Finding a vertical distance of niagara falls?
  • Thread starter ob123
  • Tags
    Vertical
In summary: Then using the Pythagorean theorem, solve for the magnitude of the vertical component, which will also be the magnitude of the vertical displacement from the top of the waterfall.In summary, the problem involves finding the vertical distance below the edge of Niagara Falls where the velocity vector of water points downward at a 61.8 degree angle below the horizontal. Using the given initial horizontal velocity of 1.42 m/s and the angle, a right triangle can be constructed to represent the velocity vector. By setting the angle and using the Pythagorean theorem, the magnitude of the vertical component can be found, which is also equal to the vertical displacement from the top of the waterfall.
ob123
Suppose the water at the top of Niagara Falls has a horizontal speed of 1.42 m/s just before it cascades over the edge of the falls. At what vertical distance below the edge does the velocity vector of the water point downward at a 61.8 ° angle below the horizontal?
Not sure
Initial velocity(u) of Niagara falls = 1.42 m/s
Angle(θ) at which it strikes the ground = 61.8o
Formula used: tan(61.8) = sq.rt(2*9.8*x/1.42)
I solved for x and got .252 m but the answer is wrong. Now I have no idea on what to do. Any help would be appreciated. Thank you.
Remember the following: the horizontal component of the velocity will never change (assuming we are only dealing with gravity). So what you need to do is find the vertical velocity that will make the velocity vector point at the desired angle. Then recall from kinematics:
vf2=vi2+2*g*d
vf is the final velocity
vi is the initial velocity
g is the acceleration due to gravity
d is the distance travelled
of course this is all for the vertical components, and vi is zero, so you just have to solve for d.
okay but how do i find the vertical distance, I am barely on my 4th day of physics so I really do not know much. But I got these hints off my book, but I have no idea how to translate what it says into a drawing.
Sketch an arrow that represents the velocity vector after the water has fallen some vertical distance. It should be angled downward. Construct a right triangle whose hypotenuse is the velocity vector of the water, and whose sides are the vertical and horizontal components of the velocity, and . The horizontal component of the velocity is known. Use the Pythagorean theorem to solve for the magnitude of the vertical component of the velocity.
Once the vertical component of the velocity is known, use the equations of kinematics (table 3.1) to solve for the vertical displacement from the top of the waterfall. The magnitude of the vertical displacement is equal to the distance below the edge of the waterfall.
That hint your book gives you is essentially what I have told you, except I go farther and give you the equation. So you are having trouble drawing the diagram. Ok, well consider that you have two components to the velocity of the water falling from the cliff, a component in the horizontal direction (IE parallel to the ground) and a component in the vertical direction (IE perpendicular to the ground.) So draw two lines connecting at a point, but perpendicular to each other. These are the components of the velocity of the water. Now join them with a third line to make a triangle, and this is the velocity vector. So now all you need to do is set the appropriate angle to 61.8 degrees, and this will set the length of the vertical component, because the horizontal component is already known, and you have an angle at 90 degrees as well.
1. How is the vertical distance of Niagara Falls measured?
The vertical distance of Niagara Falls is measured using a combination of topographical maps and precise measurements taken from the top and bottom of the falls. This is done by trained professionals using specialized surveying equipment.
2. What is the current estimated vertical distance of Niagara Falls?
The current estimated vertical distance of Niagara Falls is approximately 167 feet, based on recent measurements taken in 2016. However, this measurement can vary due to natural erosion and other factors.
3. Has the vertical distance of Niagara Falls changed over time?
Yes, the vertical distance of Niagara Falls has changed over time due to natural erosion and human intervention. In the 1800s, the falls were estimated to be 176 feet, but have since decreased to its current estimate of 167 feet.
4. How does the vertical distance of Niagara Falls affect its overall height?
The vertical distance of Niagara Falls is just one aspect of its overall height. The falls also have a horizontal distance, which adds to its total height. The vertical distance is important for measuring the rate of erosion and understanding the geology of the falls.
5. Is there a way to accurately measure the vertical distance of Niagara Falls from a distance?
Yes, there are methods to accurately measure the vertical distance of Niagara Falls from a distance. One way is by using aerial photography and satellite imagery to create a 3D model of the falls, which can then be used to calculate the vertical distance. However, on-site measurements are still the most accurate method.
