Subgroups of a Cyclic Normal Subgroup Are Normal
In summary, the conversation discusses a proof involving a cyclic and normal subgroup of a group. The proof relies on the fact that the subgroup can be generated by a single element and that it is normal in the larger group. The conversation also provides tips on how to complete the proof, including using the definition of a normal subgroup and the fact that the subgroup can be written in terms of the generator.
e(ho0n3
1,357
If H ≤ G is cyclic and normal in G, prove that every subgroup of H is also normal in G.
The attempt at a solution
Let H = <h>. We know that for g in G, hi = ghjg-1 by the normality of H. A simple induction shows that hin = ghjng-1, so that <hi> = g<hj>g-1. Now all I need to show is that hj belongs to <hi>. I'm having trouble with this. Any tips?
Hello!
Great job on starting the proof. Here are some tips to help you with the rest of the proof:
1. Use the fact that H is cyclic and normal in G: Since H is cyclic, we know that it is generated by a single element, say h. Since H is also normal in G, we know that for any g in G, ghg^-1 is also in H. This means that any element in H can be written as ghg^-1 for some g in G.
2. Use the definition of a normal subgroup: A subgroup N of a group G is normal if for any element g in G, gNg^-1 = N. This means that for any element in N, we can "move" it to the other side of g using the inverse operation. This can help you show that hj belongs to <hi>.
3. Use the fact that <hi> = g<hj>g^-1: This means that for any element in <hi>, we can write it as ghjg^-1 for some g in G. This can also help you show that hj belongs to <hi>.
Hope these tips help you complete the proof! Good luck!
1. What is a cyclic normal subgroup?
A cyclic normal subgroup is a subgroup of a group that is generated by a single element and is invariant under conjugation by any element in the group.
2. How do you determine if a subgroup of a cyclic normal subgroup is normal?
A subgroup of a cyclic normal subgroup is normal if it is invariant under conjugation by any element in the subgroup. In other words, for any element in the subgroup, its conjugates must also be in the subgroup.
3. Why are subgroups of a cyclic normal subgroup important?
Subgroups of a cyclic normal subgroup are important because they help us understand the structure of the original group. They also play a critical role in the study of group theory and have many applications in various fields of mathematics and science.
4. Can a subgroup of a cyclic normal subgroup be non-cyclic?
Yes, a subgroup of a cyclic normal subgroup can be non-cyclic. This is because a cyclic normal subgroup may have multiple generators, and its subgroups can have different generators as well.
5. What is the relationship between normal subgroups and cyclic normal subgroups?
All cyclic normal subgroups are normal subgroups, but not all normal subgroups are cyclic normal subgroups. This means that a subgroup can be normal without being generated by a single element and being invariant under conjugation.
  • Math POTW for University Students
