How are these eigenfunctions obvious (by inspection)?
In summary, the eigenfunctions psi_211 and psi_21-1 are 0 and the other two eigenfunctions (+/-) are linear combinations of phi_200 and phi_210, with equal coefficients due to the equal off diagonal elements in the matrix.
ihatelolcats
[PLAIN]http://img251.imageshack.us/img251/1050/quantume.png
taken from http://quantummechanics.ucsd.edu/ph130a/130_notes/node338.html
I see how psi_211 and psi_21-1 are eigenfunctions, because they are just 0.
I don't see how they got the other two (+/-).
Thanks in advance
Well, this is the way I would inspect the equations:
You have two non-zero off diagonal elements in your matrix. So, you know you are going to have some non zero eigenvalues.
The non zero values fall in the positions of the matrix that connect [itex]\phi_{200}[/itex] and [itex]\phi_{210}[/itex]. Thus, we know that (from previously solving a lot of matrix eigenvalue problems and noticing patterns) the eigenfunctions will be linear combinations of [itex]\phi_{200}[/itex] and [itex]\phi_{210}[/itex].
The off diagonal elements are equal, so the coefficients of [itex]\phi_{200}[/itex] and [itex]\phi_{210}[/itex] will be equal. We need to have normalize eigenfunctions so, we get the linear combinations given above.
1. What are eigenfunctions and why are they important?
Eigenfunctions are special mathematical functions that describe the behavior of a physical system. They are important because they allow us to understand and predict the behavior of systems, such as atoms, molecules, and quantum particles.
2. How can eigenfunctions be identified by inspection?
Eigenfunctions can often be identified by inspecting their symmetry and shape. They typically have distinct patterns and symmetries that make them stand out from other functions.
3. Can eigenfunctions be solved for analytically?
Yes, many eigenfunctions can be solved for analytically using mathematical techniques such as separation of variables, boundary value problems, and differential equations.
4. How do eigenfunctions relate to eigenvalues?
Eigenfunctions and eigenvalues are closely related, as eigenvalues are the values that result from solving for the eigenfunctions. Eigenvalues represent the energy levels of a system, while eigenfunctions describe the corresponding wavefunctions.
5. Are there any real-world applications of eigenfunctions?
Yes, eigenfunctions have numerous applications in fields such as physics, chemistry, and engineering. They are used to solve problems involving heat transfer, wave propagation, quantum mechanics, and more.
