PID temp control for distillation (was Before i ask )
In summary, Scotty is asking questions about distilling and wants to make sure that it is okay to do so. He has a hobby of distilling and is looking for advice on how to proceed. He is also looking for advice on how to avoid problems.
Slowpokescott
PID temp control for distillation (was "Before i ask")
I am 68 years old and never studied physics-- i am not a college student and only completed 1 year of college.
I have a hobby of distilling and need questions amswered-- is it ok if i aske questions here about distilling?
:smile:
Scotty
Chemistry news on Phys.org
:smile:
Scotty
Welcome to the PF, Scotty.
I would think it would be okay. If there are any problems, folks here are pretty good at using the Report button to give a heads up to the Mentors about any issues.
What-all do you distill?
I don't intend to break any rules-- Well i started making wine a few years back and somewhere along the line i found a distilling website-- I truly almost never ingest alcohol. The hobby is a bit interesting - i use the wine to bribe the handy men in the trailer park.
hOLIDAY, BIRTHDAY ETC GIFTS.
Well i really don't remember what prompted me to buy a small still but I am in up to my neck now--I have been attempting to make Irish whiskey with barley malt.I have a variac and am putting together a pid controller to controll the heat to the boiler.
Thats where the confusion comes in. The old timers on the distilling website tell me that i must get the liquid to a boil and then cut back the power so as to maintain the boil and never let the heat source shut off even if it is just on low
BTW i let my advanced class ham license lapse--Years ago
Well in my mind i can't see how the liquid knows if the power to the heating element is off or on-- i think that if i got the liquid up to about 200-205 deg.F. the alcohol would boil off even of the power was turned off- I am setting my controll with a 1 degree diferential.
Is the actual boiling necessary??
What i want to do is assemble a pID with a solid state relay. I am really green at this pID thing but i believe that i read that the device would cycle the power on and off at diferent rates as the desired temperature was approaching. This would almost eliminate over shooting and wide variations in the temp but not necessarily keeping a constant power tothe heat element.
If i have not explained clearly i will gladly try to answer any questions--And naturally thanks for any and all comments-- i want to learn if possible:smile:
The pot will boil at it's boiling point. That will change as you distill out the more volatile components. When you change the setting of your variac, you are changing the power to the heating mantle. Without contacting any surface, like the still pot, the temperature tracks with power but in contact with the still the story isn't so simple. In contact with the still, the temperature of the mantle may change somewhat with different power settings but the pot temperature is regulated by the physical properties of the contents. What will change is the rate at which you produce distillate. Higher power... faster rate. It is possible to superheat the still and produce volatiles that are higher than they might otherwise be, but I wouldn't operate your still in that manner. This usually happens when the level in your pot drops below the level of the mantle.
Hope you've http://www.ttb.gov/spirits/faq.shtml#s7" Good luck.
edit. I forgot to add that boiling is necessary unless you intend to use a very low temperature on your condenser and you have loooots of time on your hands. Heck, you could "freeze dry" it if you have the time and equipment.
Im converting my still to an internal heat element in a week or so. Waiting for the stainless coupling.
Does anyone recommend that i run it at a steady boiler temperature-- I use an alcoholometer to determine what portions of the distilate to keep And I monitor the temperature in the top of the still to see when the best alcohol is present. Prox 78C As the temp rises the purity(amount od fusel oils increases)
I am am willing to expeiment if anyone can give me some suggestions.
Maybe he should also answer whether he plans to fill corresponding british, french, german, italian, chinese, indonesian ... forms.
Thank you for your comment-- Rather than be policed i have requested that my name be stricken from the site roster..
My loss but as I told the administratror, i used to go to a church that required signatures etc. I won't submit to that again.
Again, my loss i had high hopes of learning from you brainy typs..
The PF has a policy against discussing illegal or dangerous activities (see the Rules link at the top of the page). I'd assumed at the start of this thread that distillation of spirits was the same as making beer or wine at home, which lots of folks do within the respective rules. It's too bad that spirits appear to have different rules, at least in the US.
Related to PID temp control for distillation (was Before i ask )
1. What is PID temp control for distillation?
PID (Proportional-Integral-Derivative) temp control for distillation is a method of regulating temperature during the distillation process. It uses a feedback loop system to continuously adjust the heat source in order to maintain a consistent temperature.
2. How does PID temp control work?
PID temp control works by using a temperature sensor to measure the temperature of the distillation setup. The temperature reading is then compared to a set point, which is the desired temperature. The controller then adjusts the heat source based on the difference between the two values, using a combination of proportional, integral, and derivative control to minimize any temperature fluctuations.
3. Why is PID temp control important in distillation?
PID temp control is important in distillation because it allows for precise temperature regulation, which is crucial for obtaining desired distillate products with consistent quality. It also helps to prevent temperature fluctuations that can affect the separation of different components in the distillate.
4. What are the advantages of using PID temp control for distillation?
The advantages of using PID temp control for distillation include improved product quality, increased efficiency, and reduced energy consumption. It also allows for greater control over the distillation process, resulting in more consistent and reproducible results.
5. Are there any limitations to PID temp control for distillation?
While PID temp control is highly effective, it may not be suitable for all types of distillation processes. For example, in cases where there are significant delays in the heat transfer, a different type of control system may be more suitable. Additionally, PID control may require regular tuning and adjustments to maintain optimal performance.
  • Mechanical Engineering
  • Electrical Engineering
