How Does a Second Order High-Pass Filter Create Energy at Cutoff Frequency?
In summary: So in reality there would be power gain at resonance...If you mean in the time domain, then yes. Not in the frequency domain of the Bode Plot. You lose time-domain info in going to the Bode Plot, and that's what caused your initial confusion, I think.Not sure I follow that. Could you post the rest of your work, and what the circuit looks like?It's a second order high-pass filter. It looks like this.but without any concrete values for the components (it's an image I found on the Internet, not mine).
yoran
118
Hey guys,
I have a question about the Bode diagram of a second order high-pass filter (one with both a capacitance and an inductance). The Bode-diagram of the amplitude looks like this.
http://dave.uta.edu/dillon/pspice/images/pst07g.jpg
Here, the cutoff frequency is equal to about 10 kHz.
You see that the amplitude of the transfer function is greater than 1 at the cutoff frequency. But, since
[tex]P_u = |H(f)|^2 P_i[/tex]
where Pi is the power in and Pu is the power out,
then power is created since [tex]|H(f)|^2 > 1[/tex].
So if you apply a sinus with a frequency equal to the cutoff frequency to the filter, you create energy!
I know there must be a flaw in my reasoning but I cannot see where.
Thanks,
Yoran
First, that's a highpass filter, not lowpass. Second, the gain in the passband is shown to be 0dB, which means that the amplitude out equals the amplitude in. No energy gain.
Hi,
Sorry about that, I picked the wrong image. Anyway, the same thing happens for a high-pass filter. If you look at f=10 kHz, then you can see that the gain is actually higher than 0 dB...
yoran said:
Hi,
Ah, I think I see what you're asking now. To calculate the power, you need to plot both voltage and current, especially around that resonance... Can you intuit why there is no power gain at resonance now?
Oh, I think I see. The output voltage is higher than the input voltage, but then the output current must be a smaller than the input current?
I don't think that's quite it. Think about what the voltage and current are doing in a resonant LC circuit. When the voltage is peak, what is the current doing? When the current is peak, what is the voltage?
Isn't it so that when the voltage is high, the current is low and vice-versa?
Ah wait I think I see it. I worked the equations out at the resonance frequency and I get the result that the output voltage is pure imaginary ([tex]V(f_r) = \frac{j\omega_r L}{R}V_{in}[/tex]) while the current is pure real ([tex]I(f_r) = \frac{V_{in}}{R}[/tex]). As you said, then the real power is equal to the product which is zero then? Because the power is purely imaginary?
http://dave.uta.edu/dillon/pspice/images/pst07f.gif
I just realized I made a mistake. The current I gave at the resonance frequency is the current through the inductance, not the current through the output (when assuming that there is a load impedance parallel to the inductance).
Related to How Does a Second Order High-Pass Filter Create Energy at Cutoff Frequency?
1. What is a second order low-pass filter?
A second order low-pass filter is a type of electronic filter that attenuates high frequency signals while allowing low frequency signals to pass through. It is commonly used in audio and telecommunications systems to remove unwanted noise and improve signal quality.
2. How does a second order low-pass filter work?
A second order low-pass filter works by using a combination of resistors, capacitors, and inductors to create a circuit that allows low frequency signals to pass through while attenuating high frequency signals. The exact behavior of the filter is determined by the values of these components.
3. What are the advantages of using a second order low-pass filter?
One advantage of a second order low-pass filter is that it has a steeper roll-off (attenuation of high frequencies) compared to a first order filter, meaning it can more effectively remove unwanted noise. Second order filters also have a flatter passband (range of frequencies that are allowed to pass through) which can help preserve the original signal.
4. Are there any limitations to using a second order low-pass filter?
One limitation of a second order low-pass filter is that it can introduce phase shifts in the filtered signal, which may affect the overall quality of the output. Additionally, second order filters may be more complex and expensive to design and implement compared to first order filters.
5. How is a second order low-pass filter different from other types of filters?
A second order low-pass filter is different from other types of filters, such as first order filters or higher order filters, in terms of its frequency response and complexity. It has a steeper roll-off and flatter passband compared to first order filters, but may be more complex to design and implement compared to higher order filters.
  • Electrical Engineering
13K
34K
