Calculating an equations error given the error of a single value
  • Thread starter buttermellow
  • Tags
    Error Value
In summary, the total error in calculating E, which depends on both m and v, would be the sum of the percentage errors for m and v. This is due to the engineers rule of thumb that states that when measurements are added or subtracted, their errors add, and when measurements are multiplied or divided, their relative errors add. For the equation E = 0.5mv^2, the relative error would be dm/m + 2dv/v, where dm is the error in m and dv is the error in v.
buttermellow
Say you had an equation like E = .5mv2. If in an experiment the velocity is measured, but has an error of 10%, what would be the total error in calculating E?
Hi buttermellow, welcome to PF! :smile:
Is this a homework question?
If so, what do you think it should be?
That way we can help you better to understand how to calculate such errors... :wink:
What about m? Just use addition of percentage error here. While making product percentage errors are added, while making sums just add errors. After all, uncertainty of E depends on m as well.
There is an engineers rule of thumb that says that when measurements are added or subtracted their errors add. When measurements are multiplied or divided, their relative errors (error divided by the value) add.
If f= xy and x has error dx, y has error dy, then f could be as large as (x+ dx)(y+ dy)= xy+ xdy+ ydx+ dxdy. Neglecting the small dxdy (if dx and dy are small, dxdy will be much smaller), the error is xdy+ ydx so the relative error is (xdy+ ydx)/(xy)= dy/y+ dx/x.
With 0.5mv^2, for small errors dm and dv, the relative error is dm/m+ 2dv/v.
The total error in calculating E would depend on the type of error that is present in the velocity measurement. If the error is a random error, meaning it is equally likely to be positive or negative, then the total error in calculating E would be 10% of the calculated value of E. This is because the error in the velocity measurement would be propagated through the equation and result in a 10% error in the final calculated value of E.
However, if the error in the velocity measurement is a systematic error, meaning it consistently overestimates or underestimates the true value, then the total error in calculating E may be larger or smaller than 10%. This is because the systematic error would be consistently propagated through the equation, resulting in a larger or smaller error in the final calculated value of E.
To accurately determine the total error in calculating E, it is important to identify and quantify the type of error present in the velocity measurement. This can be done through careful calibration and validation of the measurement equipment, as well as conducting multiple trials and analyzing the data for any trends or patterns that may indicate a systematic error. Overall, it is crucial to consider and account for all sources of error in scientific experiments in order to ensure the accuracy and reliability of our calculations and results.
Related to Calculating an equations error given the error of a single value
1. How do you calculate the error of an equation given the error of a single value?
To calculate the error of an equation, first determine the partial derivative of the equation with respect to the variable with the known error. Next, multiply the partial derivative by the known error of the variable. Finally, take the absolute value of the result to get the error of the equation.
2. What if the equation has multiple variables with known errors?
If the equation has multiple variables with known errors, you will need to calculate the partial derivatives for each variable and then add them together to get the total error of the equation.
3. Can you give an example of calculating the error of an equation?
Sure, let's say we have the equation E = mc^2 and we know that the mass (m) has an error of 0.1 kg. The partial derivative of this equation with respect to mass would be 2mc. Multiplying this by the known error of 0.1 kg gives us an error of 0.2mc. So the error of the equation would be 0.2 times the value of c squared.
4. Is it necessary to know the error of every single variable in the equation?
No, it is not necessary to know the error of every single variable in the equation. You only need to know the error of the variable that you are interested in finding the error of the equation for.
5. What are some common sources of error when calculating the error of an equation?
Some common sources of error when calculating the error of an equation include rounding errors, errors in measurement or data, and errors in the assumptions made in the equation. It is important to properly account for these sources of error in order to get an accurate result.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
