Deriving normal and shear stresses
In summary, the shear stress in a fluid is given by \tau_{xy} = \mu(\partial_y u + \partial_x v) = \tau_{yx} when looking at only one side of the fluid element. To account for the opposite side, we assume the shear stress is constant and take the average, giving \tau_{xy} = \frac{1}{2}2\mu(\partial_y u + \partial_x v) = \mu(\partial_y u + \partial_x v) = \tau_{yx}. The same logic can be applied to the normal stress, but the correct formula is \tau_{xx} = \mu(\partial_x u), not \tau_{xx} = \frac
Niles
1,866
Hi
When we talk about shear stresses in a fluid, we find that the shear stress is given by
[tex]
[/tex]
This relation we get when only looking at one side of our fluid-"cube". Now, in order to take into account the opposite side we assume that the fluid element is so small that the shear stress is constant, leading to the average
[tex]
[/tex]
Applying the same logic to the normal stresses gives me
[tex]
\tau_{xx} = \frac{1}{2}\mu(\partial_x u + \partial_x u) = \mu(\partial_x u)
[/tex]
However, in my textbook (White) it is given as
[tex]
\tau_{xx} = 2\mu(\partial_x u)
[/tex]
Where does this extra factor of 2 come from in the normal stress?
You used the wrong formula for the normal stress.
What is the formula for deriving normal stress?
The formula for deriving normal stress is σ = F/A, where σ is the normal stress, F is the applied force, and A is the cross-sectional area of the material.
What is the formula for deriving shear stress?
The formula for deriving shear stress is τ = F/A, where τ is the shear stress, F is the applied force, and A is the cross-sectional area of the material.
How do normal and shear stresses relate to each other?
Normal and shear stresses are two types of stresses that act on a material. Normal stress is the force applied perpendicularly to the surface of the material, while shear stress is the force applied parallel to the surface. In many cases, both types of stresses act simultaneously on a material.
What is the difference between normal and shear stresses?
The main difference between normal and shear stresses is the direction in which the forces are applied on the material. Normal stress acts perpendicularly to the surface, while shear stress acts parallel to the surface. Additionally, normal stress can lead to compressive or tensile deformation, while shear stress causes shear deformation.
How do normal and shear stresses affect the strength of a material?
The magnitude of normal and shear stresses can significantly affect the strength of a material. Excessive normal stress can cause a material to fail through compressive or tensile forces, while excessive shear stress can lead to shear failure. Therefore, it is crucial to calculate and consider both normal and shear stresses when designing and testing the strength of a material.
  • Classical Physics
  • Other Physics Topics
