Phase difference b/w air-water interface and water-air interface
In summary: So you subtract them out to get a number in the range from 0 to 2pi.Another way to think of modular arithmetic is to think of a clock. When you subtract multiples of 12 hours from a time, you end up with the same time you started with. You only need to look at the hour hand to figure out what time it is.Similarly, when you subtract multiples of 2pi from the phase difference, you end up with the same phase difference you started with. You only need to look at the fraction of 2pi to determine the phase difference.
c-murda
67
Light of wavelength 418 nm is incident normally on a film of
water 1.0 μm thick. The index of refraction of water is 1.33.
(a) What is the wavelength of the light in the water?
(b) How many wavelengths are contained in the distance 2t,
where t is the thickness of the film? (Do not round your answer
to a whole number.)
(c) What is the phase difference between the wave reflected from
the top of the air-water interface and the one reflected from the
bottom of the water-air interface in the region where the two
reflected waves superpose?
my attemp at a solution:
(a)lambda"water" = lambda/n = 445nm
(b)N = 2t/ lambda"water" = 4.5
(c) Light is going from a medium of smaller index of refraction
(air n = 1) to a medium with higher one (water n = 1.33) so the
reflected wave is out of phase by π respect to the transmitted
wave right?
So the phase diff = π + 2π(2t/lambda"water") = -π +2π(4.5) = ?
My answers i have tried:
25.1 rad, 3.14rad, 31.4 rad, 1 rad, 4.72 rad, 0 rad 31.42rad 1 rad
Im really stumped...pls help!
Redo this calculation. This effects parts (b) and (c).
Sorry typo...original problem was from the book...
This is from my HW:
Correct Problem Statement:
Light of wavelength 592 nm is incident normally on a film of water 1.0 µm thick. The index of refraction of water is 1.33.
then part b and c follow
wave right?
All good.
OK. You're comparing π to 2π(4.5), so the phase difference is that difference mod (2π).
One of those should be right.
What book is this from?
What is the film of water on? It sounds like you are treating it as a film of water on air--that doesn't seem likely.
Doc Al said:
All good.
I know i thought long and hard about this and only have come up with these solutions repeatedly...is it possible they want a negative answer(which is my only guess left)?
this is web based homework.
The problem is from tipler 6th ed ch32 prob22
your right it doesn't seem likely but the problem doesn't state any other medium is involved
I seriously doubt it.
Those web-based systems can be picky. Some insist on 3 significant figures, so it may be worth redoing your calculations without rounding off to two digits in any intermediate step. For example, is 4.5 closer to 4.49?
Unfortunately, I only have an earlier edition.
I got:
-π +2π(4.49) = 8.89π
subtracting 7π leaves 1.98π = 6.22 radians
which is correct!
c-murda said:
which is correct!
Sweet! (Pain in the butt, isn't it? :smile:)
HA youre telling me...This is the 13 assignment I've had to do for this class all with 30+ questions...sig figs start to become a little annoying. Luckily they have improved the software side of the web-based homework(WEBASSIGN). with chem is was 2x as bad. Thank goodness there is a 1% marginal error aloud
Thanks for your help DOC as usual you come through!
Quick question: So C-Murda got -n + 2n(4.5) because 4.5 is the value of the 2t/lambda(water), and 2n because it travels through water first, but where did he get the 7n that he uses in his calculations? And which n is air and which is water?
Appreciate if you could help me out on this one.
First, realize that what you are calling 'n' is actually 'π' = pi.
The phase difference is 2π(4.49) - π = 7.98π. When you express that mod 2π, you end up subtracting 6π, for a phase difference of 1.98π.
(His post #8 was not quite clear and contained a few typos.)
Thank you very much - makes WAY more sense now. Regards.
I don't understand what "Expressing mod 2pi" means. I'm really having a hard time understanding why you subtract that 6pi.
That means subtracting out whole multiples of 2pi until you're left with just a fraction of 2pi. For more on this, see: Modular arithmetic
The reason why you subtract the multiples of 2pi is that 2pi is equal to a whole wavelength. If two things have a phase difference of 2pi, they're really in phase. Only the fractions of a wavelength that are left after subtracting the whole wavelengths are relevant to figuring out the net phase difference.
RIGHT RIGHT. Oh my goodness I'm so dumb haha. Thanks for clearing that up haha.
1. What is the phase difference between the air-water interface and water-air interface?
The phase difference between the air-water interface and water-air interface is the difference in the physical state or phase of the two substances at their boundary. In this case, it refers to the difference in the state of air (gas) and water (liquid) molecules at the interface where they meet.
2. Why is the phase difference between the air-water interface and water-air interface important?
The phase difference between the air-water interface and water-air interface is important because it affects the behavior of light and sound when they pass through the interface. It also has significant implications in understanding surface tension and other physical phenomena at the boundary between air and water.
3. How is the phase difference between the air-water interface and water-air interface measured?
The phase difference between the air-water interface and water-air interface can be measured using techniques such as interferometry, which involves the use of light to observe the changes in the interface. Other methods include acoustic and ultrasonic techniques, which measure the phase difference in sound waves passing through the interface.
4. What factors can affect the phase difference between the air-water interface and water-air interface?
The phase difference between the air-water interface and water-air interface can be affected by various factors, including temperature, pressure, and the properties of the substances themselves. For example, changes in temperature can cause the molecules to vibrate differently, leading to a change in the phase difference at the interface.
5. How does the phase difference between the air-water interface and water-air interface impact the behavior of waves?
The phase difference between the air-water interface and water-air interface can significantly impact the behavior of waves, such as light and sound. For example, it can result in the reflection, refraction, and diffraction of these waves as they pass through the interface. It also plays a crucial role in the formation of interference patterns, which are observed when two or more waves interact at the interface.
