Proof of common sense when maths is lacking concept
In summary, the conversation is discussing the relationship between power consumption and resistance in electrical appliances. The length of time an appliance is on does not affect the rate of energy consumption. The correct term for power at a constant voltage is (I^2)*R, not I*R. A smaller resistance will consume more power according to (V^2)/R. However, this model does not take into consideration the distinction between resistance and impedance in AC circuits. Therefore, the size and number of windings in a motor can affect its power consumption.
  • #36
toneboy1,
So to summerise, the more resistance of a load on a motor, the more it increases the current, which makes it use more power.
You still don't have it quite right. Yes, you can stall the motor and draw a fuse popping, wire burning, switch melting amount of current, but if the current is not in phase with the voltage across the motor, the power will not appear. I tried to explain that with my inductor example previously.
So if it's an ac motor it will change the phase of the voltage or current,
All motors will change the phase of their voltage/current if they have inductance.
so the peaks will be closer
The peaks are determined by the line frequency. That usually does not change.
and I*V will be bigger,
The power will be greater because the voltage and current are in phase longer.
or if its DC then the back emf will decrease and it will use more power.
The "back EMF" is due to the collapsing magnetic field. Any motor type that uses inductance will have a back voltage. A motor will use more power if its voltage and current are in phase during more of the rotation cycle.
COOL. Exactly the sort of explanation I was looking for.
Are you sure about that?
If any of you (possibly clever engineers) could, I have an algebraic nightmare (a few of them) in this thread: https://www.physicsforums.com/showthr...=1#post4165324
I'd REALLY appreciate some help!
You should start a new thread in the math section for that problem.
Ratch
  • #37
It would be a great idea if this problem could be sorted out for Resistive Loads first. When we've got that all straightened out then we could move on to inductive and rotating loads. These are much more complicated and certainly not to be leaped into without getting the basics first.
For resistive loads, all you need to thing of is
1) P = IV : the Power relationship
and 2) R = V/I : the way we define Resistance
Combine these two together and you get two more useful formulae:
3) P = V2/R
and
4) P = I2R
Those four formulae will give you the answer to all possible questions about resistance, power and the way it can be supplied.
3) shows you that the power delivered (and used) goes down as the resistance is increased.
4) shows how the power lost in a supply wire, for instance, will increase as the resistance of the wire increases (that's if you keep the current the same)
  • #38
toneboy1 said:
On the contrary, it means more ohmic resistance, but what I'm saying is that say a fan would have LESS resistance than a heater but still use LESS power, or am I wrong, is a fan actually manifold more resistive?
Correct, your fan's motor could have less resistance and yet still use less power. Indeed, as an experiment you could make your motor windings have almost no resistance by using pure gold wire, an almost perfect conductor, and the fan would still draw less current* and use less power than the heater.
This is because the current in a fast spinning fan is largely not determined by the windings' resistance. As others have pointed out, the electrical model for a fan is not simply a fixed resistance and nothing else. It's that "something else" that is the key to explaining why it is that motors use more power the harder they work. http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon6.gif
  • #39
Thanks Windadct. Rach: "The power will be greater because the voltage and current are in phase longer." good way to put it, but I didn't necessarily mean stall the motor, just slow it down.
"The "back EMF" is due to the collapsing magnetic field" Ah, right, ofcourse, thanks.
As for the thread in the math section, I did, but I from what I've seen the people here stand a better chance of allowing me to figure it out.Thanks sophiecentaur, I think I've got the purely resistive relationships down and as far as I'm aware the phase relationship of an ac motor too.
The only possible area of lacking I feel might be possible is the way the EMF reduces the current in a DC motor. That said I'm still satisfied.
  • #40
TB1,
You really need to get a computer program that can do equations like that. Otherwise you can spend hours and hours spinning your wheels and probably making lots of mistakes. I think there are some trial programs and freebies on the web from outfits like Wolfram, but I am not sure. Anyway, the first thing to do is rationalize both sides of the equation and see if they match. Rationalize means no complex terms in the denominator. That is a lot of work, but if they do match, then you proved they are equal and are finished. You rationalize the left side by first calculating a common denominator, and then multiply the numerator and denominator by the conjugate of each complex term in the denominator. Collect similar terms whenever you can. That is a lot of scut work, but it shows if the equations match. As you can see from the attachment, the right side should be twice what the rationalization shows to equal what the left side is, so the problem equation is wrong. You might be tempted to look for shortcuts by finding equal terms in the numerator and denominator, but for an equation that complex, you will probably just get tangled up trying to take advantage that situation. I think, to just do it systematically. (Ugh)
Ratch
  • #41
Ratch said:
TB1,
You really need to get a computer program that can do equations like that. Otherwise you can spend hours and hours spinning your wheels and probably making lots of mistakes. I think there are some trial programs and freebies on the web from outfits like Wolfram, but I am not sure. Anyway, the first thing to do is rationalize both sides of the equation and see if they match. That is a lot of work, but if they do match, then you proved they are equal and are finished. You rationalize the left side by first calculating a common denominator, and then multiply the numerator and denominator by the conjugate of each complex term in the denominator. Collect similar terms whenever you can. That is a lot of scut work, but it shows if the equations match. As you can see from the attachment, the right side should be twice what the rationalization shows to equal what the left side is, so the problem equation is wrong. You might be tempted to look for shortcuts by finding equal terms in the numerator and denominator, but for an equation that complex, you will probably just get tangled up trying to take advantage that situation. I think, to just do it systematically. (Ugh)
Ratch
Thanks, well I had no reason to think they wouldn't be the same, but you're saying they're not equal? That shouldn't be, are you sure?
For argument's sake if I just had the LHS and wanted to reduce it to the form of the RHS would I still have to do the conjugate times numerator and denominator? (surely not)
I was just looking for the simplest way to solve the LHS without expanding into 25 term polynomials and having to factorise cubics.
I've used wolfram on the net and I have MATLAB and I think maple (which I've never used) but I don't know what I'd use to show me how to solve anything like that.
  • #42
TB1,
Yes, I am. I used Maple, and it has never given me a wrong answer. I rationalized both the RHS and the LHS, and they don't come out equal. You can spend a lot of time trying to wrestle one expression into another, especially if they are not equal. There are a zillion alternative ways to represent an expression, but if you know the end result, it is best just to determine if they are equal and walk away.
To do it the hard way, first rationalize it. Then multiply the numerator by a hairy factor to get what you want in the numerator. Multiply the denominator by the same factor to keep everything equal. Simplify the denominator. Then use the terms in the denominator, and factor if necessary to create your own expression. You have to use all the denominator terms, and cannot use extra terms. Of course, you can use the computer to subtract the terms you use, and factor if necessary. The choices are many.
You are not solving an equation. You are proving an equality.
Sounds like you are well stocked with software.
Ratch
  • #43
Thanks for pointing out that they're not equal, I could have wasted even more time.
I'll have to give maple a go when I get a chance. To varify.
To clarify, these two steps were in someone's working out, and I didn't know how they got from LHS to RHS, it wasn't a question of proove they're equal or not (if there's been a misunderstanding). I still don't see how I'd factorise the denominator to get it like ()^2 + ()^2 from the denominator of your (1). To do this it doesn't matter if there are j's in the denominator.
  • #44
TB1,
You can see from the attachment that I used the rationalize function of Maple. I would have thought that Matlab and the Wolf could do what Maple did. Maple can factor expressions, but that is not necessary to rationalize an expression, even if you do it manually. You need to multiply by conjugates to get rid of complex terms in the denominator. Then use the procedure I outlined previously to make any expression that is possible from the terms in the denominator.
Ratch
  • #45
Ratch said:
TB1,
Ratch
I'm sure there is a way with them but I'm not that proficient yet (matlab wolf).
I don't see why it's necessary to eliminate all the complex numbers on the denominator or how it could be factorised to that, given the highest exponent of the solution saught will be 4, not 8. I could factorise the two term part by completing the square, but as for the 3 term polynomial squared, I wouldn't know where to start...Thanks for your help anyway.
  • #46
Sorry for trying to teach my Grandmother to suck eggs! :smile:
Reading this thread reminds me how similar electric motors and radio antennae behave (and even loudspeakers). The up-front resistance is usually just not relevant to their performance - a dipole is an 'open circuit' but it can look like a useful 70Ω at the right frequency. Electrical resistance turns up where you'd least expect it but Energy Conservation requires it.
The Back EMF is only a 'way of looking at it', I think. There must be an alternative way of looking at it involving self inductance of a rotating machine.
  • #47
TB1,
Like I said before, the back voltage is caused by the collapsing magnetic field when the current changes direction. It shouldn't be hard to imagine a "bucking" voltage going against the source voltage to reduce its value and lowering the current. It is a physical happening, and needs no alternative way at looking at it. The constant shift of electrical energy from the circuit to the inductor and back again also causes a current/voltage phase shift associated with inductive reactance.
Ratch
  • #48
TB1,
Just to follow up on your previous question about that math expression. If you look at equation (6) of the attachment, you can find an alternative form of that expression. If fact, there are many different forms. Once you have the denominator rationalized, you can use partial fraction expansions. Then the number of different expressions is only limited by your imagination.
Ratch
  • #49
I'm going to throw in my 2 cents here because I think there's a small misconception with regards to self-inductance and its significance.
Let's consider a single winding of an AC motor which we'll model as a resistor in series with an inductor. It's true that a changing current through the winding will produce an opposing voltage in proportion to the self-inductance of the winding, but this isn't what limits the current in the circuit as the angular velocity of the rotor increases.
Be it a DC or an AC motor, as the motor speeds up, the current is limited by the voltage produced by the increasing rate of change of magnetic flux through the winding, due to the increasing angular velocity of the rotor field. It's this component of induced voltage that's usually termed 'back-EMF' in motors.
  • #50
milesyoung,
Be it a DC or an AC motor, as the motor speeds up, the current is limited by the voltage produced by the increasing rate of change of magnetic flux through the winding, ...
I don't understand. First you say that the opposing voltage does not limit the current. Then you say that the voltage does limit the current. What's an inquiring mind to think?
Ratch
  • #51
Give it a second read-through - in the simplest case there are two causes of changing magnetic flux in the winding. One is a change in current in the circuit - the other is a change in the angular position of the rotor. The latter is what limits the current.
Edit: And just clarify further, I'm talking about two different components of opposing voltage - that's my whole point.
  • #52
milesyoung,
I did, several times.
OK, I believe you are referring to the change caused by the alternating line voltage.
Are you sure you don't mean the angular velocity of the rotor?
A big inductance coil does not have a rotor, and yet it limits current. In any case, anything that causes a conductor to cross a magnetic flux in a perpendicular manner will generate a voltage in the conductor.
Ratch
  • #53
I'm talking about a change in instantaneous current.
No (edit: As in, yes I'm sure :). A change in rotor position will change the magnetic flux through the winding and induce a voltage. A change in velocity will chance the rate of change of magnetic flux through the winding.
A big inductance coil does not have a rotor, and yet it limits current. ...
Yes but this isn't what limits the current as the angular velocity of the rotor increases. How could it? This voltage isn't a function of anything that has to do with the rotor. It's only a function of the rate of change of current in the winding, considering the self-inductance of the winding to be constant.
How else would you explain an increasing opposing voltage in a DC motor? For a constant current the inductive voltage drop associated with the self-inductance is clearly not present.
  • #54
milesyoung,
Caused by?
A change of position is velocity, a change of velocity is acceleration.
Partly by inductive reactance, whether the rotor is turning fast or slow.
Are we still talking about the back-voltage?
Stator winding or rotor winding?
Permanent magnet DC motor? OK, then rotor winding. So both the rotation of the rotor and the switching of the commutator can change the current.
Yes, changing current with constant inductance produces voltage proportional to current change. Now, what all can change the current? Rotation and the commutator?
The current may be constant from the source, but the commutator changes its direction in the rotor.
Ratch
  • #55
Caused by?
Why does it matter?
I wrote "change in the angular position of the rotor". If I replace "position" with "velocity", which I would argue your response would ask me to consider, the statement is false.
Yes _partly_ if the instantaneous current is changing - which it isn't necessarily in a DC motor. The effect that's limiting current in your "big inductance coil" might also be present, but this is not what is the limiting factor that increases with the angular velocity of the rotor and it's not usually what would be called "back-EMF" in motors.
Back-EMF is a confusing term because its used by different people to describe different things. Usually it means the part of the "back-voltage" that's dependant on the angular velocity of the rotor but some will lump the voltage produced by a change in the instantaneous current in with it.
Stator winding. Why would it have something to do with the rotor winding?
It can certainly not change the current in the stator winding (that would make it AC), which is where the back-EMF appears.
Again, I have no idea why you would bring the commutator into this - we're naturally talking the stator winding.
Edit:
Ah sorry I completely missed the "Permanent magnet DC motor" part. In that case I'm referring to the part of the rotor windings on the stator side of the brushes (which sees no alternating current).
  • #56
It would be better to consider a permanent magnet motor first, surely - there is no stator winding. A brush motor with a permanent field magnet will behave just like a dynamo. By Lenz's law, the EMF generated by such a dynamo will be 'such as to oppose its cause' i.e. it will be against the polarity of the supply volts. The commutator is necessary for this to happen and it is, of course, necessary for the motor to be turning in the first place.
If you want a stator winding then, as this passes DC (series or shunt connection) will that affect or produce any 'back EMF'? I don't think so.
The load on the motor is what limits the speed of the motor and that governs the difference between supply voltage and back EMF, which determines the current that can flow through the resistance of the rotor. The resistance that the supply 'sees' would be supply volts / rotor current.
For a series wound motor, the field current will drop as the speed builds so the speed regulation is not so good.
  • #57
You're absolutely right, consider the simple DC-motor model which probably needs no introduction:
http://www.library.cmu.edu/ctms/ctms/simulink/examples/motor/motorsim.htm
Let the motor be loaded so the rotor has a constant angular velocity and let the current in the circuit be constant in magnitude. Would you say the back-EMF in this case has anything to do with the self-inductance L?
  • #58
If you were to increase the supply volts, the current would increase significantly until the revs built up, a reducing the current to slightly more than before. That looks, to me, mighty like a big parallel capacitor, relating to the MI of rotor and load.
  • #59
I'm not quite sure what you mean. I can't see how you could argue that the induced voltage from flux cutting the rotor windings could be attributed to self-inductance.
  • #60
heh, it wasn't quite like that. Thanks for the interesting input.
Ratch said:
TB1,
Ratch
So you're saying I could force it into that form after partial fractions, interesting.
THOUGH it would take ages to even get to (1) if you didn't have a computer to aid in expanding and simplifying the fraction, wouldn't it?
Also, I don't quite see where H came from when you introduced it.
Thanks
  • #61
TB1,
Yep, lots of work without a computer. But you can see that eq(6) is the same equation as eq(1).
After rationalizing the left side, I multiplied the numerator by what it took to make it look like the right side. The multiplier was "H". Of course, I also had to multiply the denominator by the same multiplier to balance the fraction out.
Ratch
  • #62
'Equivalent Circuits' don't always make physical sense, I know, but when you start a motor, a lot of energy goes in. The rate of current reduction will be exponential with a time constant. That can be modeled with a CR series circuit across a parallel resistor. It's a simplification but it even works as the supply volts are reduced.
  • Electrical Engineering
11K
24K
