Doubt regarding removing of electrons from shells
In summary: The rules for determining electron configuration only apply to neutral atoms, not ions. As for the correctness of the configuration, it may be right for a neutral Cu atom, but not necessarily for a Cu2+ ion. As mentioned before, the coordination environment of the ion will affect the energy levels and the order in which they are filled.
Cu - 1s2 2s2 2p6 3s2 3p6 4s1 3d10
Cu2+ - 1s2 2s2 2p6 3s2 3p6 4s0 3d7
This is the configuration of the respective atoms and ions..
According to Aufbau's principle.The subshells with lesser energies get filled first !
Which means 4s sub shell is filled and only after that 3d10 sub shell is filled because the energy of 3d subshell is be greater than 4s subshell ie.4s < 3d energy.
Now if we are removing electrons and converting Cu to Cu2+ it means that energy should be provided to remove the electrons,If that is the case then.
Since, 3d subshell has more energy than 4s orbital,therefore less energy will be required for removing electrons from 3dorbital because they already have greater energy than 4s orbital..
But 4s electrons are removed while ionizing ..How ?
I hope you understood my question...Please giveme a rpoper reason for this..
Thanks,
-5416339
Chemistry news on Phys.org
Correct. (it's the aufbau principle BTW, 'aufbau' means 'building up' in German)
But this is at odds with what you just said. The 4s shell should be filled before the 3d shell.
Well I'm not 100% sure of the configuration you gave. But more importantly: It's not really important.
See, Madelung's rule and such are only approximate rules. There are many exceptions. (the mentioned [Ar]4s13d10 configuration for neutral copper being one. Filling the final 'd' orbital gives a reduction in energy which makes it more stable than having [Ar]4s23d9. Filled and half-filled orbitals have additional stability due to Unsöld's theorem) The ordering of the levels isn't constant at all, change the number of electrons and their internal order changes. (e.g. K has 4s1 but Ar-, with the same number of electrons puts the last one in the p orbital!)
So it's not very predictable, except for these general rules that don't always hold. The reason why it's not so important is that the electron configuration is for a single atom in vacuum. In practice, you rarely have a Cu2+ ion in vacuum (and if you do, it's not really chemistry you're doing anyway). Once you have ligands surrounding the copper ion, the levels will change again depending on the coordination environment (ligand-field splitting). In the case of Cu, you have a Jahn-Teller axis as well.
In short, there's no easy way to predict the electronic structure of a transition-metal complex. But on the up side, you'll seldom be required to do so unless you're studying it at the more advanced level.
Thats fine ! But i don't think you have answered my question and the Configurations are right ! Don't know how !
Your question was fundamentally wrong. There's no reason to assume the ordering of the orbitals will be the same when you ionize the atom. Period.
Thank you for your question. The reason for the removal of electrons from the 4s orbital in the ionization of copper (Cu) is due to the concept of electron configuration and the stability of atoms and ions.
In the electron configuration of an atom, the electrons are arranged in specific energy levels called shells and subshells. The order in which these shells and subshells are filled is based on the Aufbau principle, which states that the subshells with lower energies are filled first before the higher energy subshells.
In the case of copper, the 4s orbital is filled before the 3d orbital because the 4s orbital has a lower energy than the 3d orbital. This is because the 3d orbital is further away from the nucleus and experiences more shielding from the inner electrons, resulting in a higher energy level.
However, when copper is ionized to form Cu2+, one electron from the 4s orbital is removed, leaving behind a partially filled 3d orbital. This is due to the fact that the 4s orbital is more easily ionized than the 3d orbital. This is because the 4s orbital is closer to the nucleus and experiences a stronger attraction, making it easier to remove an electron from this orbital.
Additionally, removing an electron from the 4s orbital also results in a more stable configuration for the ion. This is because the 3d orbital is now half-filled, which is a more stable configuration than having one electron in the 4s orbital and five in the 3d orbital.
In summary, the removal of electrons from the 4s orbital in the ionization of copper is due to the energy levels of the orbitals and the stability of the resulting ion. I hope this explanation helps to clarify any doubts you may have had.
Related to Doubt regarding removing of electrons from shells
1. How do electrons get removed from shells?
Electrons can be removed from shells through a process called ionization. This can occur through collisions with other particles, exposure to high-energy radiation, or through an electric field.
2. What happens to an atom when an electron is removed from its shell?
When an electron is removed from an atom's shell, the atom becomes positively charged, as it now has more protons than electrons. This process is known as ionization and can result in the formation of ions.
3. Can electrons be removed from any shell in an atom?
No, electrons can only be removed from the outermost shell, known as the valence shell. This is because the valence electrons are the most loosely bound and therefore easiest to remove.
4. Why is the removal of electrons from shells important in chemistry?
The removal of electrons from shells plays a crucial role in chemical reactions and the formation of compounds. It determines the reactivity and properties of atoms and allows for the formation of new molecules through the transfer or sharing of electrons.
5. What factors can influence the ease of removing electrons from shells?
The ease of removing electrons from shells can be influenced by factors such as the size of the atom, the strength of the nuclear charge, and the shielding effect of inner electrons. The type of element and its position on the periodic table can also play a role.
  • Chemistry
24K
  • Chemistry
14K
10K
  • Quantum Physics
90K
