Drag coefficient of an airplane control surface
In summary, the conversation discusses the control of rudders in RC planes and the drag equation that governs it. The drag coefficient of a flat plate is also mentioned, with values of 0.005 when parallel and 2 when perpendicular. The conversation also brings up the concept of induced drag and how it may affect the overall drag of the plane. It is noted that airfoil specs may not be accurate for slower speed craft and that rudder drag may be insignificant compared to other sources of drag.
phys_student1
106
Hello,
I was reading somewhere about how to control Rudders in RC planes. The basic equation here is the drag equation: F=0.5*ρ*v^2*C*A (take ρ=1Kg/m3)
where v is the velocity, C is the Drag coefficient of the control surface (Rudder in this case) and A is the area.
I am wondering if we have a flat plate, what would its Drag coeff. be if its area is A and it is deflected θ° to either directions? According to Wikipedia, if it is parallel, C=0.005, if it is perpendicular, C~2. I am not sure how these numbers were calculated.
You could get a good estimate by looking at the specs of a thin symmetrical airfoil. For example, the NACA0010 airfoil has a fairly constant drag coefficient of around 0.006 for lower angles of attack ( < 8 degrees ). But there is one other drag source you may want to consider, namely induced drag. Induced drag could be equal or possibly greater than the drag of the base airfoil at 8 degrees since rudders tend to be low-aspect wings.
Two other points to think about. The first is that airfoil specs are generally given for high Reynold's numbers. The specs are often inaccurate for slow speed craft like models since the air is not moving fast enough to keep a good flow. The second is that your rudder drag is probably insignificant compared to the wing drag and the overall form drag of the plane. Also, you probably shouldn't be flying with 8 degrees of rudder (assuming this is not a multi-engine with an engine failure).
1. What is the drag coefficient of an airplane control surface?
The drag coefficient of an airplane control surface is a dimensionless quantity that represents the amount of drag created by the control surface (such as a wing, flap, or aileron) when it is in motion. It is a crucial factor in determining the overall aerodynamic performance of an aircraft.
2. How is the drag coefficient of an airplane control surface calculated?
The drag coefficient of an airplane control surface is calculated by dividing the drag force acting on the control surface by the dynamic pressure of the airflow around it. It is affected by various factors such as the shape, size, and angle of the control surface, as well as the speed and density of the air.
3. What is the significance of the drag coefficient in aircraft design?
The drag coefficient plays a crucial role in aircraft design as it helps engineers and designers to optimize the aerodynamic performance of an aircraft. A lower drag coefficient means that the control surfaces create less drag and therefore, the aircraft can fly more efficiently with less fuel consumption.
4. How does the drag coefficient of an airplane control surface affect flight?
The drag coefficient of an airplane control surface affects the flight in several ways. It determines the amount of drag on the control surface, which in turn affects the overall drag of the aircraft. It also affects the lift and stability of the aircraft, as well as the control and maneuverability of the airplane.
5. What are some factors that can influence the drag coefficient of an airplane control surface?
The drag coefficient of an airplane control surface can be influenced by various factors such as the shape and size of the control surface, the angle of attack, the airspeed, the air density, and the surface roughness. Other external factors such as turbulence, wind gusts, and temperature can also affect the drag coefficient.
  • Mechanical Engineering
15K
28K
