Calculating Breakaway Torque for a 16 Pipe: A Simple Explanation
  • Thread starter ljh34481
  • Tags
    Torque
In summary, there is a radius of gyration that needs to be calculated in order to determine the breakaway torque for a 16" diameter pipe. This radius is based on the amount of force required to rotate the pipe material bunched up into one thin piece.
ljh34481
Hi, I am not an engineer nor a physicist but said I would try researching for a friend.
The question is - how do you calculate the breakaway torque for a 16" diameter pipe weighing 1350 pounds?
We are trying to determine what HP engine would be required assuming that the motor shaft would be centered in the pipe and there would be zero friction.
I have found WK² or WR² but am totally confused with the radius of gyration.
Is there a "simple" way of making this determination?
Thanks - hope this question was clear
Tough one if you want a real number, rather than a theoretical (probably wrong) one.
Any chance to measure motor current draw?
To understand the radius of gyration, you have to think about what's actually happening. Here's a quick explanation:
In order to rotate a very thin piece of pipe about its axis, you have to apply a force on the outside of pipe to move it. For the same amount of pipe material, the wider the pipe is, the easier it is to rotate. Imagine your pipe as a lot of really thin (like infinitesimally thin) pieces of pipe whose diameters are getting bigger as you move from the inside to the outside. If you want to rotate all of them, the inside pieces will require more force to rotate than the outside pieces. Now, instead of trying to calculate the force required to rotate each individual piece of really thin pipe and then add it all up together to get one number, it would just be easier to imagine all the material bunched up into one thin piece of pipe with a certain radius that requires exactly the same amount of torque to rotate as all those sections of pipe. That radius is the radius of gyration.
There are equations to solve for the radius of gyration for pipe. You'll need to know the inside and outside radii of the pipe.
Hope this helped clear up some confusion.
1. What is breakaway torque?
Breakaway torque is the amount of force required to start rotation of a stationary object, such as a bolt or screw, that is secured by a fastener. It is a measure of the initial resistance or stiffness of the joint.
2. How is breakaway torque measured?
Breakaway torque is typically measured using a torque wrench or torque tester. The device is attached to the fastener and turned until the joint begins to rotate. The amount of force needed to start the rotation is recorded as the breakaway torque.
3. What factors can affect breakaway torque?
There are several factors that can affect breakaway torque, including the type and condition of the fastener, the surface finish of the materials being joined, and the amount of lubrication on the threads. Additionally, environmental conditions such as temperature and humidity can also impact breakaway torque.
4. Why is breakaway torque important in engineering and manufacturing?
Breakaway torque is important in engineering and manufacturing because it helps determine the proper amount of force needed to secure a fastener and prevent loosening or failure of the joint. It also ensures consistent performance and reliability of the product.
5. How can breakaway torque be adjusted or controlled?
Breakaway torque can be adjusted or controlled by altering the design or materials of the fastener, using different lubricants or coatings, or adjusting the tightening method. It is important to carefully consider these factors to achieve the desired breakaway torque for a specific application.
  • Mechanical Engineering
11K
