Converting a Lead Acid Battery to Alkaline
In summary, the conversation discusses an interesting article on how to convert a standard lead acid battery into alkaline, which claims to increase capacity and withstand deep discharges better. There are testimonials of both success and failure with this conversion, and there is a question about the scientific explanation and whether everyone should convert their lead acid batteries. One person points out that the claim of these batteries being clean is incorrect as the lead electrodes are still present in the converted battery.
nobb123
I came across this interesting article to convert a standard lead acid battery into alkaline:
http://blog.hasslberger.com/2007/01/how_to_convert_a_lead_acid_bat.html
Seems very promising. Not only does the capacity increase slightly, but the battery also withstands deep discharges much better than a conventional lead acid. Still charge with approximately the same voltage. Perfect right? There are a few testimonials of the success and failures of people attempting this conversion.
I am just curious as to what you guys think. Would love to hear an intelligent opinion on this matter.
No idea what is the chemistry behind, but claim that these batteries are clean is plainly wrong - if you convert an old acid battery, it still contains the same lead electrodes.
Well actually, I was most interested in the fact that they claim these batteries can be cycled more deeply than conventional lead acid. Just wondering if there was a scientific explanation and why everyone shouldn't convert their lead acids.
Related to Converting a Lead Acid Battery to Alkaline
1. Can a lead acid battery be converted to an alkaline battery?
Yes, it is possible to convert a lead acid battery to an alkaline battery. However, it requires several steps and is not a recommended practice.
2. Why would someone want to convert a lead acid battery to an alkaline battery?
Some people may want to convert a lead acid battery to an alkaline battery because they believe it will increase the battery's lifespan or performance. However, there is no scientific evidence to support this claim.
3. What are the steps involved in converting a lead acid battery to an alkaline battery?
The process of converting a lead acid battery to an alkaline battery involves removing the electrolyte from the lead acid battery and replacing it with an alkaline electrolyte. This is typically done by dissolving potassium hydroxide in distilled water and then filling the battery with this solution.
4. Is it safe to convert a lead acid battery to an alkaline battery?
No, it is not safe to convert a lead acid battery to an alkaline battery. The process involves handling corrosive materials and can be dangerous if not done properly. It is also not recommended as it can damage the battery and may not provide the desired results.
5. Can a converted alkaline battery be used in the same way as a regular alkaline battery?
No, a converted alkaline battery may not perform the same as a regular alkaline battery. The conversion process may not be effective in producing a fully functional alkaline battery, and there is also a risk of leakage or explosion due to the change in electrolyte. It is best to use batteries that are specifically designed and manufactured as alkaline batteries.
  • Electrical Engineering
9K
9K
  • Art, Music, History, and Linguistics
  • General Discussion
