Viscosity - how to calculate the internal force in a fluid
In summary, the conversation is about a formula for the internal force/volume in a fluid, and the discussion of how to calculate the partial derivative of velocity with respect to time if velocity is a function of x, y, z, and t. The conversation also delves into simplifying the expression and finding a way to write it as a vector field independent of the coordinate system. It is recommended to look into the Navier-Stokes system of equations for further understanding.
TriKri
72
Hi,
I'm looking for a little bit of help in this matter, I'm trying to put up a general formula of the internal force/volume in a fluid in a spot, as a function of how the velocity varies locally around that spot.
What I started with was a formula I found in a book called "Physics Handbook - for Science and Engineering":
Differential equation for a Newtonian liquid flowing in the y-direction with speed vy = vy(x,t)
[tex]\frac{\partial v_y}{\partial t}=\frac{\eta}{\rho}\ \frac{\partial^2 v_y}{\partial x^2}+\frac{f}{\rho}[/tex]
[tex]f[/tex]=external force in y-direction per volume
[tex]\eta[/tex]=coefficient of viscosity
Now, do anyone know how to calculate [tex]\frac{\partial \vec{v}}{\partial t}[/tex] if [tex]\vec{v}[/tex] is a function of x, y, z and t?
Anyway, from what was in the book, the acceleration that comes from the viscosity (hence exluding all external forces), is
[tex]\frac{\partial v_y}{\partial t}=\frac{\eta}{\rho}\ \frac{\partial^2 v_y}{\partial x^2}[/tex]
Multiplying with the density gives us
[tex]\frac{dm}{dV}a_y=\eta\frac{\partial^2 v_y}{\partial x^2}[/tex]
where m is the mass, V is the volume, and ay is the acceleration in y-direction. Since m*a=f, we have:
[tex]\frac{df_y}{dV}=\eta\frac{\partial^2 v_y}{\partial x^2}[/tex]
Now, if you have [tex]v_y=v_y(x,z,t)[/tex] instead, I guess the equation would look like
[tex]\frac{df_y}{dV}=\eta\left(\frac{\partial^2 v_y}{\partial x^2}+\frac{\partial^2 v_y}{\partial z^2}\right)[/tex]
And to what I suppose, the force created (only by the inner friction of the liquid, i.e. the viscosity) would be the same, even if [tex]v_y[/tex] is a function of both x, y, z and t.
What I realized was this:
[tex]\frac{df_x}{dV}=\eta\left(\frac{\partial^2 v_x}{\partial y^2}+\frac{\partial^2 v_x}{\partial z^2}\right)[/tex]
[tex]\frac{df_z}{dV}=\eta\left(\frac{\partial^2 v_z}{\partial x^2}+\frac{\partial^2 v_z}{\partial y^2}\right)[/tex]
or
[tex]\frac{d\vec{f}}{dV}=\eta\left(\begin{array}{ccccc}
0&+&\frac{\partial^2 v_x}{\partial y^2}&+&\frac{\partial^2 v_x}{\partial z^2}\\ \\
\frac{\partial^2 v_y}{\partial x^2}&+&0&+&\frac{\partial^2 v_y}{\partial z^2}\\ \\
\frac{\partial^2 v_z}{\partial x^2}&+&\frac{\partial^2 v_z}{\partial y^2}&+&0
\end{array}\right)[/tex]
Now, is there any way to simplify this expression? Anyway, I worked a bit on it on my own and I found that it equals to
[tex]\eta\left(\begin{array}{ccccc}
\frac{\partial^2 v_x}{\partial x^2}&+&\frac{\partial^2 v_x}{\partial y^2}&+&\frac{\partial^2 v_x}{\partial z^2}\\ \\
\frac{\partial^2 v_y}{\partial x^2}&+&\frac{\partial^2 v_y}{\partial y^2}&+&\frac{\partial^2 v_y}{\partial z^2}\\ \\
\frac{\partial^2 v_z}{\partial x^2}&+&\frac{\partial^2 v_z}{\partial y^2}&+&\frac{\partial^2 v_z}{\partial z^2}
\end{array}\right)
\eta\left(\begin{array}{c}
\frac{\partial^2 v_x}{\partial x^2}\\ \\
\frac{\partial^2 v_y}{\partial y^2}\\ \\
I also found that
[tex]\left(\begin{array}{ccccc}
\end{array}\right)
(\vec{\nabla}\cdot\vec{\nabla})\vec{v}[/tex]
[tex]\text{(And also }=\vec{\nabla}(\vec{\nabla}\cdot\vec{v})\ -\ \vec{\nabla}\times(\vec{\nabla}\times\vec{v})\ )[/tex]
so that basically, one can write
\eta(\vec{\nabla}\cdot\vec{\nabla})\vec{v}
Now I have showed you my work, how long I have come so far. I would really appreciate if someone could help me with the last part. The thing I have done here is that I have removed almost all x, y and z and written it as a vector field instead of as three different scalar fields. Hence trying to make it undependent of which coordinate system that is used. I just can't find a way to write that last vector without using x, y and z, and without making it depend on which coordinate system you use. I want to minimize it into one row as I have done with the bigger vector.
If someone knows a way to do this, I would be really thankful if that one could tell me. Or, if someone knows how the thing I wanted to know from the beginning (how to calculate [tex]\frac{\partial \vec{v}}{\partial t}[/tex] if [tex]\vec{v}[/tex] is a function of x, y, z and t) usually is written, that would be fine too.
TriKri said:
Hi,
<snip>
There's a lot to this post, I'll tackle it piecemeal, and see how far I get before having to take a break.
Ok, first- that equation is a simplified version of a=F/m, written for continua. Normally, the dv/dt term is written as Dv/Dt, because v = v(x,y,z,t), and so v can change either by you standing somewhere and looking at it (dv/dt) or by you moving somewhere else (v *grad(v)), where '*' is a dot product. So, this text has not only assumed that the flow is linear (so the v*grad(v) term is gone), but also v = v(x,t), and only in the 'y' direction- recall v is a vector field.
There's nothing that bizarre about the equation shown, the usual way to deal with it is by separation of variables.
<snip>
<snip>
I didn't see anything obviously wrong, but I think the origin of your confusion is that you are not treating ma=F as a vector equation right from the beginning; there are three (one for each component). So you end up with this mish-mash of expressions. That, plus starting from a 1-D simplified expression and trying to generalize to 3-D.
Look up the Navier-Stokes system of equations and how (say) Pouiseuille (sp?) flow is derived from the general expression. That should help.
Right or wrong, such a pretty post.
TriKri said:
Hi,
<snip>
<snip>
Ok- found one error. Or two, depending on how you count. First, [itex]\rho\neq\frac{dm}{dV}[/itex]. That would be d[itex]\rho[/itex], IIRC. And then also, a[itex]\neq\frac{\partial v}{\partial t}[/itex], and df[itex]\neq
{\partial m}a[/itex]
[for understand your problem you begin with the cinematic of fluid.
for describe any fluid it exixt two types of description lagrangien and euleurien descriptions. where any propriety is write as f=f(x,y,z,t) like velocity v=(x,y,z,t).
for calculate the acceleration you use the particular derivative = the locale acceleration +convective term.
for the viscosity you can see :dynamic of ''real fluid''
good luck
Okay, your post is confusing me. I really don't see why it shouldn't be the case. Isn't [itex]\rho=\frac{dm}{dV}[/itex] like the definition of density? If you mean that [itex]\frac{dm}{dV}[/itex] should equal [itex]d\rho[/itex] then you really have to explain why - if you count the d:s and [itex]\partial[/tex]:s in your equation it doesn't add up. The same thing with the acceleration. Why shouldn't that be the case (you also got to consider that this is only the acceleration which is caused by the inner friction of the liquid - not depending on any external forces; then you also have to subtract v*grad(v) as you stated before)? And df[itex]\neq{\partial m}a[/itex], where have I written that they are equal?
Concerning your last post, you say that what is causing my confusion is that I treat F not as a field but rather as three different components - don't you think that I deal with that later? If you have read the entire post you will know that I derived those equations from one single equation that was in a book called Physics Handbook, which had simplified it all so that it was valid to a 1-D field only, hence it wasn't really possible for me to go ahead in any other way. If you have any suggestions on how I could have done it instead, you can gladly tell me.
But thanks for your reference to Navier-Stokes equations, I think I have found something useful there.
-Kristofer
The density [itex]\rho[/itex] is m/V (i.e. kg/m^3). I haven't seen density used in a differential form, even though we sometimes write dm = [itex] \rho dV[/itex]. But note, that's different than what you wrote, because there's an integral floating around somewhere to get back to 'm' and 'V'.
The quantities 'dm' and 'dV' are different than the mathematical sense of 'dm/dV'. It makes sense to talk about infinitesimal portions of mass and volume (related by the density), but writing dm/dV and treating that as a well-defined mathematical operation (d/dV (ma)) is questionable.
Still, if you have a suggestion on how I can do it instead, I would be happy to hear it. So far you have only come up with problems that didn't even exist from the beginning (imo).
dear sir, you are trying to solve the well known Navier-Stokes equation for the flow of Newtonian liquids. You can only solve this equation analytically in the cas of the laminar steady flow in a duct of simple cross section shape (circular, rectangular...).
For other cases : non steady, turbulent... you need to use numerical methods like k-epsilon or direct numerical simulation (DNS). You can find easy tu use numerical codes like polyflow...
Best regards
Well, I am really not trying to solve any equation, I am just looking for another way to write (what I consider to be) [tex]\displaystyle{\frac{d\vec{F}}{dV}}[/tex], that is undependent of the coordinate system. If you look at my first post, you can see that I have only managed to get the expression to
[tex]\frac{d\vec{f}}{dV}=\eta(\vec{\nabla}\cdot\vec{\nabla})\vec{v}-\eta\left(\begin{array}{c}\frac{\partial^2 v_x}{\partial x^2}\\ \\ \frac{\partial^2 v_y}{\partial y^2}\\ \\ \frac{\partial^2 v_z}{\partial z^2}\end{array}\right)[/tex]
Where the last term is still problematic. I want to express it in another way, just like I have done with the [itex]\eta(\vec{\nabla}\cdot\vec{\nabla})\vec{v}[/itex] term, to get completely rid of the parameters (in this case x, y and z).
-Kristofer
1. What is viscosity?
Viscosity is a measure of the resistance of a fluid to flow. It describes the internal friction of a fluid and how easily it can be deformed or sheared. Viscosity is a key factor in determining the behavior and properties of fluids.
2. How is viscosity calculated?
Viscosity can be calculated using the formula: η = F/A x t/v, where η is the viscosity, F is the internal force, A is the area of the fluid, t is the time taken for the fluid to flow, and v is the velocity of the fluid.
3. What is the significance of viscosity in fluid mechanics?
Viscosity plays a crucial role in fluid mechanics as it affects the rate of flow, resistance to flow, and the smoothness of flow in a fluid. It also determines the behavior of fluids when they come into contact with solid surfaces.
4. How does temperature affect viscosity?
The viscosity of a fluid is highly dependent on temperature. Generally, as temperature increases, the viscosity of most fluids decreases. However, for some fluids, such as water, the viscosity increases with temperature. This is due to the changes in the molecular structure and movement of the fluid particles.
5. What are the different units of viscosity?
The SI unit of viscosity is Pascal-second (Pa·s). However, other commonly used units include centipoise (cP), poise (P), and stoke (St). 1 Pa·s = 1000 cP = 10 P = 10000 St.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
