Greatest common divisor | Relatively prime
In summary, the claim is that n! + 1 and (n+1)! + 1 are relatively prime. Proving this using mathematical induction is a possible method, as demonstrated by the base case (n=1) and the induction hypothesis (assuming the statement is true for n=k). However, further steps are required to prove the statement for n=k+1. Another approach suggested is to use proof by contradiction, assuming that n! + 1 and (n+1)! + 1 are not relatively prime and showing that this leads to a contradiction. This can be done by considering a prime number or any integer greater than 1 that divides both numbers.
kingwinner
1,270
Claim: n! + 1 and (n+1)! + 1 are relatively prime.
How can we prove this? Can we use mathematical induction?
Base case: (n=1)
gcd(2,3)=1
Therefore, the statement is true for n=1.
Assuming the statement is true for n=k: gcd(k! + 1,(k+1)! + 1)=1 (induction hypothesis), we need to show that it's true for n=k+1. But I am stuck here. How can we use the induction hypothesis to prove this?
Or am I even on the right track thinking of using induction?
Thanks for any help!
Reduce mod k = n! + 1.
I have no background about modular arithmetic right now. It is an exercise from the first chapter of my book about "divisibility" and "relative primes". How can we prove it without assuming knowledge about modular arithmetic?
Try a proof by contradiction: Suppose that n! + 1 and (n + 1)! +1 are not relatively prime. Let p be a prime number that divides both numbers. Then p divides the difference, and so ... (Can you do the rest?). (Or if you haven't covered prime numbers yet, let d be any integer greater than 1 that divides both numbers and then continue as above.)
HTH
Petek
Write (n+1)! + 1 in terms of n! + 1.
HTH
Petek
I am not sure how to express (n+1)! + 1 in terms of n! + 1, the best I can think of is
(n+1)! + 1 = (n+1) n! +1
Proof by contradiction:
Suppose d is an integer greater than 1 that divides both n! + 1 and (n + 1)! +1
=> d divides (n + 1)! - n! = (n+1) n! -n! = n!(n+1-1) = (n!)n
i.e. d divides (n!)n
I am trying to reach a contradiction, but where is it??
Good first step: you've written it in terms of n!. Now you want to write it in terms of k = n! + 1, so replace all instances of n! by (k - 1) and expand.
OK!
Let k= n! + 1 (=> n! = k-1)
Then (n+1)! + 1 = (n+1) n! +1 = (n+1)(k-1) +1
= nk -n +k -1 +1
=n (n! +1) - n + (n! +1)
But I still don't see where the "contradiction" is...
Hi kingwinner! :smile:
ok, now subtract n! + 1 from that. :wink:
That's exactly what I did in post #6, but I can't find my contradiction...
kingwinner said:
… Suppose d is an integer greater than 1 that divides both n! + 1 and (n + 1)! +1
oh, sorry, I missed that :redface:
ok, if a prime d divides the difference, then d | (n!)n, so d | n!, so … :smile:
Actually Petek was right, I haven't read the chapter about "primes" yet, so I assume no results about primes, so I let d to be any integer greater than 1 that divides both numbers. How should I continue?
But by the way, why if d is a prime and d | (n!)n => d | n! ?
One theorem in the later chapters says: If p is a prime, then p|(abc) => p|a OR p|b OR p|c.
Thanks!
Yup … d | (n!)n => d | n! or d | n …
but if d | n, then d | n! anyway. :wink:
But I think the converse is false.
d | (n!)n => d|n or d|(n-1) or d|(n-2) or...or d|2 or d|1 or d|n
I agree :smile:
but all you need is d | n! :wink:
Actually you are right. I don't know what I was thinking before.
If d | n!, then d | n!
If d | n, then d | n!
So d | (n!)n => d | n! or d | n => d | n!
But we don't know what "n" is, so there does not seem to be any contradiction...?
kingwinner said:
… d | n!
ah, but you started with …
so … ? :wink:
The claim is n! + 1 and (n+1)! + 1 are relatively prime for ALL n E N.
So to use proof by contradiction, we assume that
there exists SOME n E N such that n! + 1 and (n+1)! + 1 are not relatively prime.
But we don't know what that "n" is. It could be 1000, or 10205.
d | n! => n! = d z for some z E Z where d is a prime. I don't see anything contradictory with this. Prime factors are allowed in the factorization, right?
If you have shown that d|n!, then the contradiction arises from the assumption that d also divides n! + 1 (since consecutive integers are relatively prime). However, it does not follow that d|(n)(n!) implies that d|n!. For example 32|(6)(6!), but 32 does not divide 6!.
This problem is trickier than I thought when I gave the above hint.
Petek
Yes, and that means there is a prime d dividing both of them,
and you proved that that d divides n!.
So you have d | n! + 1 and (n+1)! + 1 and n!
(if you still haven't got it … if n = 4, can d divide both 24 and 25? :wink:)
Petek
OK, I follow your arguments that IF d|n!, then we're done.
But as you said "it does not follow that d|(n)(n!) implies that d|n!", then what should I do instead?
Thanks!
Petek said:
… However, it does not follow that d|(n)(n!) implies that d|n!. For example 32|(6)(6!), but 32 does not divide 6!.
If d is prime, d|(n)(n!) does imply that d|n! :rolleyes:
OK, I think that I now have a valid solution. Here're some hints:
Use the Euclidean algorithm to derive the following identity:
(n + 1)! + 1 = (n - 1)(n! + 1) + (n! + 1 - n)
(or just simplify the RHS of the equation to verify the equality).
Conclude that if d divides both (n + 1)! + 1 and n! + 1, then d divides n! +1 - n. Using the techniques discussed in this thread, show that this implies that d divides n. It's already been shown above that d|n gives a contradiction.
HTH
Petek
Correct, but the OP hadn't covered prime numbers when solving this problem.
Petek
HTH
Petek
I haven't learned Euclidean algorithm yet...and also, I fail to see why (n + 1)! + 1 = (n - 1)(n! + 1) + (n! + 1 - n). I tried simplifying the RHS but I got n! n instead of (n + 1)! + 1.
And also, to get a contradiction, I think we need d|(n!) instead of d|n
kingwinner, why are you bothering with this? :confused: The equation you found yourself …
… is much simpler. :smile:
Sorry about that. The equation should be
(n + 1)! + 1 = n(n! + 1) + (n! + 1 - n)
and everything else I wrote is OK (I hope). I just mentioned the Euclidean algorithm to motivate how I derived the equation. Finally, it was already pointed out that d|n implies d|n!.
Petek
@tiny-tim,
The difficulty is deriving a contradiction from d|n(n!) without using the theorem that p|ab implies p|a or p|b, with p prime. It's easy if you can use that theorem, but seems to require additional reasoning if you can't. Or perhaps you do have an easier argument?
Petek
Petek
(n+1)! + 1 = n (n! +1) - n + (n! +1) = (n+1)(n! +1) - n
=> n = (n+1)[n! +1] - [(n+1)! + 1]
By assumption, d divides both (n + 1)! + 1 and n! + 1
=> d divides any integer linear combination of (n + 1)! + 1 and n! + 1
=> d divides (n+1)[n! +1] - [(n+1)! + 1]
=> d|n
=> d|(n!) (since a|b => a|(bc) for any c E Z and n! = n (n-1)! )
So d|(n!) and d|(n! +1) where d>1 <-----contradiction
Thus, no integer greater than 1 divides both n! + 1 and (n + 1)! +1.
(so I think the key point is to express "n" as a linear combiation of (n + 1)! + 1 and n! + 1)
Are my reasonings here correct?
Looks good, but let me review the details tomorrow.
Petek
  • #31
kingwinner,
"Upon further review", your solution is correct and yes, the key was to express n as a linear combination of (n + 1)! + 1 and n! + 1.
Petek
  • #32
Petek said:
kingwinner,
Petek
Hrm. I think simply using the Euclidean algorithm (or a very slight adjustment) to compute the GCD works out to doing the same thing.
  • #33
See my post #23 in this thread.
Petek
  • #34
Petek
One never has to talk about divisibility or anything -- just finish computing the GCD with Euclidean's algorithm and get 1.
  • #35
Petek said:
kingwinner,
Petek
Thanks for the confirmation. :)
Now I'm interested in the method of proof by contradiction about assuming d to be a PRIME (as you said originally).
So to use proof by contradiction, we should assume that
i.e. Suppose that for SOME n E N, d is an integer greater than 1 that divides both n! + 1 and (n + 1)! +1
As shown above, this leads to a correct proof and I'm perfectly fine with it.
But why instead we can assume that d is a "prime" without any loss of generality? (i.e. why don't we have to check the case where d is NOT prime and show that it also leads to contradiction? Why is it sufficient to check only for the case where d is prime?)
Thanks!
  • Linear and Abstract Algebra
  • Precalculus Mathematics Homework Help
