Methods of determining concentration of solution
In summary, the conversation discusses the most effective methods for determining the concentration of a known solution, specifically a KNO3(aq) solution within 10% of the actual value. Two procedures are mentioned: one utilizing direct proportionality of solution concentration and conductivity, and the other involving a titration with KNO3(aq) being put through an ion exchange column. Other potential methods, such as gravimetric, AAS, and spectrophotometry, are mentioned but may be overkill for the requested accuracy.
bitbot
I was wondering what the most effective (i.e. most accurate) methods are for determining the concentration of a known solution.
In my specific case, I need to determine the concentration of a KNO3(aq) within 10% of the actual value. As of now, I have written up two separate procedures to determine the concentration of the solution. The first one utilizes the direct proportionality of solution concentration and conductivity. The other is a titration with the KNO3(aq) being put through an ion exchange column.
I don't really have any ideas on other methods (besides evaporating the solution) so I'm just asking if there are better methods for this lab.
Chemistry news on Phys.org
Sure there are other methods. For example you can determine concentration of potassium by gravimetric method (not to mention AAS or AES), or nitrate by spectrophotometry. But given the requested accuracy they would be an overkill.
Thank you for the reply. I'll surely look into those methods.
What is the definition of concentration of a solution?
Concentration of a solution refers to the amount of solute (substance being dissolved) present in a given volume of solvent (liquid in which the solute is dissolved).
What are the different units used to express concentration?
The most common units used to express concentration are molarity (M), molality (m), mass percent (%), and parts per million (ppm).
What is the difference between molarity and molality?
Molarity is defined as the number of moles of solute per liter of solution, while molality is defined as the number of moles of solute per kilogram of solvent. In other words, molarity takes into account the volume of the solution, while molality takes into account the mass of the solvent.
What are some methods used to determine concentration of a solution?
Some common methods used to determine concentration of a solution include titration, spectrophotometry, gravimetric analysis, and gas chromatography.
How can I prepare a solution with a specific concentration?
To prepare a solution with a specific concentration, you can use the formula C1V1 = C2V2, where C1 and V1 are the initial concentration and volume of the solution, and C2 and V2 are the desired concentration and volume of the final solution. Alternatively, you can also use a balance to weigh out the appropriate amount of solute and then add it to a known volume of solvent to reach the desired concentration.
  • Materials and Chemical Engineering
24K
12K
15K
  • Biology and Chemistry Homework Help
