Can Fluent 6.3.26 be used to analyze flow rate and heat in a copper tube?
In summary: The inner pressure of the inner tube is 3.92 bars. The inner pressure of the outer tube is unknown. The tubing is electrolytic copper (99.9% pure). The inlet temperature is 80 degrees Celsius and the outlet temperature is unknown.
origen87
25
hello all,
i am from electrical background and for a project i need to analyse the flow of oil through a hollow copper tube when the tube is subjected to some amount of heat. the outcome should tell me if the heat will be absorbed by the oil and what would be the stress points when i apply different amount of fluid flow rate. can fluent 6.3.26 be used for this?.if so please let me know how to start, because its totally new to me..
thanks a tonne:)
I am sure Fluent can analyze this problem for you but you don't need to go to that level of detail to determine the stress and outlet temperature of the oil.
... if the heat will be absorbed by the oil
The heat has to go somewhere, so yes the amount of heat not absorbed by the copper tubing will be absorbed by the oil and this will increase the temperature of the oil when it exits the copper tubing.
To calculate the exit temperature simple use the following formula
q = mCpdt
where
m = mass flow rate of the oil (lbs/hr)
Cp = specific heat of the oil at constant pressure (Btu/lb-F)
dt = temperature difference between the inlet and outlet of the oil
q = heat absorbed by the oil (Btu/hr)
Use this equation to perform a heat balance between the oil and the fluid that is doing the heating.
... stress points ...
The stress in the tubing is dependent upon the pressure. So for a constant diameter tubing increasing the pressure will increase the stress in the tube wall. See the ASME (American Society of Mechanical Engineers) Section VIII Div.1 for a standard wall thickness calculation for the tubing. If you don't have access to it, let me know and I can help you out.
If you have turns in the tubing the stress at the elbows is not a straight forward calculation.
I am assuming that you are trying to design a hot oil heater with multiple passes using 180 degree return bends. Am I correct?
Trust me, if you haven't used Fluent before, you will spend more time trying to figure out how to use Fluent then you will doing these simple hand calcs and once you are done you will see the Fluent results are probably within .1% of your simple hand calcs.
Thanks
Matt
Thanks Matt!
Well these are coils(round, similar to a suspension used in automobiles) one overlapping the other, I am through with the temp calculations but for presenting it to my boss I need to have a model which is simulated and shows the heat at tube at different points and corresponding stress. When such coils are overlapped the heat of one tube will have effect on others too.
So you have a double pipe serpentine coil?
Are you able to show a picture or print of it?
Thanks
Matt
k..i wil sketch a rough figure.
Hey Matt,
very rough sketch though,but will give you an idea of the system, the two coils are separated by some kind of insulation.
Thanks for the print.
Well, the equation in my first reply is still valid for this system.
If you want to calculate a heat flux, you can "unwrap" the coil and calculate an equivalent straight length of tubing and use that in the heat flux calculation. The only problem there would be with calculating an accurate inside and outside convection coefficient. What is the fluid you are using for heating?
What quantities do you want to calculate?
Thanks
Matt
I am using mineral oil..the one used in transformers..i need to find out the stress at every point.
... need to find out the stress at every point.
Is the outer tubing the same diameter from the beginning to the end? If so the calculation for it is simple.
Sh = (p*r)/t
where
Sh = hoop stress (psi)
p = internal pressure (psi)
r = inner radius (inches)
t = tube thickness (inches)
This will be the stress at every location in the outer tube of the serpentine coil
If you specify and allowable stress for the tube material, you can use the above formula to calculate the required minimum tube thickness.
The inner tube is different because it is pressurized externally. See the ASME code Section VIII Div.1 for the procedure for this. If you don't have access to the ASME let me know.
Thanks
Matt
hey thanks matt!well i don't have access to that, could you please help me with that
What is the inner pressure of the inner tube?
What is the inner pressure of the outer tube?
What material is the tubing? UNS # ? ASTM Spec?
What is the inlet and outlet temperatures of the inner and outer tubing?
Thanks
Matt
I know the needed pressure difference, and that is 3.92 bar,velocity of flow being 0.7m/s.its electrolytic copper(99.9%pure).ASTM spec...inlet temp 80c and outlet 25c
hey sry,,,inlet is 25,,,n outlet is 80c
Oh yeah I forgot to ask you,
What are the inner diameters of both tubes?
Do you have the mean specific heat of the mineral oil?
Thanks
Matt
id=6.5mm,od=8.2mm,,,,,,,,id=4.9mm,od=5.5mm
1.67 kJ/kg.K
origen87, I am out of my office today. I will be able to help you tomorrow.
Thanks
Matt
I know the needed pressure difference,..
Could you get the actual operating pressures of the inner and outer tubes?
Thanks
Matt
i dnt have any clue of d operating pressures. initially i knew only required flow rate and tube dimensions that gave me the pressure difference reqd.
What is flow rate?
Flow rate, also known as volumetric flow rate, is the volume of fluid that passes through a given cross-sectional area per unit time. It is typically measured in units such as cubic meters per second or liters per minute.
How is flow rate calculated?
Flow rate is calculated by dividing the volume of fluid that passes through a given cross-sectional area by the time it takes for the fluid to pass through that area. This can be expressed as Q = V/t, where Q is the flow rate, V is the volume, and t is the time.
What factors affect flow rate?
Flow rate can be affected by several factors, including the size and shape of the cross-sectional area, the viscosity of the fluid, and the pressure and temperature of the fluid. Other factors such as surface roughness and flow velocity can also have an impact on flow rate.
What is heat analysis?
Heat analysis, also known as thermal analysis, is a method used to study the behavior of materials as they are subjected to changes in temperature. It involves measuring the heat flow, temperature, and other thermal properties of a material in order to understand its thermal behavior.
What is the relationship between flow rate and heat transfer?
There is a direct relationship between flow rate and heat transfer, as an increase in flow rate can result in an increase in heat transfer. This is because a higher flow rate means more fluid is passing through a given area, which can carry more heat away from a source. However, other factors such as the thermal properties of the fluid and the material being heated can also affect the heat transfer rate.
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • Thermodynamics
10K
