Countable union of countable sets vs countable product of countable sets
In summary, the conversation discusses the concept of countable unions and products and how they relate to the set of infinite sequences. It is mentioned that while a countable union and finite product of countable sets is countable, a countably infinite product of countable sets may not be. The conversation also delves into the difference between X^\omega and \bigcup{X^n} and how there are more elements in X^\omega. It is then concluded that the standard Cantor argument shows that even a countable product of the set {0,1} is uncountable.
snakesonawii
I know that a countable union of countable sets is countable, and that a finite product of countable sets is countable, but even a countably infinite product of countable sets may not be countable.
Let [tex]X[/tex] be a countable set. Then [tex]X^{n}[/tex] is countable for each [tex]n \in N[/tex].
Now it should also be true that [tex]\bigcup^{\infty}_{n=1} X^{n}[/tex] is countable. How is this different from [tex]X^{\omega}[/tex], which is uncountable?
Ah, very good question. Let's take a look at this question with [tex]X=\mathbb{N}[/tex]. You first mentioned
[tex]\bigcup{X^n}[/tex]
The elements of these set are all the finite tuples. So examples include (1,2), (3,4,2000),... Of course, if you add zero's to the end, then you obtain an element of [tex]X^\omega[/tex]. So (1,2) corresponds to (1,2,0,0,0,...) and (3,4,2000) corresponds to (3,4,2000,0,0,0,...).
So it is easily seen that every element of [tex]\bigcup{X^n}[/tex] can be represented by an element of [tex]X^\omega[/tex]. And it is also easy to see that such elements are exactly the elements ending with a trail of 0's. For example: (1,1,1,0,0,0,...) corresponds to (1,1,1)...
But, and here comes the clue: there are much more elements in [tex]X^\omega[/tex]. For example: (1,1,1,...) does not come from an element of [tex]\bigcup{X^n}[/tex]. Other examples are (1,2,3,4,...) or (2,7,1,8,2,...). This shows that there are a huge number of elements in [tex]X^\omega[/tex]! And so [tex]X^\omega[/tex] really is different than [tex]\bigcup{X^n}[/tex].
Of course, this is not a proof. But it merely gives an indication why the two sets are different...
Yes, after thinking about it I came to the same conclusion. You can't put them in bijective correspondence because if you wanted to map the union onto [tex]X^\omega[/tex] you could do so injectively by adding 0s but there's no way to make this mapping surjective.
i believe the standard cantor argument shows even a countable product of the set {0,1} is uncountable, i.e. the set of all sequences of 0's and 1's.
Exactly, hence why this was a seeming contradiction.
What's the contradiction that you're referring to?
It's already been stated that the needed bijection doesn't exist. I'm not following you're argument...
What is the difference between a countable union of countable sets and a countable product of countable sets?
A countable union of countable sets refers to the combination of multiple countable sets into one set, while a countable product of countable sets refers to the Cartesian product of multiple countable sets. In other words, a countable union of countable sets is a set of elements that are themselves sets, while a countable product of countable sets is a set of tuples of elements from each set.
Can a countable union of countable sets be uncountable?
No, a countable union of countable sets will always be countable. This is because a countable set means that its elements can be put into a one-to-one correspondence with the natural numbers, and a union of countable sets will still have the same number of elements as the individual sets being combined.
Is a countable product of countable sets always countable?
Yes, a countable product of countable sets will always be countable. This is because the Cartesian product of two countable sets is still countable, and this property holds true for any number of countable sets being multiplied together.
What are some real-life examples of countable union of countable sets and countable product of countable sets?
One example of a countable union of countable sets is the set of all positive even numbers, which can be seen as a union of the sets of even numbers from 2 to 4, from 6 to 8, and so on. An example of a countable product of countable sets is the set of all possible outcomes when rolling two six-sided dice, which can be seen as the Cartesian product of the set {1, 2, 3, 4, 5, 6} with itself.
Why are countable union of countable sets and countable product of countable sets important in mathematics?
Countable union of countable sets and countable product of countable sets are important concepts in mathematics because they allow for the representation and manipulation of infinite sets. They also have applications in various fields such as computer science, probability, and topology.
