Evaluating integrals or not?
  • Thread starter pivoxa15
  • Tags
    Integrals
In summary, some integrals cannot be evaluated exactly because they do not have a closed form anti-derivative in terms of elementary functions. This is due to the fact that there is no general formula for anti-derivatives and finding the inverse of a derivative is typically difficult. Additionally, even if we use infinite series, some integrals may still diverge. However, for analytic functions, we can calculate a Taylor series and integrate it term by term to get a power series for the anti-derivative, but this only works for a limited number of functions.
pivoxa15
2,255
Why are some integrals not able to be evaluated?
i.e. the integral of (1+1/x^4)^(1/2) is impossible to evaluate exactly from 0 to 1. Why??
It's hard to answer your question without knowing just what you mean by "evaluated", "able", and "why". :tongue:
If you mean "find an expression for the anti-derivative in an elementary form", that is true for almost all integrable functions. the problem is that we simply don't know enough functions. By "elementary functions" we typically mean rational functions, radicals, exponentials and logarithms, and trig functions. That is just a tiny part of all possible functions, even all possible analytic functions.
In a deeper sense, the problem is that while we have "formula" for the derivative, there is no "formula" for the anti-derivative; it is simply defined as the "inverse" of the derivative. And "inverses" are typically very difficult. If we define [itex]y= x^5- 3x^3+ 4x^3- 5x^2+ x- 7[/itex], the direct problem, to "evaluate" the function (Given x, what is y?) is relatively simple. The "inverse" problem, to "solve the equation" (Givey y, what is x) is much harder
evaluate by integrating from 0 to 1. which I have added in the OP.
able as you computing it exactly.
why as in why is it not able to be computed exactly.
So we will have an infinite series as an antiderivative for the function? If so then we can compute the series? It might diverge?
Well, your example diverges. :tongue2:
[tex]\int_0^1 \sqrt{1 + \frac{1}{x^4}} \, dx = \int_0^1 \frac{\sqrt{x^4 + 1}}{x^2} \, dx \geq \int_0^1 \frac{1}{x^2} = \infty[/tex]
Given an analytic function to be integrated, we certainly can calculate its Taylor's series and integrate that term by term to get a power series for the anti-derivative. If I remember correctly, it should converge on the same radius of convergence as the original function.
Of course, not all functions of interest are analytic- i.e. have a Taylors series that converges TO the function on some interval around the central point.
What precisely do you mean by "compute"?
If you mean "write in decimal notation with finitely many digits", then isn't the answer obvious?
If you mean "write down an algorithm that, given an integer n, outputs the n-th digit in its decimal representation", then it is computable.
1. What is the purpose of evaluating integrals?
The purpose of evaluating integrals is to calculate the exact area under a curve or the exact value of a function over a given interval. This is important in many fields of science, including physics, engineering, and statistics.
2. How do you evaluate integrals?
To evaluate integrals, you can use various techniques such as substitution, integration by parts, or trigonometric substitution. You can also use numerical methods such as the trapezoidal rule or Simpson's rule to approximate the value of an integral.
3. Why is it important to know when to evaluate an integral or not?
Knowing when to evaluate an integral is important because there are some cases where it is not possible to find an exact solution. In these cases, numerical methods can be used to approximate the integral, but this may result in some error. It is also important to understand the limitations of integration techniques to accurately evaluate integrals.
4. What are some real-world applications of evaluating integrals?
Evaluating integrals has many real-world applications, including calculating the area under a velocity vs. time graph to determine displacement, finding the volume of a three-dimensional object, and determining the probability of certain events in statistics.
5. Are there any common mistakes to avoid when evaluating integrals?
Yes, there are some common mistakes to avoid when evaluating integrals. These include forgetting to apply the chain rule when using substitution, incorrectly applying integration by parts, and forgetting to account for limits when using numerical methods. It is also important to check your answer for correctness and to simplify as much as possible.
