Determine whether the points lie on a straight line
In summary, the problem is to determine whether the given points lie on a straight line. The traditional approach is to use the sum of distances calculation, but some find it more meaningful to approach the problem using the slope of the line in two dimensions and projecting it into the x-y and x-z planes in three dimensions. Another approach suggested by Ray Vickson is to show that the vector C-A is a scalar multiple of the vector B-A.
maff is tuff
65
Determine whether the points lie on a straight line.
a) A(2,4,2), B(3,7,-2), C(1,3,3)
b) D(0,-5,5), E(1,-2,4), F(3,4,2)
I tried graphing to see the points A B and C to see if they looked like they were in a straight line and it looked like they were but the answer says they are not in a straight line. I looked on Cramster and they said, "For the points to be in a straight line, the distance between the two sets of points closest to each other must equal the distance between the two points farthest from each other." I am not following this logic. Our solution manual for our class says, "In order for the points to lie on a straight line, the sum of the two shortest distances must be equal to the longest distance." This made a little more sense so I tried to test this by doing it in 2D. I graphed the line y=x and chose 3 points: (0,0), (1,1), and (2,2). It turned out that their method worked for 2D and according to the graph I drew, it looks obvious that the the distance from (0,0) to (1,1) plus the distance from (1,1) to (2,2) equals the distance from (0,0) to (2,2) but I can't seem to visualize/see it graphically in 3D. Any tips? Thanks
Do you know how to calculate distance in three dimensions? For problem a, it looks to me like point A is between point C and B. If the points are on the same line, it should be the case that CA + AB = CB.
If A is between C and B shouldn't it be: AB + AC = BC? Or am I confused?
Yep, you're right.
Can you calculate the 3 distances?
You need not compute any distances. All you need to show is that the vector C-A is a scalar multiple of the vector B-A; that is, there is a constant r giving C-A = r*(B-A).
RGV
While the sum of distances calculation that the books suggests is easy and straightforward, I find that I am rather bugged by this approach. I feel like it is more meaningful, in the sense of obtaining a geometric understanding of the problem, to approach the problem differently.
In two dimensions, you can use two points along a line to determine the slope of that line, and then use the slope and one of your two initial points to find the equation the line satisfies (and thus, find all points along the line).
The same approach works in three dimensions, except that you need to reduce the problem into two separate two dimensional problems by projecting the line into the x-y and x-z planes (treat this as calculating an x-y slope and an x-z slope). You then treat the problem exactly as you would in the two dimensional case, except that you will now have two separate equations, and the line is the set of points which satisfies both equations simultaneously.
Edit: Ray Vickson's suggestion above is a more mathematically sophisticated (and computationally easier) method of doing the same thing. If you understand how his approach works (and why it works) then use it. If you don't, then it probably won't help you.
Thanks for all th4 replies. Aimless, that makes more sense doing it that way thanks.
1. How do you determine if points lie on a straight line?
To determine if points lie on a straight line, you can use the slope formula or graph the points and see if they form a straight line.
2. What is the slope formula?
The slope formula is (y2-y1)/(x2-x1), where (x1,y1) and (x2,y2) are the coordinates of two points on the line.
3. Can points form a straight line if they have different y-intercepts?
Yes, points can form a straight line even if they have different y-intercepts. This is because the slope of the line remains constant as long as the points lie on the same line.
4. How can you tell if points lie on a horizontal or vertical line?
If the slope between two points is 0, then the points lie on a horizontal line. If the slope is undefined, then the points lie on a vertical line.
5. What is the significance of determining if points lie on a straight line?
Determining if points lie on a straight line is important in many fields, such as mathematics, physics, and engineering. It helps us understand the relationship between variables and can be used to make predictions and solve problems.
  • Math POTW for University Students
