How to determine the roots of a quadratic equation
In summary, it is possible to determine the number of roots for a given quadratic formula without using the quadratic formula itself. One way is by completing the square and analyzing the vertex of the resulting parabola. Another way is by using the discriminant, which can be derived from the quadratic formula. The fundamental theorem of algebra also states that a polynomial of degree n has n roots.
powp
91
Hello All
I am trying to figure out how to determine if there are two, one, zero, or infinitely many roots for given formula ax^2 + bx + c. Are there any easy ways to determine this without having to use the quadratic formula?
Thanks
P
I believe you are asking whether the polynomial has real roots. You can determine that by defining a function
[tex]f(x) = ax^2 + bx + c[/tex]
and completing the square
[tex]f(x) = a \left(x + \frac {b}{2a}\right)^2 - \frac {b^2}{4a} + c[/tex]
The graph of x is a parabola whose vertex is at
[tex]x = -\frac {b}{2a}[/tex]
Given the sign of a you can determine whether the vertex is a maximum or a minimum and determine whether f(x) = 0 is possible.
powp said:
Hello All
Thanks
P
Well if you're referring to roots in a general sense then yes there is an easy way, it's called the fundamental theorem of algebra. A polynomial of degree n has exactly n roots including multiplicities.
Another way, maybe the way in your book, is using the discriminant b^2 - 4ac. If that's greater than 0 then the equation has 2 real roots, if it's less than 0 the equation has 0 real roots, and if it is equal to 0 then the equation has 1 real root. It comes out of the quadratic formula but you don't need to use the entire formula, just the part under the square root sign.
Related to How to determine the roots of a quadratic equation
1. What is a quadratic equation?
A quadratic equation is an equation in the form of ax² + bx + c = 0, where a, b, and c are constants and x is the variable. It is a type of polynomial equation and can be solved to find the values of x that make the equation true.
2. How do I determine the roots of a quadratic equation?
The roots of a quadratic equation can be determined by using the quadratic formula, which is x = (-b ± √(b² - 4ac)) / 2a. This formula gives two possible values for x, known as the "roots" of the equation.
3. Are there any other methods to find the roots of a quadratic equation?
Yes, there are other methods such as factoring, completing the square, and graphing. However, the quadratic formula is the most commonly used method as it can be applied to any quadratic equation.
4. What if the discriminant is negative?
If the discriminant (b² - 4ac) is negative, then the quadratic equation has no real roots. This means that the solutions are complex numbers and cannot be represented on a real number line.
5. Can a quadratic equation have more than two roots?
No, a quadratic equation can have a maximum of two roots. This is because it is a second-degree polynomial and has a degree of 2. If there are more than two solutions, then it is not a quadratic equation.
  • STEM Educators and Teaching
