Why are heilicty and chirality equivalent for massless particles?
In summary: Going to a different frame via a Lorentz boost is a different story though (note again that you don't have to "actually" "overtake" the particle, since "you" are not anywhere in the math) because then the particle's momentum would be reversed and it would have a different (new) helicity.
Superposed_Cat
388
Salutations, question:
For massless particles—such as the photon, the gluon, and the (hypothetical) graviton—chirality is the same as helicity; a given massless particle appears to spin in the same direction along its axis of motion regardless of point of view of the observer.
~wikipedia. I'm assuming that's because (correct me if I'm wrong) those particles would travel at c and you could not overtake them so their chirality and helicity are equal.But if a photon was coming towards you then zoomed past you surely the chirality would change because you now see it going away from you?
It is now going away, but the spin also changed its radial direction: if it was oriented towards you before, it will be oriented away from you afterwards, and vice versa.
Or, in other words, the spin is always in the direction of motion or against, and this does not change.
But then why does it change for massive particles?
does it change for massive particles? The chirality does not coincide with helicity, because chirality symmetry is explicitly broken
helicity sorry. why does for massive particles?
Please don't take this the wrong way, but do you know what either helicity or chirality are? From your questions, it doesn't look like you do.
No worries I take no offence. I just no what i read on the wiki.
Usually people understand one and are confused about the other. (And answering the question hinges on finding which one they understand) But if you don't know what either of them are, it will be difficult to explain the difference.
In fact, can't your just write your state as a superposition of helicity eigenstates, and then look at how it transforms under a lorentz transformation to see that?
Likes 1 person
V-50 I was wondering why they said you can't change your reference frame because you can't overtake it. Surely if it flyies past you it is the same as overtaking it?
P.S. thanks chrisver
Chirality (aka handedness) = ±1 is the eigenvalue of γ5. It's a Lorentz invariant, but for a particle with nonzero m it's not a constant of the motion, i.e. [H, γ5] ≠ 0.
Helicity = ±1 is the eigenvalue of σ·p/|p|. For a free particle it's a constant of the motion, but clearly not a Lorentz invariant.
The easiest way to see the relation between the two is to follow Peskin-Schroeder and use the Weyl representation, in which γ5 is diagonal,
[tex]\gamma^5 = \left(\begin{array}{cc}-1&0\\0&1\end{array}\right)[/tex]
The eigenfunctions of γ5 corresponding to ±1 are denoted ψR and ψL, respectively. In terms of ψL and ψR the Dirac equation is
[tex]\left(\begin{array}{cc}-m&E + \sigma \cdot p\\E - \sigma \cdot p&m\end{array}\right) \left(\begin{array}{c}\psi_L\\\psi_R\end{array}\right) = 0[/tex]
and so for m = 0 we have that ψR and ψL are also eigenstates of helicity, σ·p = ±E.
No, when you overtake a particle, you're moving faster than the particle and in your reference frame the particle is seen moving the opposite direction reversing its helicity. When a particle overtakes you you still see the particle moving in the same direction with no helicity reversal.
Likes 1 person
Thanks all esp. dauto
And perhaps to make it even more obvious, there is no preferred "centre" of a reference frame, i.e. nothing explicitly stating where "you" are relative to the particle. x=0 is not special. So nothing you measure about the particle is going to change as it zooms past some arbitrary location, except it's position of course.
Related to Why are heilicty and chirality equivalent for massless particles?
1. What is the significance of helicity and chirality for massless particles?
The concepts of helicity and chirality are important in understanding the behavior and properties of massless particles, particularly in the field of quantum mechanics. Helicity refers to the spin of a particle along its direction of motion, while chirality refers to the symmetry of a particle's spin with respect to its direction of motion.
2. Are helicity and chirality equivalent for all types of particles?
No, helicity and chirality are only equivalent for massless particles. For massive particles, the two concepts are not equivalent and must be considered separately.
3. How does helicity affect the behavior of massless particles?
Helicity has a significant impact on the behavior and interactions of massless particles. It determines the direction of their spin and can affect their stability, decay, and interactions with other particles.
4. Can the helicity of a massless particle be changed?
Since helicity is determined by the direction of a particle's spin, it cannot be changed for a massless particle. This is because a massless particle always travels at the speed of light, and therefore its direction of motion cannot be altered.
5. Why are helicity and chirality equivalent for massless particles?
This equivalence is a consequence of the nature of massless particles, which always travel at the speed of light and have zero rest mass. In this case, their spin and direction of motion are intrinsically connected, resulting in the equivalence of helicity and chirality.
  • High Energy, Nuclear, Particle Physics
  • Quantum Physics
  • Atomic and Condensed Matter
  • Quantum Physics
