Is it possible to calculate the difference in mass between a Proton and Neutron?
In summary, the mass difference between a proton and neutron is due to the difference in the masses of their quarks.
Passionflower
1,543
Can we calculate the difference in mass between a Proton and Neutron?
If so, how?
[ Moderator: why did you move this from QM to general physics? ]
Hi Passion Flower.
neutron is slightly heavier
Mass of proton : 1,6726 x 10^(-27) kg
Mass of neutron: 1,6749 x 10^(-27) kg
Mass of electron: 0,00091x10^(-27) kg
The mass of a neutron is greater than the mass of a
proton because the neutron contains a proton, contains
an electron with some subatomic particles.
neutron = proton + electron + subatomic particles
nasadall said:
Hi Passion Flower.
So what is the formula?
In energy units (using E = mc^2), the masses are: Proton: 938.272 MeV, neutron:
939.566 MeV, mass difference = 1.293 MeV, electron: 0.511 Mev.
I do not think you understand what I am asking. I am asking if we can calculate the masses or at least the difference in mass. And if so, then what is the formula.
From Wikipedia
Outside the nucleus, free neutrons are unstable and have a mean lifetime of 885.7±0.8 s (about 14 minutes, 46 seconds); therefore the half-life for this process (which differs from the mean lifetime by a factor of ln(2) = 0.693) is 613.9±0.8 s (about 10 minutes, 14 seconds).[2] Free neutrons decay by emission of an electron and an electron antineutrino to become a proton, a process known as beta decay:[6]
n0 → p+ + e + νe
mathman said:
From Wikipedia
n0 → p+ + e + νe
I do not want to be difficult but is my question really so hard to understand?
I suspect you are really asking if we can predict the difference in mass from first (or at least deeper) principles.
This is absolutely not correct. A proton consists of two u quarks, a d quark and a set of virtual quark pairs and gluons. A neutron looks exactly like that with a d quark substituted for one of the u quarks.
Well if we can predict something that implies we can calculate it right?
At any rate, yes, so if the answer is yes I like to see some formulas.
nasadall said:
Hi Passion Flower.
This model of the neutron has been known to be inaccurate for the last 45 years, which you might have realized if you kept reading on the web page you took that from.
We now understand that protons and neutrons are composed of quarks. The proton is composed of 2 up quarks and 1 down quark, while the neutron is composed of 2 down quarks and 1 up quark. There's no simple explanation for the exact difference in the mass between the proton and neutron. It's known that the down quark is slightly heavier than the up quark, so the neutron could be predicted to be slightly heavier than the proton. However, the difference between quark masses only explains a small amount of the neutron-proton mass difference.
The remaining mass difference can only be explained by the strong interaction between the constituent quarks of each particle. This interaction within the proton is stronger, since the proton is stable and the neutron is not. So the proton has more binding energy, again leading to a smaller mass than the neutron. However precisely computing the mass difference is not as simple as writing down a formula, since just about all approximation schemes break down when considering the strong interaction at low energies. Lattice QCD is the most promising computational method for answering such questions, and it gives correct results for nucleon masses to within a few percent.
Ok Lattice QCD it is then.
Within a few percent is ok.
There is no simple formula to be written down. Lattice QCD starts with the definition of QCD observables via path integrals, discretizing on a lattice (along with techniques that took many years to develop) allows these integrals to be done numerically. The resulting spectrum can be converted to (ratios) of particle masses, but I'm not familiar (and not many people outside of the experts are either) with the details. If you want to see some general ideas about lattice methods, you could take a quick look at http://arxiv.org/abs/hep-lat/0506036 One of the more recent computations of light hadron masses appears in http://arxiv.org/abs/0906.3599 but there aren't many formulas there either.
From the second paper:
In the work presented here, a full calculation of the light hadron spectrum in QCD,
only three input parameters are required: the light and strange quark masses and the coupling g.
I can be misreading something, but it looks to me like calculated mass of hadron is still a function of something we can't calculate from the first principles - unless we assume quark mass to be the first principle...
My understanding is that the masses of quarks would come from the Higgs mechanism, thus outside QCD. This paper is as fundamental as it gets for QCD.
There is no need for it to be simple. We passed the time long ago where we had to calculate things by hand.
That looks helpful, in Python nevertheless. I would prefer Maple, any worksheets?
Can we do the full calculation in Maple or mathematica (I prefer Maple).
If the answer is no then what software is used to calculate it?
We certainly can do path integrals, Wick rotations and Monte Carlo stuff in Maple. Discretizing on a lattice I am not sure. What is quenched approximation? It seems if we use that then "the Standard Model explains" is not very relevant statement to the method of calculation or do I see that incorrectly?
You are probably right that we cannot explain the absolute value of a mass but I am already satisfied if we can calculate the relative masses and according to the second paper "the Standard Model should explain the difference". However rather than asking for an explanation, which is tricky (at least to me) in QM anyway I rather see, how we can actually compute this on our desktop computers.
There's a computational obstacle that I don't completely understand related to doing computations with light quark masses. Obtaining physical results is done by some sort of scaling procedure (in masses, this is separate from the lattice spacing) and they must require some extra data to complete the definitions of physical results.
Almost, but due to renormalization, the quark masses at the electroweak scale are very different from those at GeV scales. There are other papers that compute light quark masses and coupling renormalization at GeV scales, but they also use light pion masses as inputs.
I'd expect many of the lattice codes are still written in Fortran and run on parallel supercomputers. I don't think that Maple or Mathematica are well-suited yet to doing these things. While you could probably put all of the formulas into a notebook, neither program would do the computations in a particularly optimal manner. It's still better to explicitly code hard computations.
Quenched means that corrections from fermion loops are being neglected. This is because dealing with Grassmann variables on a lattice is a very hard problem in the first place and the approximation schemes that must be used are computationally intensive.
A side question then would be how computationally intensive is the full calculation. So do I understand correctly that there are two main approaches, e.g. perturbation and QCD lattice and that quenched optimization is a shortcut for the second approach which is a shortcut to the perturbation method?
So how computationally intensive is it? Wasn't this done decades ago? As far as I understand the computing power decades ago can now easily be reproduced on even a laptop.
From the paper on computation of neutron/proton masses (light hadron masses):
Computations were performed on the Blue Gene supercomputers at FZ J¨ulich and IDRIS
and on clusters at Wuppertal and CPT. This work is supported in part by EU grant I3HP,
OTKA grants AT049652, DFG grants FO 502/1-2, SFB-TR 55, EU grants RTN contract
MRTN-CT-2006-035482 (FLAVIAnet), (FP7/2007-2013)/ERC no208740 and the CNRS’s
GDR grant 2921. Useful discussions with J. Charles and M. Knecht are acknowledged
FYI: this paper is considered a landmark culination of 3 decades or work on QCK
FYI: this paper is considered a landmark culmination of 3 decades of work on lattice QCD methods.
Passionflower said:
desktop computers.
Computing the nucleon mass is one of the most expensive calculation done from lattice supercomputers. Not maple on a desktop. Besides, calculating the nucleon mass means that the calculation is not accurate enough to distinguish proton and neutron. There are other calculations dedicated to this difference
http://arxiv.org/abs/hep-lat/0608023
edit
missed the second page of the discussion before posting
Am I wrong in thinking we can already have similar speeds with NVIDIA's CUDA technology?
Interesting article. Do we know what kind of hardware this was computed with?
The apparent lack of computing power makes me wonder, how were those claims that the Standard Model can accurately calculate the relative masses ever verified say 30 years ago? I guess they were not right?
Passionflower said:
Am I wrong in thinking we can already have similar speeds with NVIDIA GPU's?
Where did you see such claims? I thought the early successes of QCD were all about predicting high energy reactions accurately. Surprisingly, this is much simpler than computing masses. I have a friend who worked on lattice QCD years ago - he likened it to computing weather, only harder.
Calculating the relative masses is a huge part of verifying QCD, but there are many other tests. At energies large compared to the mass of the proton, the QCD coupling is much smaller (what's called asymptotic freedom) and perturbation theory is valid. So a huge body of evidence for the correctness of QCD was the agreement between perturbation theory and experiment at those scales.
See also:
http://news.sciencemag.org/sciencenow/2008/11/21-02.html
Got ya.
Looks from the article we at least have the first step:
From the article:
The experimental neutron-proton mass difference:
1.2933317±0.0000005 MeV
The EM contributions is:
em = −0.76±0.30 MeV
(estimated using the Cottingham sum-rule saturated by the Born diagrams),
Difference due to strong isospin breaking:
d−u= 2.05∓0.30 MeV
Related to Is it possible to calculate the difference in mass between a Proton and Neutron?
1. How can the difference in mass between a Proton and Neutron be calculated?
The difference in mass between a Proton and Neutron can be calculated using the mass of each particle and the atomic mass unit (amu) conversion factor. The mass of a Proton is approximately 1.0073 amu, while the mass of a Neutron is approximately 1.0087 amu. By subtracting the mass of a Proton from the mass of a Neutron, we can calculate the difference in mass between the two particles, which is approximately 0.0014 amu.
2. Why is it important to calculate the difference in mass between a Proton and Neutron?
Calculating the difference in mass between a Proton and Neutron is important because it allows us to understand the structure and properties of atoms. The difference in mass between these two particles affects the stability and behavior of atoms, which in turn has implications for various chemical and physical processes.
3. Are there any other factors that can affect the difference in mass between a Proton and Neutron?
Yes, there are other factors that can affect the difference in mass between a Proton and Neutron. For example, the mass of a Proton and Neutron can vary based on the element they belong to, as well as the specific isotope of that element. Additionally, relativistic effects can also play a role in the difference in mass between these particles.
4. Can the difference in mass between a Proton and Neutron be measured experimentally?
Yes, the difference in mass between a Proton and Neutron can be measured experimentally using techniques such as mass spectrometry. This involves separating and analyzing the mass of individual particles, allowing for the measurement of their differences in mass.
5. How does the difference in mass between a Proton and Neutron contribute to the overall mass of an atom?
The difference in mass between a Proton and Neutron contributes to the overall mass of an atom by making up the majority of its mass. While Protons and Neutrons are relatively similar in mass, they are significantly more massive than the electrons that orbit the nucleus. The difference in mass between these particles is essential in determining the overall mass of an atom.
