Vertical and horizontal asymptotes of the curve
In summary, vertical and horizontal asymptotes of the curve of f(x) = (x^2+x-6)/(9-x^2 ) are respectively: a
mooneh
24
vertical and horizontal asymptotes of the curve of f(x) = (x^2+x-6)/(9-x^2 ) are respectively :
a) x=3,x=-3,y=-1 b)x=3,y=-1 c)x=3,y=1 d)x=-3,y=-1
i did the infinit limit to find the horizontal asymptote and i got -1
then to solve the vertical; 9-x^2 = 0 and so x= √9 so x= 3 and x=-3
but the right answer is b) x=3,y=-1
why ?
You need to divide the numerator by the denominator because the degree of the polynomial in the numerator is equal to the degree of the polynomial of the denominator.
then to solve the vertical; 9-x^2 = 0 and so x= ?9 so x= 3 and x=-3
why ?
This is a trick question that instructors like to slip onto exams. You need to factor both the numerator and denominator. You noted correctly that the denominator is (3 - x)·(3 + x), so it is zero when x = -3 or x = +3. However, the numerator can be factored as (x - 2)·(x + 3). There is then a factor (x + 3) which can be canceled in the numerator and denominator. The original function is still undefined at x = -3 , but the function is algebraically equivalent to (x - 2)/(3 - x) otherwise. The two-sided limit of the function approaches -5/6 as x approaches -3 , without having a value at x = -3 . The curve in a graph of this function will smoothly approach y = -5/6 on either side of x = -3 ; the "hole" at x = -3 is represented by an open circle at ( -3, -5/6 ). [EDIT: Sorry -- I re-read your post and see that you have studied limits.]
So when a factor can be canceled in the numerator and denominator of a rational function in this fashion, the vertical asymptote at that value of x is replaced by a "point discontinuity" there. For your function, then, there is only one vertical asymptote. So this is a little something to watch out for on homework or exam problems...
1. What is a vertical asymptote?
A vertical asymptote is a line on a graph where the function approaches infinity or negative infinity as the x-value approaches a certain value. It is typically represented by a dashed line on the graph.
2. How do you determine if a graph has a vertical asymptote?
To determine if a graph has a vertical asymptote, you can look for any x-values that would make the denominator of the function equal to 0. These values would be excluded from the domain of the function and would result in a vertical asymptote.
3. What is a horizontal asymptote?
A horizontal asymptote is a straight line on a graph that the function approaches as the x-values become very large or very small. It is typically represented by a solid line on the graph.
4. How do you find the equation of a horizontal asymptote?
The equation of a horizontal asymptote can be determined by analyzing the behavior of the function as the x-values become very large or very small. If the function approaches a constant value, that value will be the equation of the horizontal asymptote. If the function approaches infinity or negative infinity, there is no horizontal asymptote.
5. Can a function have more than one vertical or horizontal asymptote?
Yes, a function can have multiple vertical and horizontal asymptotes. This can occur when the function has multiple x-values that make the denominator equal to 0 or when the function has different behaviors as the x-values become very large or very small.
