Aharonov-Bohm topological explanation
In summary, the Aharonov-Bohm effect shows something that cannot be explained by classical physics in the sense that makes observable a classical EM global gauge transformation that shouldn't be observable within classical EM, where only the effects of the fields are observable but not the effects of the potentials. However, in QM where potentials are physical, and so it was theoretically predicted and later experimentally confirmed that charged particles going thru a a region where a magnetic field is negligible show a shift in their diffraction pattern caused just by the vector potential and varying with the flux thru the solenoid.
  • #106
I don't really want to enter in your "you understand nothing" dynamic. I believe I made my point sufficiently clear so I don't need to make that kind of remarks.
It was clear enough I was referring to the ideal case, which is the one used in the topological explanation of the effect. In that case it is clear the infinite solenoide creates a string-like singularity.
I know the physical case of the experiment is not this ideal case but as long as the solenoid is shieldd for the electrons, the consequence is the same, or else the ideal explanation of the different topology is not valid, doesn't explain anything.
With respect to the "declaration of indistinguishability": the math is an instrument of physics, not an end, I know the math of QM doesn't care, that's because of its non-locality, many physicists feel uneasy about nonlocality, but it is accepted by the community as one of the "weird" things of QM one should not question but accept.But remember you started you participation in this thread saying something like the AB effect is really classical, that just its experimental realization is quantum mechanical. Now this is wrong as long as one considers classical mechanics doesn't include nonlocality, unlike QM.
So I guess I accept the indistinguishable argument and the topological explanation within the QM nonlocal frame of mind, but not within the classical frame.
No more need to argue about this. Thanks.
  • #107
TrickyDicky said:
... saying something like the AB effect is really classical, that just its experimental realization is quantum mechanical.
Yes, I said that.
Are you really saying that you don't understand that
[tex]\oint_C A[/tex]
is a classical (non-quantized), non-local, gauge invariant observable already present in Maxwell's theory of electromagnetism? This entity exists classically, but you don't have any classical measuring device; that's where the quantum mechanical description of the electron enteres the stage.
btw.: textbooks about (algebraic) topology in physics are full of classical non-local entities like Aharonov-Bohm phase, Dirac strings, 't Hooft monopoles, solitons, instantons, ... many of them considered in a QM/QFT context but formulated w/o quantizing the gauge field! So it's always the same: non-local entities do exist classically, whereas experimentally a qm device is required.
And this non-locality we are discussing here has NOTHING to do with the non-locality a la EPR!
  • #108
About the "spooky action at a distance" that shows up in the AB effect it might be relevant to cite here the words of Newton, though he was referring to gravity:"that one body may act upon another at a distance thro' a Vacuum, without the Mediation of any thing else, by and through which their Action and Force may be conveyed from one to another, is to me so great an Absurdity that I believe no Man who has in philosophical Matters a competent Faculty of thinking can ever fall into it."
The absurdity was apparently solved in the case of gravity by Einstein's relativity.
But I guess in the case of EM after being for a moment substituted by the "field" concept, it returned with a vengeance with QM. Will that be the last word?
  • #109
I guess one could say those non-local entities exist classically (rather semiclassically) , but without QM/QFT there is no theoretical and experimental support for that assertion, so we are agreeing basically.
  • #110
There is no 'spooky action at a distance' in the AB effect - not in the sense of EPR and entanglement. The electron wave function acts as an "integrator of the A-field", but the interaction itself is local
fine
btw.: are you aware of the fact that there are a lot of classical and non-local entities which are relevant classically? energy (not energy density), the magnetic flux, ... Maxwell's theory can be formulated using these non-local quantities but usually we prefer the local version
  • #111
Not being aware of the distinction between different principles of locality (there is only one for me) and their violations you are referring to, yeah, I'm referring to whatever sense spooky action at a distance as a violation of the principle of locality applies to the AB effect.
This is a nice theme for a different thread, but out of curiosity, do you have any reference where it is explicitly stated that energy is a non-local entity?
  • #112
Please bvelieve me, the non-locality in the AB effect and the non-locality I am QM are totally different and unrelated; they have nothing in common!
In the trivial sense energy is non-local b/c it's an integral; in a rather complex but precise sense it's non-local in GR: http://relativity.livingreviews.org/Articles/lrr-2009-4/
  • #113
See: " Conceptual Foundations of Quantum Field Theory" by Tian Yu Cao, chapter 21: "Is the Aharonov-Bohm effect local?" by Richard Healey, for an opinion different from yours, it is in amazon.com reader freely available pages.
  • #114
I know it's have nothing to do with what is usually called quantum nonlocality that is related with entanglement and EPR paradox.
But it's a nonlocality nevertheless and all nonlocalities share the action at a distance feature, (except in the case of the liberty you take with words below) to add confusion the AB effect's is a nonlocality that is only explained by the QM wave function.
Ugh, you are using non-local to mean global, which is not necessarily related to action at a distance. Ok , this has degenerated to semantics issues, an slippery path.
  • #115
From wikipedia:
"In physics, nonlocality or action at a distance is the direct interaction of two objects that are separated in space without an intermediate agency or mechanism... Quantum nonlocality refers to what Einstein called the "spooky action at a distance" of quantum entanglement.
Nonlocality may also refer to:
Nonlocal Aharonov–Bohm effect, a quantum mechanical phenomenon in which an electrically charged particle is affected by an electromagnetic field, despite the fact that the field is zero in the region concerned" End Quote
You seem to be using "nonlocal" in a way not considered in the wikipedia article, meaning a global or integral entity, so I guess for you the AB effect is local so you disagree with the "Nonlocal Aharonov–Bohm effect" sense of wikipedia.
  • #116
In feynman letures on physics,it is mentioned that if one wants to give aharonov-bohm a meaning in terms of local effect,it must be considered that A is important i.e. A exists just like B.and also it is A(vector potential) not B(field) which holds more reality.
  • #117
Sure, in relativistic QM, that is in QFT locality is recovered.
  • #118
There are a reasonable number of studies of topological considerations in classical or semi-classical contexts that have been published such as:
Botelho & de Mello, "A non-Abelian Aharonov-Bohm effect in the framework of pseudoclassical mechanics", J. Phys. A: Math. Gen., vol 18, 1985
Subdrum & Tassie, "Non-Abelian Aharonov-Bohm effects, Feyman paths and topology", J. Phys., vol 27, no 6, 1986
Berry, "The adiabatic limit and the semiclassical limit", J. Phys. A: Math. Gen., vol 17, 1984
Chiao & Wu, "Manifestations of Berry's topological phase for the photon", Phys. Rev. Lett., vol 57, no 8, Aug 1986
Kitano, Yabuzaki & Ogawa, "Comment on 'Observations of Berry's topological phase by use of an optical fiber", Phys. Rev. Lett., vol 58, no 5, Feb 1987
Bialynicki-Birula & Bialynicka-Birula, "Berry's phase in the relativistic theory of spinning particles", Phys. Rev., vol D35, 1987
(Those are just the tip of the iceberg)
  • #119
instead of discussing words w/ or w/o definitions we shoud look at the mathematical expressions; in the AB effect we have a local expression, namely the A-field and the wave function , and we have a local the interaction term, evaluated via an integral
don't know which term you prefer, but there is no need to refer to any 'spooky action at a distance'; in addition the AB effect does not violate locality in the sense of 'action at a distance feature' or 'violation of Lorentz invariance' or something like that
  • #120
In fact only in a very superficial way is what Feynman mentioned about this in the Lectures (and I seconded in my answer) true, the actual case is more complex and in fact QFT cannot explain the AB effect as a local effect either. I'll quote from the reference I gave above:
"One might suppose that quantum field theory contains the resources to provide a completely local account of the A-B effect. For that theory represents the electrons as well as electromagnetism by means of quantized fields defined at space-time points, and postulates that these fields interact via an interaction term e^x)^A^{x)\jj(x) in the total Lagrangian that couples them at each space-time point x. This secures overall gauge invariance, since while neither I/J(X) nor A^(x) is individually gauge-invariant, their interaction is: a gauge transformation preserves the total Lagrangian, and hence leaves the dynamics unaltered. It may appear that this gives us a gauge-invariant, separable, account of electromagnetism and electrons, plus an account in conformity to Local Action of how these interact in general, and so in particular in the A-B effect. But this appearance proves illusory.
First there is the general problem faced by any interpretation of a quantum field theory. In this case this involves understanding the relation between the quantized electron field and the electrons which are its quanta on the one hand, and the relation between the quantized and classical electromagnetic fields on the other. Without some account of the ontology of quantum fields one can give no description of either electromagnetism outside the solenoid or the passage of the electrons through the apparatus, still less a separable description. And one is therefore in no position to show that interactions between these two processes conform to Local Action.
Suppose one were to represent the passage of quasi-localized electrons through the apparatus by wave-packets formed by superposing positive-energy particle solutions to the Dirac equation, with non-negligible amplitudes only for momenta corresponding to trajectories through the top slit that go over the solenoid and trajectories through the bottom slit that go under the solenoid. Then given a choice of gauge one could think of electromagnetism's effect as that of locally altering the phase of each pair of the overall wave-packet so as to change the relative phases of the different elements of the superposition. But actually neither the electromagnetic potential nor the local phases are well-defined, since each is gauge-dependent. In fact, the interaction is between electromagnetism (represented by the Dirac phase factor) and the entire wave-packet. This changes the overall wave-packet's amplitude at each point by altering the phase difference around curves enclosing the solenoid. But there is no localized interaction between a quantized representative of electromagnetism (such as a quantized coh field) and the component of the electron wave-packet superposition with non-negligible amplitude at that point. In the absence of an agreed interpretation of the ontology of quantum field theories we have no clear quantum field-theoretic account of the A-B effect. But we have good reason to believe that any account that is forthcoming will be nonseparable, and in that sense nonlocal, irrespective of whether or not it could be made to conform to Local Action.
  • #121
The mathematical expressions are analyzed n the reference by Richard Healey I provided.
The purely quantum mechanical interpretation of the effect is nonrelativistic so there is no "'violation of Lorentz invariance' or something like that" because there is no LI one can violate to begin with.
And certainly even using the Dirac phase factor as you do in which the closed integral of the A-field is a gauge-invariant, there is nonlocality and action at a distance, which all nonlocality implies (regardless of if you consider it spooky or not ;-) )
I'll quote the relevant excerpt from the Healey reference:
"At this point, one might naturally appeal to the analysis of Wu and Yang (1975), for they showed how to give a gauge-independent description of electromagnetism which could still account for the A-B effect. Following their analysis, it has become common to consider electromagnetism to be completely and nonredundantly described in all instances neither by the electromagnetic field, nor by its generating potential, but rather by the so-called Dirac phase factor [itex] e^{-(ie/K) \oint_c {A^\mu(x^\mu) • dx^\mu}}[/itex] where [itex]A^\mu[/itex] is the electromagnetic potential at space-time point [itex] x^\mu[/itex] , and the integral is taken over each closed loop C in space-time. Applied to the present instance of the Aharonov-Bohm effect, this means that the constant magnetic field in the solenoid is accompanied by an association of a phase factor S(C) with all closed curves C in space, where S(C) is defined by [itex] e^{-(ie/K) \oint_c {A (r) • dr}}[/itex]
This approach has the advantage that since S(C) is gauge-invariant, it may readily be considered a physically real quantity. Moreover, the effects of electromagnetism outside the solenoid may be attributed to the fact that S(C) is nonvanishing for those closed curves C that enclose the solenoid whenever a current is passing through it. But it is significant that, unlike the magnetic field and its potential, S(C) is not defined at each point of space at each moment of time. There is an important sense in which it therefore fails to give a local representation of electromagnetism in the A-B effect or elsewhere." End quote
  • #122
Yes, there is nonlocality but, there is no "action at a distance" b/c
TrickyDicky said:
... which all nonlocality implies
is wrong.
If you like you may check my posts which explain in detail that there is a local interaction resulting in a non-local phase factor and that especially the gauge fiber bundle carries a non-local topological structure.
Perhaps you may want to understand other explanations like
... there is an important sense in which it therefore fails to give a local representation of electromagnetism in the A-B effect or elsewhere ...
Of course I agree with that; I already presented some mathematical details to let you understand what non-locality in this context means.
The only thing I want to stress is that non-locality in the sense of the AB effect and "action at a distance" have nothing to do with each other.
Please check you references. They never mention "action at distance", I bet. This is your idea, neither mine nor Healey's!
  • #123
I'm simply using the definition given in wikipedia:
"In physics, nonlocality or action at a distance is the direct interaction of two objects that are separated in space without an intermediate agency or mechanism."
If you think it is wrong, you may edit it.
  • #124
You might be confused because "spooky action at a distance" was used by Einstein to refer to the quantum nonlocality related to entanglement and EPR paradox that is not the same nonlocality we are discussing here.
  • #125
I checked this is what Healey says at the beginning of the reference I've been commenting, he clearly equates nonlocality with "action at a distance" in the AB effect case:
"At first sight, the Aharonov-Bohm effect seems to manifest nonlocality. It seems clear that the (electro)magnetic field acts on the particles since it affects the interference pattern they produce; and this must be action at a distance since the particles pass through a region from which that field is absent. Now it is commonly believed that this appearance of nonlocality can be removed by taking it to be the electromagnetic potential Aμ rather than the field Fμν that acts locally on the particles: indeed, Bohm and Aharonov themselves took the effect to demonstrate the independent reality of the (electro)magnetic potential. But the nonlocality is real, not apparent, and cannot be removed simply by invoking the electromagnetic potential. While there may indeed be more to electromagnetism than can be represented just by the values of Fμν at all space-time points, acknowledging this fact still does not permit a completely local account of the Aharonov-Bohm effect."
  • #126
OK, sorry, so the confusion is due to the term "action at a distance" used by Wikipedia and in Healey's text.
In the Wikipedia article on action at a distance they write "In physics, action at a distance is the nonlocal interaction of objects that are separated in space. " They equate 'non-local interactions' with action at a distance, but the fail to explain the difference between nonlocality and action at a distance in general.
Then they write "This term [action at a distance] was used most often in the context of early theories of gravity and electromagnetism to describe how an object responds to the influence of distant objects. More generally action at a distance describes the failure of early atomistic and mechanistic theories which sought to reduce all physical interaction to collision. The exploration and resolution of this problematic phenomenon led to significant developments in physics, from the concept of a field, to descriptions of quantum entanglement and the mediator particles of the standard model" This is OK and clarifies that local fields and their (local) interactions resolve the puzzles.
Please check http://en.wikipedia.org/wiki/Action_at_a_distance_(physics )
In the article on nonlocality you find the confusing equation "nonlocality = action at a distance" again in "In physics, nonlocality or action at a distance is the direct interaction of two objects that are separated in space without an intermediate agency or mechanism. Isaac Newton (1642-1727) considered gravity-action-at-a-distance "so great an Absurdity that I believe no Man who has in philosophical Matters a competent Faculty of thinking can ever fall into it". Quantum nonlocality refers to what Einstein called the "spooky action at a distance" of quantum entanglement." Again the main idea is correct b/c they explicitly refer to the resolution of action at a distance via local fields and local interactions in "without an intermediate agency or mechanism".
http://en.wikipedia.org/wiki/Nonlocality
Healey says "At first sight, the Aharonov-Bohm effect seems to manifest nonlocality"
OK!
"and this must be action at a distance since the particles pass through a region from which that field is absent"
Hm, not so sure about that; let's see what comes next
"Now it is commonly believed that this appearance of nonlocality can be removed by taking it to be the electromagnetic potential Aμ"
Of course this the resultion on the level of the action (which is local).
"But the nonlocality is real, not apparent, and cannot be removed simply by invoking the electromagnetic potential"
Again he is correct b/c the gauge fiber bundle carries a non-local topological structure and therefore the AB effect is non-local in a very precise sense due to the non-trivial 1st homotopy group S1 → U(1). But at the same time the underlying theory i.e. the classical electromagnetism and the interaction of the A-field with matter fields in the Schrödinger or the relativistic Dirac Lagrangian are interactions defined via a local action principle.
So in both references the only confusion is to equate nonlocality with action at a distance in a confusing way.
So whereas
is a non-local entity (posts #16, #45, #77), the underlying Lagrangian
[tex]\mathcal{L} \sim \bar{\psi}\gamma^\mu D_\mu \psi[/tex]
for a Dirac field using the covariant derivative D with a classical A-field is local.
  • #127
but the cyclic integral of A can be made zero in a suitably chosen frame in which there is no magnetic field,because it is only the curl which is important.In that case it is ∅ which appears because of the simple action principle of feynman in which [itex]e^(iS)[/itex],where [itex]S=∫Ldt[/itex],and in it appears -i∫∅dt,which is a time integral.(physics must be same for two inertial observers):confused:
  • #128
To which integral are you referring?
The scenario w/o B-field and R³/R base manifold we already discussed in detail; the Stokes' theorem fails due to topology, so one must not rewrite the line integral to a surface integral over a (vanishing) curl;
The physical scenario with B-field and trivial topology plus Lorentz transformation sending B to zero may be interesting; I think the Schrödinger equation fails b/c it is not Lorentz covariant so one must take the Dirac equation plus relativistic effects into account.
  • #129
How it fails?How will dirac eqn helps here.I don't know how relativistic effects are really of concern here.
  • #130
It's simple: you start with a non-zero B-field inside the solenoid in the lab frame. Now you apply the Lorentz transformation:
- this changes the 4-current density as source of the B-field
- it changes the B-field (for a specific trf. it sends the B-field to zero)
- it creates an E-field
- in case you study the A-field only you have to calculate how the trf. affects the A-field.
And of course the trf. affects the wave function!
But how? this is undefined b/c for the wave function in non-rel. QM you cannot apply the Lorentz trf.; you have to use a fully relativistic description to analyze the effect of a Lorenzt trf. on the wave function and the interference pattern. Otherwise the calculation incomplete.
EDIT:
Looking at the R³/R case w/o B-field and with the A-field as defined above one observes that an Lorentz transformation in z-direction does not alter the A-field (with A°=0, and spatial part perpendicular to z). In this case it's rather trivial that the interference pattern related to a line integral in the xy-plane doesn't change when the whole setup is boosted in z-direction.
  • #131
but even in non-relativistic case,it is possible to eliminate B field. schrodinger wavefunction DOES GET affected because of vector potential as
ψ=ψ0exp(ie∫A.ds),and in absence of magnetic field the line integral does vanish and the contribution will come from ∅.
  • #132
How?
andrien said:
schrodinger wavefunction DOES GET affected because of vector potential as ψ=ψ0exp(ie∫A.ds)
Yes, we all know this.
No, why? The line integral is over A, not over B, so it does not vanish.
Sorry, what is ∅? (a problem with my browser?)
  • #133
if we assume validity of stokes theorem,(no topology),it does vanish.∅ is simply scalar potential(A0).i am just thinking with something like a charge in motion,and we go to it's rest frame and we can eliminate B.it does not depend on non-relativistic motion or relativistic one.Is this not possible to do?:confused:
  • #134
I tried to find some references explaining the topological and gauge theoretic aspects of the Aharonov-Bohm effect: here's a nice article paying attention to single-valued exponentials with multi-valued gauge transforms and cohomologies:
http://bolvan.ph.utexas.edu/~vadim/Classes/11f/abm.pdf
  • #135
is relativity really important here?The reference seems just a copy of sakurai,to which I have already seen.
  • #136
Yes, it becomes relevant once you want to use it to transform away the B-field (that's your idea, not Sakurai's, so you have to deal with it)
There is no single moving charge in the case of the solenoid.
Let's start with the A-field outside the solenoid. It's pure gauge, so it could be gauged away locally (not globally!) and it defines vanishing B-field (and E-field of course). An arbitrary Lorentz trf. sends a vanishing el.-mag. field to a vanishing el.-mag. field b/c the Lorentz trf. is linear in E and B. Therefore the Lorentz trf. does not create E- or B-fields "from nothing". The transformed A-field is of course non-zero but still pure gauge (again this is related to the fact that both LOrentz trf. and gauge trf. are linear).
Now let's look at the A-field inside the solenoid and use Lorentz transformations for electromagnetic fields: http://en.wikipedia.org/wiki/Classical_electromagnetism_and_special_relativity Starting with constant B-field in z-direction and vanishing E-field the formulas simplify to
[tex]{E}^\prime = \gamma {v} \times {B}[/tex]
[tex]{B}^\prime = \gamma {B} - (\gamma-1)({B}{e}_v){e}_v[/tex]
By inspection you see that a pure z-Boost cannot eliminate
[tex]{B}_z^\prime = \gamma {B}_z - (\gamma-1){B}_z = B_z[/tex]
In addition any boost with xy-components produces an E-field, therefore the AB-effect would be (partially) due to a non-vanishing E-field in the boosted frame!
Forget about transforming away B; it does not help.
  • #137
So whereas
See #119.
  • #138
TrickyDicky said:
See #119.
so you agree?
  • #139
No, sorry I meant the quote in #120
  • #140
Do you want me to read the entire post again and to guess what you want me to say by referring to it? or do you want to stress some important ideas and consequences?
Are do you simply agree on the locality of the action principle and on the non-locality of the effect?
Have you understood the difference between nonlocality (which plays an important role here) and "action at a distance" which is irrelevant and confusing in the AB context?
  • Quantum Interpretations and Foundations
9K
  • Quantum Physics
  • Atomic and Condensed Matter
