Question about neutral region in Derivating Shockley equation
  • Thread starter alexyangfox
  • Tags
    Neutral
In summary, the "neutral region" in the Shockley equation refers to the area in a PN junction where there is no net electric field present. This is due to the balance between the depletion region and the diffusion of charge carriers from the P and N regions. The second term in the equation representing the electric field becomes zero in this region. The Ideal diode model simplifies the behavior of a diode by assuming it is either fully conductive or fully non-conductive, without considering voltage drop or band twisting.
alexyangfox
question about "neutral region" in Derivating Shockley equation
Hey guys.
I met a problem when derivating the Shockley equation.
a few steps before I finally get the Shockley equation , I met the Equation
in the attachment.
the book said , because there's no electric field in the neutral region.
So the E is 0,that means the second term disappears.
But why?
When there's a voltage say 5v Across the Pn junction(say,forward bias) ,how could it be possible that there's no electric field in the neutral region?
Or the Ideal diode model computes the "voltage" in the depletion layer,say twist the bands?
thanks,
Best regards.
Hello there,
Thank you for your question about the "neutral region" in the Shockley equation. The neutral region refers to the area in a PN junction where there is no net electric field present. This means that the electric field is equal in magnitude and opposite in direction on both sides of the junction, resulting in a net electric field of zero.
In order to understand why the second term in the equation disappears in the neutral region, it is important to understand the behavior of the electric field in a PN junction. When a voltage is applied across the junction, it creates a depletion region where there is a difference in charge density between the P and N regions. This difference in charge density creates an electric field that opposes the applied voltage.
In the neutral region, the electric field is zero because the depletion region is balanced by the diffusion of charge carriers from the P and N regions. This means that the second term in the equation, which represents the electric field, becomes zero as well.
As for your question about the Ideal diode model, it does not consider the voltage in the depletion layer or the twisting of bands. Instead, it simplifies the behavior of a diode by assuming that it is either fully conductive or fully non-conductive, with no voltage drop across it.
I hope this helps clarify the concept of the neutral region in the Shockley equation. Let me know if you have any further questions.
1. What is a neutral region in the Derivating Shockley equation?
The neutral region in the Derivating Shockley equation refers to the region in which no current flows in a semiconductor device. This is the region between the forward and reverse biased regions where the voltage across the device is not enough to cause significant current flow.
2. Why is the neutral region important in the Derivating Shockley equation?
The neutral region is important because it helps to determine the overall behavior of a semiconductor device. It allows us to understand how the device responds to different levels of voltage and current, and can help us to optimize its performance.
3. How is the neutral region calculated in the Derivating Shockley equation?
The neutral region is calculated by finding the point at which the forward and reverse biased regions intersect on a plot of current vs. voltage. This is known as the "knee" of the curve and represents the transition from the neutral region to the forward biased region.
4. What factors can affect the size of the neutral region in the Derivating Shockley equation?
The size of the neutral region can be affected by various factors such as the doping concentration, temperature, and material properties of the semiconductor device. These factors can impact the behavior of the device and therefore the size of the neutral region.
5. How does the neutral region impact the performance of a semiconductor device in the Derivating Shockley equation?
The neutral region can impact the performance of a semiconductor device by affecting its switching speed, power dissipation, and overall efficiency. Understanding the size and behavior of the neutral region is crucial in optimizing the performance of the device for various applications.
  • Atomic and Condensed Matter
  • Electrical Engineering
