/c^2 = 1 - 1/(10^10)^2
v^2/c^2 = 1- 1/10^20
v/c = sqrt(1 - 1/10^20)
v/c = (1 - 5 * 10^-21)
v = (1 - 5*10^-21) c
Is this correct?
b) The photon covers the distance in t2 - t1 = 1.33 x 10^-8 s
The distance = c t^2
= 3 x 10^8 x 1.33 x 10^-8
= 3.99 m
Is this correct?
c) Can we say that the observer B will see the proton pass by at t3 = t1 + xB/v and the photon pass by at t4 = t2 + xB/c ?
If not, then what is the correct method?
d) Can we simply divide distance (which is 10^21 m) by speed and convert into years? If not, then what is the correct method?
For c and d, I am not sure if we need to use Lorenz transformation equations. The observers are at rest relative to each other. So I think we do not need.
For part c, is it possible to express the answers as combination of a large number and a small number? I want to express t3 and t4 in such a way that it is easy to see the difference between them.
Please see if this is correct
c) t3 = time at which observer B sees the proton fly by
t4 = time at which observer B sees the photon fly by
t3 = t1 + 10^21/(1-ϵ)c
t3 = 3.33 * 10^12/(1-ϵ)
t3 = 3.33 * 10^12[1 + 1/(1-ϵ) - 1]
t3 = 3.33 * 10^12[1 + ϵ/(1-ϵ)]
Since ϵ << 1, therefore using the approximation 1-ϵ = 1, we get
t3 = 3.33 * 10^12(1 + ϵ)
t3 = 3.33 * 10^12(1 + 5*10^-21)
t3 = 3.33 * 10^12 + 1.67 * 10^-8 s
t4 = t2 + 10^21/c
t4 = 1.33 * 10^-8 + 3.33 * 10^12
t4 = 3.33 * 10^12 + 1.33 * 10^-8 s
d) For both observers, the time taken by the cosmic ray is approximately 3.33 * 10^12 s
= 10^5 years
1. What is the concept of time dilation in relation to relativistic particles?
The concept of time dilation refers to the phenomenon in which time appears to pass slower for objects moving at high speeds compared to objects at rest. This is a fundamental principle of Einstein's theory of relativity and is a key factor in understanding the behavior of relativistic particles.
2. How does the speed of a particle affect its perception of time?
The speed of a particle is directly related to its perception of time. As a particle approaches the speed of light, time will appear to pass slower for that particle. At the speed of light, time will appear to stand still for the particle. This is due to the effects of time dilation.
3. Can time dilation be observed in everyday life?
While time dilation is a well-established concept in physics, it is not directly observable in everyday life. This is because the effects of time dilation are only significant at extremely high speeds, such as those reached by particles in particle accelerators or in space travel.
4. What is the equation for calculating time dilation in relativistic particles?
The equation for time dilation is t = t0/√(1-v2/c2), where t is the time observed by the moving particle, t0 is the time observed by a stationary observer, v is the velocity of the particle, and c is the speed of light.
5. How does time dilation affect the aging of relativistic particles?
Due to the effects of time dilation, particles moving at high speeds will appear to age slower compared to particles at rest. This is why particles in particle accelerators can travel for years and only experience a fraction of a second of aging. However, this effect is only significant for particles traveling at extremely high speeds, and is not noticeable in everyday life.
