Linera Expansion and heating from a stream of electrons
In summary,A thin square tungsten foil, 10mm x 10mm, is supported in the centre of a vacuum chamber by thin wires which have negligible thermal conductance.Two parallel slits, 1\mum wide and 1mm long and whose centres are separated by 6.6\mum, have been cut in the foil.The foil is now heated by electron bombardment with a 10mA current of 5keV electrons, whose energy is completely absorbed by the foil.Calculate the change in separation of the slits.
TFM
1,026
A thin square tungsten foil, 10mm x 10mm, is supported in the centre of a vacuum chamber by thin wires which have negligible thermal conductance. A cooled shield surrounds the foil such that its initial temperature is -37 C. Two parallel slits, 1[tex]\mu[/tex]m wide and 1mm long and whose centres are separated by 6.6[tex]\mu[/tex]m, have been cut in the foil. The foil is now heated by electron bombardment with a 10mA current of 5keV electrons, whose energy is completely absorbed by the foil. Calculate the change in separation of the slits.
How would you go about measuring this change in separation from outside the vacuum chamber?
For tungsten, the emissivity should be taken as (1/5.7) and the coefficient of linear expansion as 5 x [tex]10^{-6} K^{-1}[/tex]. (The linear expansion coefficient [tex]\alpha[/tex], is defined as the fractional change in linear dimension per degree Kelvin, i.e. [tex]\alpha = \DeltaL/L0[/tex] where [tex]\Delta[/tex]L is the change in length for a 1K change in temperature and L0 is the original length.)
[tex] \frac{\Delta L}{L_0} = \alpha \Delta T[/tex]
Okay, so to get the change in length, Delta L, I need the formula
[tex] \Delta L = L_0 \alpha\delta T [/tex]
However, I am unsure how to get T.
When I saw that there was a current, I thought of using the power law
P = VI
and
V=IR
but we are not given any resistance. we are given the energy of each electron, But I am unsure how to get through to the current.
TFM
Since you have V and I, you can calculate P. R is not needed.
Where are we given the voltage? I know the electrons have 5 keV, but I thought this was an energy not a voltage...?
True, 5 keV is an energy.
What voltage would give an electron an energy of 5 keV?
well, 1 electron volt is the energy to get a electron through a p.d. of 1 volt,
so there is a voltage of 5kV then.
so now,
[tex] VI = P [/tex]
[tex] P = 5000 * 10*10^-3 = 50 Watts [/tex]
So this is the energy per second
so do we need to find out how long the bombardment lasted?
Yes, 50W is right. Good.
Good question.
They don't say anything about how long it lasts. The do tell us the emissivity of tungsten. That's a hint that radiation is playing a role here.
Okay, well, for Blackbody radiation,
[tex] j = \sigma T^4 [/tex]
j = power over area, therefore,
[tex] T^4 = \frac{P}{a\sigma} [/tex]
However, the emissivity is the ratio of energy emitted by object compared to the energy emitted by a perfect Blackbody.
therefore
[tex] 1/5.7j = \sigma T^4 [/tex]
[tex] T^4 = \frac{P}{5.7 a\sigma} [/tex]
So this gives:
[tex] T^4 = \frac{50}{5.7 (0.01*0.01 - 2(0.001*0.000 001))\sigma} [/tex]
[tex] T^4 = \frac{50}{5.7 (0.0001 - 0.000000002)\sigma} [/tex]
[tex] T^4 = \frac{50}{5.7 (0.000099998)\sigma} [/tex]
[tex] T^4 = \frac{50}{3.23*10^{-11}} [/tex]
[tex] T^4 = 1.55*10^{12}} [/tex]
[tex] T = 1115K = 841 C [/tex]
Does this look right?
Pretty close! Two little errors to correct:
j = ε σ T4 = (1/5.7) σ T4 A real object radiates less than a blackbody
Also, the square foil has 2 sides, so total surface area is ___?
p.s. I'm logging off the forum for a while ... good luck!
Oka the area of the foil plate is 10mm x 10mm = 0.0001m^2
However, the two cuts have a total area of 0.000000002 m^2
Thus the total area is 0.000099998 m^2
So for both sides,
Area = 0.000199996m^2
[tex] P = A\epsilon \sigma T^4 [\tex]
[tex] \frac{P}{A\epsilon \sigma} = T^4 [\tex]
[tex] \frac{50}{0.000199996 * \frac{1}{5.7}*5.67*10^{-8}} = T^4 [\tex]
[tex] T^4 = 2.5 * 10^{13} [/tex]
[tex] T = 2239K = 1966 C [/tex]
So I presume this is the final Temperature, so
[tex] \Delta L = L_0 \alpha (T_f - T_i) [/tex]
[tex] \Delta L = 6.6*10^{-6} *5*10^{-6} (1966 - 37) [/tex]
Gives a change in length of 6.37 * 10^-8 (657 micro meters)
Does this look okay?
Very close!
If you subtract -37 from 1966 °C, that's the same as adding ____ °C.
6 x 10-8 m is how many μm? Or, how many nm?
p.s. It's probably okay to neglect the area of the slits, since many quantities are given to just 2 significant figures.
Drat, I forgot it was minus 37. Thankfully, this is where Excelcomes in handy, just change one sign.
Gives 6.6 * 10^-8m = 66 nanometers
Excellent. I now need to figure how to measure the difference. I am assuming a ruler won't be of any use (How would you go about measuring this change in separation from outside the vacuum chamber?)
This seems though such a small change in seperation. Would a laser be useful?
Yes, a laser would be extremely useful.
Are you aware of an experiment that involves a laser -- or any single-wavelength source of light -- and two closely-spaced slits?
The Youngs Double Slit experiment.
As the slits become wider, the destructive and constructive interference spots will move.
Excellent.
Well, Thanks a lot for your assistance, Redbelly98
1. What is linear expansion?
Linear expansion is the increase in length of a material when it is heated. This is due to the increase in kinetic energy of the particles in the material, causing them to vibrate and take up more space.
2. How does heating from a stream of electrons affect linear expansion?
When a material is heated by a stream of electrons, the electrons transfer their energy to the particles in the material, causing them to vibrate more and thus increasing the material's length. This is known as thermal expansion and is a common occurrence in many materials.
3. What factors affect the linear expansion of a material?
The linear expansion of a material is affected by its coefficient of linear expansion, which is a measure of how much its length will change per unit of temperature change. It is also influenced by the material's initial length, temperature change, and the composition of the material.
4. How is linear expansion measured?
Linear expansion is typically measured using a device called a dilatometer, which tracks the change in length of a material as it is heated. The coefficient of linear expansion can be calculated by dividing the change in length by the initial length and the temperature change.
5. Why is understanding linear expansion important in materials science?
Understanding linear expansion is crucial in materials science as it allows us to predict how a material will behave when exposed to changes in temperature. This is important in the design and manufacturing of structures and devices, as well as in the study of thermal properties of materials.
11K
