Why is zone 1 in liver more prone to ischemic injury?
  • Thread starter sameeralord
In summary: Liver, Portal System, and Periportal ZoneIn summary, zone 1 is more prone to injury because it is the periportal zone and has less oxygen.
sameeralord
662
Hi,
Is it because around central vein, there is only deoxygenated blood from the vein where as in the periphery there is hepatic artery. Also why does eclampsia cause zone 1 necrosis. Thanks :)
Biology news on Phys.org
sameeralord said:
Hi,
Zone 1 is the periportal zone. Although a vein, the portal vein supplies about half the liver's oxygenation in the normal situation, but this is reduced in cirrhosis. The hepatic artery normally supplies the other half. Zone 1 is more prone to toxic and viral injury (hepatitis). Zone 3 is normally the least oxygenated of the hepatic zones and the most prone to ischemic injury.
http://www.ncbi.nlm.nih.gov/pubmed/8455423
http://www.google.com/search?q=hepa...11%2F01%2Fanatomy-hepatic-veins.html;1078;851
EDIT: Look up the roles of the portal circulation and of the hepatic central veins.
Likes 1 person
double check here, the portal vein shouldn't have any oxygen you mean nutrients right from the GI.
to the original question, ecclampsia is a vascular damage, so yeah the logic stands
Hepatic portal vein blood does not have as high an oxygen content per unit volume as arterial blood, but it does in fact supply half the oxygen demand of the liver in the normal situation. This is reduced with cirrhosis. Because it transports a large volume of blood, the portal system can normally meet its share of the liver's oxygen requirements. Venous blood is not totally deoxygenated. Did you do any research before you posted? Did you read the link in the post you quoted?
http://en.wikipedia.org/wiki/Liver see Blood Flow
The reason why zone 1 in the liver is more prone to ischemic injury is due to its location and blood supply. Zone 1 is located around the central vein, which receives deoxygenated blood from the hepatic artery and portal vein. This area is more sensitive to ischemia (lack of oxygen) because it is the furthest from the main source of oxygenated blood, the hepatic artery. This makes it more susceptible to damage when there is a decrease in blood flow or oxygen supply, such as in cases of shock or low blood pressure.
Eclampsia, a condition that occurs during pregnancy, can also cause zone 1 necrosis. This is because eclampsia is associated with high blood pressure and decreased blood flow to the liver, particularly in the central vein area. This decreased blood flow can lead to ischemia and damage to the cells in zone 1, resulting in necrosis (cell death).
In summary, the location and blood supply of zone 1 in the liver make it more vulnerable to ischemic injury, which can be caused by various factors such as shock or eclampsia.
Related to Why is zone 1 in liver more prone to ischemic injury?
1. Why is zone 1 in liver more prone to ischemic injury?
Zone 1 in the liver is more prone to ischemic injury because it is the area closest to the oxygen-rich blood supply from the hepatic artery. This makes it more susceptible to the effects of reduced blood flow and oxygen deprivation during ischemia.
2. What factors contribute to the vulnerability of zone 1 to ischemic injury?
The unique vascular anatomy of zone 1, with its high blood flow and oxygen demand, along with its location near the hepatic artery, makes it vulnerable to ischemic injury. Additionally, zone 1 is responsible for detoxifying the majority of drugs and toxins, which can also contribute to its susceptibility to ischemia.
3. How does ischemia affect zone 1 of the liver?
Ischemia can lead to cellular damage and death in zone 1 of the liver due to the lack of oxygen and nutrients. This can result in impaired liver function and potential liver failure.
4. What are the consequences of ischemic injury in zone 1 of the liver?
The consequences of ischemic injury in zone 1 of the liver can range from mild liver dysfunction to severe liver failure. This can impact the body's ability to detoxify and metabolize drugs, produce important proteins and hormones, and regulate blood sugar and cholesterol levels.
5. How is ischemic injury in zone 1 of the liver treated?
Treatment for ischemic injury in zone 1 of the liver depends on the severity and underlying cause. In some cases, supportive care such as oxygen therapy and intravenous fluids may be sufficient. However, more severe cases may require surgery to restore blood flow to the liver or even a liver transplant.
  • Biology and Medical
16K
14K
22K
