What do you mean by 1 mol gas occupies 22.4 litres
  • Thread starter jd12345
  • Tags
    Gas Mean
In summary: The pressure difference is negligible because the Young's modulus for rubber is between 0.01-0.1 GPa.
jd12345
256
Avagadro law states that 1 mol of any gas( ideal) occupies 22.4 litres.
I don't really understand it. You take one mole of oxygen and leave it in a room - will it go in a corner and occupy 22.4litres? I think it spreads out in the whole room.
So what does the law mean?
Chemistry news on Phys.org
This law states at STP (101325 pa and 273K) one mole of an ideal gas (such as oxygen) will occupy a volume of 22.4L ;)
a) cool the room to 273.15 K;
b) hermetically seal the room;
c) create a high vacuum in it by pumping all the air out;
d) Add 1 mole of oxygen.
The pressure in the room should be given by:
[tex]
1 \, \mathrm{atm} \frac{22.4 \, \mathrm{dm}^3}{V}
[/tex]
Or, another way of looking at it, take an ideal empty large balloon. Fill that balloon with 1 mole of any gas, and place balloon in a room at STP. The inside volume of that balloon will be 22.4 liters...
No, it won't. The pressure inside an inflated balloon is larger than the exterior pressure, due to the elastic tension in the material from which the balloon is made of.
True if its a rubber balloon, but even still the pressure caused by the rubber will tend to be vanishingly small.
How did you estimate that the pressure difference is negligible? The Young's modulus for rubber is between 0.01-0.1 GPa. If we have a sphere with radius R, and thickness t, then a pressure difference on both sides of the sphere translates to a strain [itex]\sigma[/itex]:
[tex]
\sigma = \frac{R}{t} \, \Delta p \Leftrightarrow \Delta p = \frac{t}{R} \, \sigma
[/tex]
A typical thickness of a balloon is 10 mil (ten thousandths of an inch), and a typical inflated radius of a balloon is 5 inches. But, the balloons are often inflated twice their undeformed length, i.e. [itex]\epsilon \sim 1[/itex]. Therefore:
[tex]
\Delta p \sim \frac{10 \times 10^{-3} \, \mathrm{in}}{5 \, \mathrm{in}} \, \left( 0.01 - 0.1 \, \mathrm{GPa} \right) = 0.02 - 0.2 \, \mathrm{MPa} = 0.2 - 2 \, \mathrm{atm}
[/tex]
I think this is exactly of the same order of magnitude as the atmospheric pressure.
I said 'ideal' balloon - this implies zero constraining forces from the material itself. P(inside) = P(outside)... Yes, in a normal balloon P(inside) slightly larger than P(outside). You'll still get close to 22.4l in any case. If it makes people happier, change 'balloon' to 'plastic garbage bag' with a nominal 50 liter capacity... as you'd only fill it to 22.4l, there will be no strain on the material and P(inside) = P(outside).
I base that on the fact that I can blow one up with my lungs! Based on this link (and an everyday experience we all have had!), the max pressure we can generate is about 1psi, so you're an order of magnitude high with your calculation: http://www.ncbi.nlm.nih.gov/pmc/articles/PMC1501025/
From the link you had provided:
In men, maximum expiratory pressure increased with volume from 63 to 97 cmH2O and maximum inspiratory pressure decreased with volume from 97 to 39 cmH2O.
97 cm H20 refers to a pressure difference of:
[tex]
1000 \, \mathrm{kg} \cdot 9.81 \, \frac{\mathrm{m}}{\mathrm{s}^2} \cdot 0.97 \, \mathrm{m} = 9.52 \times 10^3 \, \mathrm{Pa} \times \frac{1 \, \mathrm{atm}}{101325 \, \mathrm{Pa}} = 9.4 \times 10^{-2} \, \mathrm{atm}
[/tex]
That is 9.4% above atmospheric pressure.
Also, see:
http://www.youtube.com/watch?v=fwh-i0WB_bQ
As they inflate the balloon, the pressure is pretty constant around 810 mm Hg, eventually increasing to 840 mm Hg. Now, standard atmospheric pressure corresponds to:
[tex]
\frac{101325 \, \mathrm{Pa}}{13,600 \, \mathrm{kg} \cdot \mathrm{m}^{-3} \times 9.81 \, \mathrm{m} \cdot \mathrm{s}^{-2}} = 0.759 \, \mathrm{m} = 759 \, \mathrm{mm} \, \mathrm{Hg}
[/tex]
Thus, this is excess pressure of:
[tex]
\frac{810 - 840}{759} \, \mathrm{atm} = 1.07 - 1.107 \, \mathrm{atm}
[/tex]
I guess it is a matter of circumstance whether 10% is considered negligible or not.
Which is way lower than your initial estimate :wink:
[tex]
[/tex]
If anything, 810-760 mmHg or 0.066 atm, or about 7%.
But I agree that negligibility of this number is disputable. Thank you for digging this video up.
[tex]
[/tex]
[tex]
[/tex]
My lower estimate is only about twice as big as the other result. I would say that is not bad for an order of magnitude estimate :SMILE:
There are at least 3 issues with the calculation:
  • There might be a numerical factor in the equation relating latteral radial pressure difference, and sheer stress. I am not sure what this factor is.
  • The thickness I used ([itex]10 \, \mathrm{mil} = 254 \, \mathrm{\mu m}[/itex]) was taken from some ad for ballons used to isolate clean rooms! It might be too big!
  • Finally, I used the quoted values for Young's modulus in Wikipedia. Rubber behaves in an atypical fashion that is not in exact coincidence with Hooke's Law. That is why the range of values.
Regardless, even a 9.4% increase in pressure would lead to a [itex]1 - 1/1.0094 = 0.0093 = 9.3 \%[/itex] decrease in molar volume. 9.3% out of 22.4 is 2.08. Thus, one cannot report the result with 3 significant figures, but, instead, one would obtain something around [itex] \approx 20 \, \mathrm{dm}^3/\mathrm{mol}[/itex]
1. What is a mole of gas?
A mole of gas is a unit of measurement used in chemistry to represent a specific number of particles. It is defined as the amount of a substance that contains the same number of particles as there are atoms in exactly 12 grams of carbon-12.
2. How many particles are in one mole of gas?
One mole of gas contains approximately 6.022 x 10^23 particles, which is known as Avogadro's number.
3. How is the volume of a gas related to its moles?
According to Avogadro's law, at a constant temperature and pressure, the volume of a gas is directly proportional to the number of moles of gas present. This means that as the number of moles of gas increases, so does the volume it occupies.
4. Why is the volume of 22.4 litres used to represent 1 mole of gas?
This volume is based on the ideal gas law, which states that at standard temperature and pressure (STP), 1 mole of any gas will occupy a volume of 22.4 litres. This is a convenient value to use for calculations and comparisons between different gases.
5. Are there any exceptions to the 22.4 litre rule for 1 mole of gas?
Yes, at temperatures and pressures that deviate from STP, the volume of 1 mole of gas may not be exactly 22.4 litres. This is because the ideal gas law assumes that gases behave ideally, which is not always the case in real-world conditions.
  • Mechanical Engineering
  • Quantum Physics
  • Classical Physics
