Question About Shear Stress Naming Convention
In summary, the conversation is discussing the naming convention for shear stress \tau_{ij}, specifically in regards to a shaft of circular cross-section. The discussion touches on the use of indices i and j and whether they represent the plane containing the cross-section or the direction of the shear. The conversation also mentions the use of cylindrical coordinates and the confusion surrounding the definition of shear stress for the entire cross section versus a differential element. Ultimately, the conversation concludes that the shear stress is defined for differential elements in order to maintain equilibrium.
Saladsamurai
3,020
Question About Shear Stress "Naming" Convention
I cannot seem to find this in any of my texts.
For a shaft of circular cross-section, how do you name the shear stress [itex]\tau_{ij}[/itex] caused by a Torque?
That is, how do you assign the indices i j ? Is it the plane that contains the cross-section?
That is the only way I can make any sense of it.
Silly question, but it is driving me nuts.
Why would it be any different than normal?
None of your text show a 3D infinitesimal element?
http://ic.ucsc.edu/%7Ecasey/eart150/Lectures/Stress/Fig3.6.jpg
In this naming convention, the taus are the off diagonal elements.
I always remember it as...and this is just me...
[tex]\tau_{ij}[/tex] = in the "j" axis direction, perpendicular to "i" axis.
Since this is a cylindrical shaft, wouldn't it be easier to use cylindrical coordinates? That could be the origin of the OP's question...
That doesn't change things because a differential element in cylindrical coordinates looks like a square.
It really is the same thing, but if cylindrical coordinates are what one wants to deal with then how about this...
http://web.mse.uiuc.edu/courses/mse280/Handouts/Example_Stress_Cyl_Coord.pdf
Perhaps I am either wording this incorrectly, or I am more confused than I thought.
I was told by my instructor that when speaking of a shear stress [itex]\tau_{ij}[/itex] that i is the direction normal to the plane, and j is the direction of the shear.
That description doesn't make sense to me. But that might be because I am applying that definition to the entire cross section instead of just a differential element.
Let's take an example. If a torque T is applied clockwise to a cylindrical shaft whose longitudinal axis coincides with the z-axis. How do we name the shear stress that is induced?
If you look at the entire cross section, z is normal to the plane but in which direction do you say the shear acts? Does it even make sense to ask that question since it acts in ALL directions tangent to any radial distance?
If you look at a differential element at the top of the shaft then we can certainly assign a direction to the shear, i.e., to the "right" in the x-direction.
Is my question any clearer? Is that definition that I was given in naming tau correct? I think it only makes sense when talking about an element of the shaft.
Thanks :smile:
"That description doesn't make sense to me. But that might be because I am applying that definition to the entire cross section instead of just a differential element."
Stress states are defined for differential elements so that equilibrium is met.
You tried to define a single stress state for the entire cross sectional area. This resulted in some craziness that certainly didn't jive with your intuition.
The torque induces a shear stress [itex]\tau_{z\theta}=\tau_{\theta z}\propto T[/itex], as cristo indicated.
That's what I thought :smile: My confusion stemmed from my misinterpretation of the definition.
1. What is shear stress?
Shear stress is a type of stress that occurs when two forces are applied to an object in opposite directions, causing the object to deform or break.
2. How is shear stress measured?
Shear stress is typically measured in units of force per unit area, such as newtons per square meter or pounds per square inch.
3. What is the naming convention for shear stress?
The naming convention for shear stress follows the format of "tau" followed by a subscript indicating the direction of the shear stress, such as "xy" for shear stress in the x-y plane.
4. What are the different types of shear stress?
The different types of shear stress include direct shear stress, torsional shear stress, and shear stress due to bending.
5. How is shear stress related to material properties?
Shear stress is dependent on the material properties of the object, such as its strength, elasticity, and viscosity. Different materials will have different levels of resistance to shear stress.
  • Mechanical Engineering
