Expanding universe - energy/information conservation
In summary, two galaxies moving away from each other due to the expanding universe will create more distance for a spaceship traveling between them each time it makes a trip. This suggests that more empty space and vacuum is being created between the galaxies. However, this concept may not follow the traditional rules of energy and information conservation, as it is on a cosmological scale. Instead, general relativity suggests that the "energy-momentum" is conserved. The cosmological constant and dark energy are two sides of the same thing, and further exploration into this topic should be done through more serious sources such as those provided.
member 342489
I have trouble understanding the following.
Lets take 2 galaxies moving away from each other caused by the expanding universe.
A spaceship traveling between these 2 galaxies, more than one time, will experience a greater distance for each travel.
Therefore my conclusion is, that there must have been created more empty space/vacuum between the 2 galaxies each time the spaceship take another trip.
I have read, that when space expands, then the density of the vacuumenergy remains constant.
So i conclude, that there must have been created more energy and information, coming from nowhere.
But that dosen't make sense to me when I consider the rules about energy/information conservation.
Dosen't conservation in these cases mean constant amount of energy/information?
I already know part of the answer you guys/girls will give me, that there for some reason, haven't been any violation of neither energy nor information conservation.
Im no mathguru, so what I hope for, is some kind of abstract that can give me a basic understanding of why not.
Space news on Phys.org
Consider: although the vacuum energy density may be a constant, and the amount of vacuum increasing, the mass-energy density also is decreasing (the galaxies are moving apart), and only total energy has to be conserved? Isn't the overall energy-density decreasing with the expansion?
However... the tldr answer to your questions is:
Regular small-scale energy conservation need not apply on cosmological scales. The thing that gets conserved in general relativity is the "energy-momentum".
How you deal with this depends on the cosmological model you like - general relativity allows for a range of them.
In the end, what you are thinking about is what is behind all those discussions about cosmological constants and dark energy you hear about.
refs:
http://www.cfa.harvard.edu/seuforum/faq.htm
http://en.wikipedia.org/wiki/Conservation_of_energy#Relativity
Hi Simon.
Thank you for a very good reply.
You are right when you claim that my confusion is "about is what is behind all those discussions about cosmological constants and dark energy you hear about."
I think I get that your point is that I should try to consider the 2 galaxies and the space inbetwen as a closed system where the growing dimension of this system leads to the same density in the system overall.
I also think I get your point when you write "Regular small-scale energy conservation need not apply on cosmological scales" My interpetation of this is, that you consider the 2-galaxy system as a small scale system compared to the entire universe.
My understanding is, that the cosmological constant and dark energy are two sides of the same thing with different names where, as Lawrence Krauss shows, the cosmological constant were put in Einsteins equation to fit them to a steady state universe, and moved to the other side of the equation it describes the precise effect caused by dark energy.
Believe you have been very helpful
Some notes:
On the cosmological scale - the two galaxies and the space between them is not a closed system.
But you can consider model universes with very little in them and see how that works out.
If the system is large enough for cosmological/metric expansion to be a factor, that is not a small-scale system.
Sorry I have just read my previous reply.
"think I get that your point is that I should try to consider the 2 galaxies and the space inbetwen as a closed system where the growing dimension of this system leads to the same density in the system overall."
Should have been:
I think I get that your point is that I should try to consider the 2 galaxies and the space inbetwen as a closed system where the growing dimension of this system leads to a lower density in the system overall.
I have realized that I have missed your point "gets conserved in general relativity is the "energy-momentum" , but I'm on it :-)
Well done.
I gave you two answers, one was to direct you to look again at your reasoning and the other was to direct you to the conserved quantity.
You cannot get a good idea of this stuff from pop-science sources though.
If you are serious about exploring these ideas, then you want some more serious sources like:
http://arxiv.org/abs/gr-qc/9712019
http://preposterousuniverse.com/grnotes/grtinypdf.pdf
But you need special relativity and a bunch of maths as a prerequisite.
You may prefer something more cosmology oriented like:
http://map.gsfc.nasa.gov/universe/
http://arxiv.org/abs/astro-ph/9312022
http://icc.ub.edu/~liciaverde/CERNCosmo1.pdf
... these should be fairly accessible without requiring an undergrad degree :)
Thank you again Simon you have been most helpful and patient ;-)
I will look into the links you provided
Simon I am impressed!
The links you have recommended directs me to exactly what i really wants to know.
thank you!
No worries: those are starting points only though, it's a big subject.
What is the expanding universe theory?
The expanding universe theory states that the universe is constantly expanding and that the galaxies and other celestial bodies within it are moving away from each other. This theory is supported by evidence such as the redshift of light from distant galaxies.
How does the expanding universe theory relate to energy conservation?
According to the first law of thermodynamics, energy cannot be created or destroyed, only transformed. The energy of the universe is constantly spreading out as it expands, but it is not being created or destroyed. Therefore, the expanding universe theory is in line with the principle of energy conservation.
What is the role of dark energy in the expanding universe?
Dark energy is a hypothetical form of energy that is believed to be responsible for the accelerating expansion of the universe. It is thought to make up about 68% of the total energy in the universe, while dark matter makes up about 27%. The remaining 5% is made up of visible matter.
How does the expanding universe theory affect the concept of information conservation?
Information conservation is a principle that states that information cannot be created or destroyed. In the expanding universe, as the distance between objects increases, the amount of information that can be exchanged between them decreases. However, this does not violate the principle of information conservation, as the total amount of information in the universe remains constant.
What does the future hold for the expanding universe?
According to current scientific understanding, the expansion of the universe is expected to continue indefinitely. As the universe expands, the rate of expansion may increase due to the effects of dark energy. This could lead to a "Big Rip" scenario in which the expansion becomes so rapid that it tears apart all matter in the universe. However, this is just one of many theories and the ultimate fate of the expanding universe is still unknown.
